Question about Elektra Microcasa S1 Coffee Maker, Espresso Machine
Hi, my electra microcasa semiautomatic has been sitting for a few months. I drained it ,by turning it on it's side and draining it through the steam wand. the water came out clean. I only use bottled
Hi, my machine has been sitting for a few months. I drained it by turning it on its side, and let it drain out through the steam wand. the water was clear. I only use bottled water in it. Now I can't get the water to pump out of the water tank and into the machine. The pump noises sounds like it's working normaly, but its not flowing into the boiler water filler gage or the water tank. please help. Thanks Jeff
3 Suggested Answers
  • 137 Answers
SOURCE: Elektra Microcasa Semiautomatic
clear the connections of glass with boiler. change glass seals. (be careful not to brake sight glass tube)
Posted on Mar 31, 2009
  • 1711 Answers
SOURCE: Steam wand sprays hot water and very little steam.
The boiler lever sensor is dirty, full of scale or bent so more water getting in the boiler than it should be. Try to remove the lever sensor clean it with a brush and put it back.
Please remebr to vote for this answer thanks
Posted on Feb 17, 2010
I cannot get my GCSBDS212 steam iron to make steam.
Have a look at the steam holes in the bottom, they should be nice an clean with no blockage. If they are blocked up you will need to remove the calcium buildup inside the iron. Get some LimeAway at HDepot, pour it into the water reservoir, let sit overnight. Next day turn the iron on and try steaming on some old papers covered with an old rag or towel, once it starts working steam for a few minutes, then unplug, drain it, put in clean distilled water and flush it out until the steam comes out clear. Use distilled water not tap water, it has much less mineral content and will be less likely to plug it up. Most pharmacies and Walmart sell distilled water. ! gallon about $1.25.
Feb 05, 2015 | Sunbeam GCSBDS-212 Digital Steam Master...
Oil plug location
Hi Anonymous, the oil pan is under the transmission. The engine oil drain plug is on the side front left corner. The transmission oil drain plug is on the bottom of the oil pan right side. Good luck
Feb 26, 2014 | 2004 Harley Davidson FLHTCUI Electra Glide...
No steam needs cleaning but can't find instructions on line
Try a solution of 1 tsp. white vinegar and fill the reservoir the rest of the way with water. Turn the iron on just until it heats up to high temperature and then turn it off. Let sit for a couple hours and drain (pour it out the top.) Fill and dump the water out a few more times. Hope that helps.
Sep 30, 2013 | Rowenta Irons
2001 electra glide classic oil plug
Hi Anonymous, for more information about your question please visit the websites below. Good luck and have nice day.
picture of 2004 flht drain plugs Google Search
May 18, 2012 | 2000 Harley Davidson FLHTCUI Electra Glide...
Hi I got an HE2T front loader. its 1 yr 1 month old. i place clothes turn to cycle door locks drum turns they get wet they sit there drum turns once or twice they sit there few min it drains then goes to...
was the trip in house knocked of at any time ,sound like it was knocked of its cycle.Push and hold the on/off button in for about 5 secounds this should reset the program and if tha fails push and hold the on/off botton plus one other botton and hold the both of them in for about 5 secounds.adrian,,,,,,,,,,,,
Aug 11, 2010 | Kenmore 46462 Front Load Washer
Where is drain
The Electra glide bikes usually have the oil tank on the bottom of the transmission. On the bottom of the oil, there are two drain plugs. The one in the center is the transmission drain. The one on the left side a bit forward is the oil drain.
Feb 28, 2010 | 2005 Harley Davidson FLHTCUI Electra Glide...
I have a Black and Decker First Impressions (about 2 yrs old). When on steam it always spits out large puddles of water on the clothes as I'm ironing. It seems to come from the top or bottom part of the...
It's a possibility that you iron steam making elements are caked with lime and possibly the steam holes as well.
Purchase some "Lime Away" and dilute it 50/50 and pour it into your steam iron (drain all the old water out first and leave the iron unpluged) let sit for an hour or so and drain out, fill it again with clear water shake and drain out do this a couple of time then turn on the steam and see if it works properly, use the first time on an old towel to be sure all the chemical has been rinced out. Good Luck.
Feb 28, 2009 | Black & Decker D2030 Iron
Nov 09, 2008 | Elektra micro casa a leva S1CO Espresso...
Elektra Microcasa S1 Coffee Maker, Espresso Machine Logo
32 people viewed this question
Top Elektra Coffee Makers & Espresso Machines Experts
Jaime Hernandez
Shehu Pro
Shehu Pro
Level 1 Expert
Are you an Elektra Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
