Question about Kitchen Appliances - Others
Cuisinart WAF1U Waffle Maker - Kitchen Appliances - Others
  • 83 Answers
SOURCE: waffle mix spilled over entire waffle maker, inside and out
If it is a non-stick surface brushing cold water on with a pastry brush while it is still ver hot and immediately after removing the food will clean the surface easily. As for the outside, if it is a painted surface a non- abrasive cloth with warm water could possible clean it. I would not recommend pulling it apart.
Posted on Sep 25, 2008
  • 5 Answers
SOURCE: Waring Pro Waffle maker
Just spray the grids before each use with something like Pam, or put a thin coat of oil on them. I found it's better to spray before each waffle so it won't stick.
Posted on Mar 09, 2009
  • 33 Answers
SOURCE: I need instructions for a waffle maker mine are lost
When making a waffle have your batter made plug in your maker and get it started heating if there is a light it will go off whenit is hot enough if not wait aprox 2-3 minutes at the most 5 then spay or brush the inside of the plates with a nonstick cooking spray or brush with butter then pour your batter in the center of the bottom plate and close the lid it should start steaming right away watch the steam it is a never fail indicater of how done your waffle is the less steam the more done your waffle is, there is a lot of trial and error with waffle makers, you should spay or brush between each waffle or they will stick. Let me know how it all cooks out. goofballlovers
Posted on May 21, 2009
  • 7 Answers
SOURCE: Does the waffle maker only beeb 3 times after the first waffle?
It beeps 3 times when each waffle is done.
Posted on Sep 03, 2009
What is the best electric waffle iron to make waffles at home?
In my opinion, the best waffle irons are the vintage ones made here in the USA. They are more durable and more reliable than anything made in China today. Look up the older Sunbeam, Toastmaster, Kenmore and G.E. models and you can usually find either round, square or rectangular versions, as well as models with and without non-stick coatings. The years from late 50's to the late 70's are best.
Jul 31, 2015 | Cuisinart Kitchen Appliances - Others
Tip
EAse of cleaning my WAF6
After each use when the batter has spiled over the sides (don"t know why) I sweet talk my wife into cleanig up the mess.......
on Jan 13, 2008 | Cuisinart WAF6 Waffle Maker
How do I replace the coil on my WMB-4 waffle maker?
It's most likely not the coil that's the problem, probably a thermal fuse. Unfortunately, these Made in China waffle makers do not last and are basically disposable after a few short years. Better off replacing it with a good quality, vintage 'Made in USA' Sunbeam waffle iron. You can find good deals online on eBay and Amazon.
Feb 20, 2015 | Cuisinart WMB-4 Belgian Waffle Maker
Need a hinge pin for hinge opposite the handle it is broken
Buy a new waffle maker. I have the same problem. Got by with one broken hinge for a few years, but now the 2nd is broken. Called the company & there are no replacement parts available (looks like the hinge was a common problem). After looking around online, I'm not able to track anything down.
I've personally narrowed my choices down to:
The Caphalon No Peek Round Waffle Maker
Proctor-Silex 26500Y Belgian Waffle Maker
Black & Decker Chrome Belgian Waffle Maker WMB505
Cuisinart WMR-CA Round Classic Waffle Maker
Feb 17, 2013 | Faberware FWM800P Deluxe Chrome Belgian...
I made some yummy waffles in my kitchen waffle maker and forgot about the one waffle. Several months later, I went to make waffles again and found a terrible black powder in the appliance. The waffle had...
Unfortunately you have ruined a perfectly good waffle maker...
The coating in there is a teflon coating that needs to be applied properly for it to work...if you try to use it in the condition it is in then the waffle will stick to the plate...
Best thing to do is to trash the old one and then buy a new one...
heatman101
Jun 24, 2011 | KitchenAid Kitchen Appliances - Others
When using a toastmaster waffled maker do you have to use an oil or butter pan spray?
Normally you mix oil in with the batter, but this doesn't keep the waffles from sticking. Even non-stick waffle makers stick some. Use a light spray of Pam (or similar) on the bottom tray, add your batter than spray the top pan and close. This gives you your best shot at a perfect waffle!
Enjoy!
--W/D--
Jan 17, 2011 | Toastmaster 217 Cool Touch Belgian Waffle...
283 S Waffle Iron.
You can try this site: http://kitchen.manualsonline.com/manuals/mfg/toastmaster/287.html
Its not the exact model but sometimes they are close. Hope this helps.
Aug 13, 2009 | Toastmaster 283S Waffle Maker
Waffle iron gets to hot -waffles stick
before you make your 1st waffle, spray it really good on top and bottom plate with PAM spray, once at the beginning is all it should take- good luck!
Mar 21, 2009 | Gold Medal 5020 Waffle Maker
Power light does lid up when connect
Most appliances that work with heat, are equipped with a thermal fuse so if the thermostat fails, the fuse opens and prevents a fire.  Unfortunately, the thermal fuses are more unreliable than the devices they 'protect' and are exceedingly difficult to find. Since yours is a widely known brand, you might try their website.
Dec 18, 2008 | Cuisinart WMB-4 Belgian Waffle Maker
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
