Question about Samsung HCN5527W 55" Rear Projection Television
Perfect Focus When I try to use the perfect focus function it does not work. When I select perfect function, it will begin the process, but, it will only get up to 37%
  • Anonymous Nov 10, 2007
    ditto, up to 37% then starts over.
    Genius:
  • 1,694 Answers
Perfect "FOCUS" is a misnomer.Convergence is the real issue.Enter servicer mode--perform accurate convergence alignment procedure--activate perfect focus as last step to 100% alignment.If you have a High-Definition source,check procedure for that.
Posted on Sep 27, 2007
Indicators, hazzards,do not work on drivers side,passengers side is perfect,checked bulbs are perfect,known problem in focuas,please help thanks bryan
is both hazzards on the drivers side dont work cuz if only one dosnt work it could be just a loose bulb or ground
Jun 02, 2010 | 2001 Ford Focus
"Perfect Focus" problem on Samsung HCN4727W
You have a bad sensor, a bad digital convergence board, or the new board is not working correctly. I would start by swaping out the convergence board or exchange it for another one. Good Luck
Nov 08, 2007 | Televison & Video
Red will not focus but blue will ...perfect focus stops in middle
REPLACE THE 2 CONVERGE I.C.'S. PLEASE LET ME KNOW IF FIXED. THANKS.
Mar 15, 2009 | Samsung HCN4727W 47" Rear Projection...
Convergence perfect focus not working and double vision
The problem you have is the 2 STK - 392 convergence integrated circuits need replacing the cost in the UK is about £150.
SUPER8
Nov 26, 2008 | Televison & Video
Akai PT4298HD projection tv
convergence must be adj then saved then magic focus
if cannot be adj chips need to be replaced.
Sep 21, 2008 | Akai PT4298HD Rear Projection Television
Blue blurry on perfect focus
Did you try the manual lense focus in the back? There is a wing nut on it and it's pretty easy to change. You just need someone to look at the TV and tell you when it looks good. Additionally for the Blue tube, it's on the far left. You take off the bottom panel in the back to get to this area. Good Luck.
Jan 13, 2008 | Samsung PCN5425R 54" Rear Projection...
Prefect focus control
On the remote you have a door. Open it and you'll find the button focus on the right side the second from up to down. If not is in the menu, go in setup, convergence, auto, ok.
Jan 04, 2008 | Samsung HCN4226W 42" Rear Projection...
My samsung projection tv #pcl5415r don't want to perform perfect focus adjustments
perfect focus functions are based on service mode setup...or factory settings. if the alignment of these setting are loss then the unit wont perfect focus. does the unit have a complete loss of convergence. a complete loss of convergence indicate possible failure of convergence amps.
Jan 03, 2008 | Samsung PCL541R 54" Rear Projection...
White tint/haze
Check any/ all pico fuses in power supply. PVAT! Look for evidence of CRT coolant leak. Since Perfect Focus is a function of convergence,you might consider replacing convergence IC's,then perform alignment in servicer mode,then finish w/Perfect Focus.
Sep 28, 2007 | Samsung HCM4215W 42" Rear Projection...
Perfect Focus not working
enter your service mode by pressing mute-1-8-3- a cross hatch pattern should apear,when it does and it looks alright press and hold the enter key the ,it will say data write then press the focus key the set will align your sensors and retuen to the cross hatch pattern ,tune off set and turn back on and try the magic focus ,should work.
Sep 13, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN5527W 55" Rear Projection Television Logo
146 people viewed this question
Jerry Greenberg
Jerry Greenberg
