Question about Eureka Mega Boss 4460DT Vacuum
Remove brush roller so I can replace belt on eureka world vac mega boss model 4460
2 Suggested Answers
  • 52 Answers
SOURCE: bag model for Eureka Mega Boss 4460 type E
The model 4460 is for a Victory model which uses Eureka Type AA bags
They can be found at http://www.totalvac.com/eureka_aa_bags.html
Posted on Jun 12, 2010
On our eureka world vac 9834 we cannot figure out how to remove the roller so we can put a new belt on
On this particular model the TOP cover is removed. There are 2 phillip screws near the roller and 2 tabs near the back wheels (push in with a flat screwdriver while pulling apart). Pull the hose through cover for easy cleaning. Everything I watched or read were for other models, where the bottom cover was removed :-(
Feb 10, 2011 | Eureka Boss 7601 Bagged Upright Vacuum
We just moved in - the house is about 9 years old. I have a Eureka Mega Boss central vac - looks like model # is CV20220. 12.4 amps, 120 volts. Can't figure out what type of bags I need. Can you...
Well, for this unit you will need any of the following bags,
Eureka genuine Part# 90610
Eureka replacement (Central vac bag)
another genuine bag style called CV-1, and/or CV-2
Kenmore Central vac bags
Most of the bags there are available at your local vacuum shop, and sometimes even Sears. The Kenmore central vac bag is, can and will fit your Eureka Mega Boss. Prices range on these bags anywhere from $12-$20 for packages of 3. Generally you will replace a bag once every 3-4 months.
Good luck,
Mark
Nov 10, 2010 | Vacuums
How to change belt
look at the brush box at the top it should have some screws in it (4) undo the screws and lift the top foo the delt is under there
lift the brush roller out to swop the belt but check you fit the roller into its slot right,,,,dont turn the roller end bearings as they have many ways they can fit back in but they need to be set up right first
Jun 20, 2010 | Eureka Mega Boss 4460DT Vacuum
Bag model for Eureka Mega Boss 4460 type E
Jun 10, 2010 | Eureka Mega Boss 4460DT Vacuum
4870 roller part number
I know the belt number
Eureka Part Number: 61110B (Replaces 61110, 61110A)
And the roller i think: Genuine Eureka Brush roller part number 61250-3 for Eureka The Boss/Smart vac/smartvac ultra 4800 series vacuums including models 4870 and 4880
Hope this helps you.
Jan 03, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
Roller brush will not turn on Eureka "The Boss Power Plus" 12 amp
Depending on the model there will be a couple of screws on the top plastic cover. The cover lifts off and the belt is then serviceable. On some models you will need to remove some parts on the bottom too to get the roller out.
In any case just look for screws that hold the covers on and explore a bit. You can't break anything.
Jul 30, 2009 | Eureka Boss SuperLite Bagless Upright...
Can not change belt
some of the eurekas ha screws on the top of the base to remove the cover.others have the screws on the bottom.if they are on the bottom there will be 5 screws1 on each en of the roller in front and 2 on each end of the roller behind the brush and 1on the rear of the bottom plate where yo can see where the belt guide is.make sure you clean the old rubber off the motor shaft or your new belt won't last
Apr 23, 2009 | Vacuums
How do i change the bag on my eureka megaboss 4460 vacuum
I had the same issue and found the manual online. The answer is on p. 10. (Could they make this more difficult??!!)
http://www.eureka.com/service/manuals/70262B.pdf
Jan 11, 2009 | Eureka Mega Boss 4460DT Vacuum
Eureka the boss 5893A brush roller will not work
is there anything jammed underneath.can you turn the brush roller by hand.if not then take it back where you bought it.sounds like you have a defective brush roller
Jan 11, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
MY EUREKA WORLD VAC ROLLERS ARE NOT SPINNING. THE LIGHT IS ALSO BURNED OUT. IS THERE A CONNECTION BETWEEN THESE TWO EVENTS?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=813214
Generic problem for all Vacuums
Posted by agreene1038 on July 21, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Some of the Eureka brushrolls have a sensor in the brushroll that indicates that the brush is moving and the sensor and the light are linked together – you may have a bad brushroll – to check that you need to remove the brushroll, stand it on end and spin it freely, if it does not spin the bearings could be bad or needs to be replaced with a new brushroll and a new belt. The belt change is every 4 to 6 months for the best cleaning. . If you need further help please refer to a local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service
Customer Service Dept 1-800-282-2886
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 21, 2008 | Vacuums
Eureka Mega Boss 4460DT Vacuum Logo
56 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
