Continuity test to 6rd BR failed - Computers & Internet
Power at fuelpump relay from main relay and ignition, but no signal from computer. scanner had 5 codes but after unhook battery for a while now codes. does have a open circuit listed on fuel pump
why not post the codes. ???
usa car 96, has many codes, not one, useless or not useful.
(gas cap loose excepted)
Does all lights on car work and radio, bright head lights.?
cranks robustly, ?
spark good,? ECU cuts fuel any time one of 3 park failures, fail.?
so, spark is next.
then if spark is ok then we try test fuel. (spray )0if that fails, cam belt fell off or lost time on cam, every 60k happens.(spec)
if runs and sounds ok on test fuel, good.
crank engine for 5 full seconds, release key does the scan tool show errors. NOW? it will if those 3 spark things above, are failing.
even a dead tacho line can kill all injections.
or if TPS outputpin stuck at 5v due to ground wire to it cut,at TPS,
ok now the relay.
ECU does ground the coil (see schematic?)
but only for 3 seconds, keyon, (repeats key on).
then turns off (all G16s 91+ do that 3 sec rule.)
then the relay closes, cranking full time. look now, 96 relay is on the heater box, behind the glove box, the pink wires are BINGO FUEL.
if that works 12v on pinkk, then check fuel pressure
is car a 2 door? if 2doors, the pit behind left rear tail light
see g402 ground that is pump ground and loves to rust there.(kills pump dead)
as does the pink wires there (rust), (connectors)
see 96 ecu schematic here.
http://www.fixkick.com/schematics-run.html
read the pump page.
http://www.fixkick.com/INJECTORS/pump.html#pumptests
got 34psi
see how to fix and test pump page
http://www.fixkick.com/INJECTORS/PUMP/dead-pump.html
Jun 04, 2016 | 1996 Suzuki Sidekick
2001 Isuzu rodeo GM 4l30e transmission slips in every gear when fluid heats up?
perhaps you need to think about how it cools the transmission. Many have had to add an additional cooler .
May 19, 2016 | Isuzu Cars & Trucks
Mine cranks good but wont start and runs great. Seems to help pumping accelerator while cranking. definetly. ??
no starts have 50 causes
no tuneup tops list
there are 1 to 15 tests to find it, using tools and meters/gauges
scan it yet
check fuses yet?
does CEL lamp glow key on, (it must)_
2.0L engine? J20a?
no spark?
if spark is ok, try test fuel? yet?
if test fuel fails, engine or spark are bad.
15min work, this,,,, and no more guessing what part of system failed.
Jan 22, 2016 | 2007 Suzuki Forenza Sedan
Bogs and quits after running full throttle
Hi, Anonymous the following applies to carbureted also fuel injected models and the usual suspects are:
1. Severely discharged or damaged battery, 9 volts or lower.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Water or dirt in the fuel system, carburetor or filter.
11. Restricted, blocked or kinked fuel line.
12. Fuel tank empty.
13. Gas cap is not venting properly or fuel tank venting system blocked.
14. A failed fuel pump, pressure regulator and or fuel injectors.
15. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
16. Needle and seat stuck closed in the float bowl.
Good luck and have a nice day.
Jan 03, 2016 | Motorcycles
2004 jeep wrangler cluster does not work
stock car, no hacks?
fuses to cluster, there are 2 fuses.
the cluster has a simple self test mode, try that yet?
first?
2004 TJ,
the book is free
read chapter 8J for self test (IIRC push trip button key on)
if that fails 100% the fuses are blown.
the word is "Actuator test" in that chapter.
now the schematic, in chapter 8w, called wiring
page 40
fuse 26 PDC
and fuse 10 cab JB.
the cluster is really a computer.Display system)
when you jack the scan tool in, some power may leak form scan too to the display.
forget the scan tool, for now,
do the self test. first. if that fails, its lost power.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
posted over 100 times, now.
Sep 15, 2015 | 2004 Jeep Wrangler
I take both cams out, ...can i test compression test?
if the valves are there,you can,you can also do a leak down test
Jul 17, 2015 | 2004 Suzuki Forenza
I have a dv9700 hp notebook and no programs are working. Cd drive isn't recognizing disks, wireless is not picking up networks, its not recognizing lan cables, it says no audio devices are installed,...
posted no less that 3 times (corrected)
what OS? operating system ,windows,and what version please.?
this PC was built for many years, and may OS shipped with it. new. I cant guess that.
take out the battery first? and run on nice clean AC ?
carbon dating shows: 2010 year? not too old and is still supported
if still not slammed , still original, as HP MADE it
the F11 key is the magic key that reloads the unstated OS.
power on, F11,f11, f11, bam , recovery mode.
dig? if this fails then the HDD may be bad.
run he BIOS HDD test yet?
do you have the HP media kit? the install disks.?
It will only work if the HDD is good.
to recover it or reinstall the OS
https://support.hp.com/us-en/product/hp-pavilion-dv9700-entertainment-notebook-pc-series/3632106/troubleshooting
tests, there are many tests. is that what you want?
battery out.
screens are not dead. so we skip black screen tests.
BIOS works, you can hit the ESC key as it tells you
and you can boot to CD (using test CD known to work.
you can boot to any test USB stick , make stick with linux live or windows 7 PE live and boot that, see
the PC works right>?.??? simple easy tests.
if all that works then the HDD has issues.
the means what.? (more tests)
1: HDD bad.
2: HDD OS infected.
3: HDD OS corruption, use F11 to retort it per the guides.
One good these, I have many, too many.
but one good test for HDD is what.
a: run the BIOS HDD test.. fails, bingo bad hdd.
b: F11 fails can be bad hdd but not always.
Fll can fail for someone damaged the HP special partitions on hdd. (or the HDD was replaced before)
c: so use the HP media kit to install the unstated OS?
if that fails, the HDD is bad but to prove that
I convert my install cds to USB stick installs.
CD to ISO , RUFUS (iso) to STICK (ask)
if those install the HDD is ok but the CD drive is bad.
see? there are lots and lots of tests to do.
or its just guessing game...
I also have a LINUX disk with a full blown, HDD test in it to tell me if the hdd is bad. this works best.
but im not going to teach this here and now,
you must ask.
I did a long post due to you asking 3 times
you sound serious.....
but what do you want? all we see are limited symptoms.
you fix it?
or others fix it?
or guessing list.?
Jul 23, 2017 | HP Pavilion DV9700Z notebook PC
Jeep grand Cherokee 3.1 TD won't start could it be
NO year? post year, and win.
what country.> stated, why?
cranks ok?
diesel test fuel work>?(spray test)
filters fresh.
fuses ok
scan it yet?
glow plug tests fail>(ask or read the SM?)
Mar 18, 2017 | 2000 Jeep Grand Cherokee
Computers & Internet Logo
174 people viewed this question
David Payne
David Payne
