Question about Panasonic Toughbook CFU1 Rugged Ultra Portable Intel Atom Z520 133Ghz 1GB DDR2 16GB SSD 56 WS (CFU1AQB2ZAM) Tablet PC
WHERES THE CAP LOCK KEY - Panasonic Toughbook CFU1 Rugged Ultra Portable Intel Atom Z520 133Ghz 1GB DDR2 16GB SSD 56 WS (CFU1AQB2ZAM) Tablet PC
How do I factory reset my lg7530 ?
  1. Turn the phone off.
  2. Press and hold the following keys at the same time: Volume Down Key volumedn_key.png + Power/Lock Key powerlock_key.png on the back of the phone.
  3. Release the Power/Lock Key powerlock_key.png only when the LG logo is displayed, then immediately press and hold the Power/Lock Key powerlock_key.png again.
  4. Release all keys when the Factory hard reset screen is displayed.
  5. Press the Power/Lock Key powerlock_key.png to continue or either of the Volume Keys volume_keys.png to cancel.
  6. Press the Power/Lock Key powerlock_key.png once more to confirm or either of the Volume Keys volume_keys.png to cancel
Jun 24, 2016 | Tablets & eReaders
How do I capital letters on my apple air ipad key pad
In your Settings app, go to General-->Keyboard and make sure the "Enable Caps Lock" is on (green).
After Caps Lock is enabled, quickly touching the Caps key twice will lock it.
(Directions are for iOS 8)
Feb 16, 2015 | Apple iPad Air
For got my key lock password. now saying disabled
Wait at least a minute and you can try to put your key lock again.
Dec 14, 2013 | Apple iPad 64 GB 3G Tablet PC
Key clicks is ON , but NO sound
Is it possible that you also changed the function of the lock switch?
Try going into settings and change the settings of the lock switch to mute/unmute then place the switch itself into the unmute position.
If that brings back the sound of the keys, then it's safe to change the lock settings back to lock rotation.
If that doesn't solve the issue then I would recommend you do a backup and then restore to factory settings using your computer and iTunes.
Hope that helps!
Aug 21, 2012 | Apple iPad 32 GB 3G Tablet PC
How do i activate caps lock where is it??
How about to contact Toshiba for tech help?!
Because I don't know.
Android 4.0 Tablet PC
Feb 01, 2012 | Toshiba Thrive Android Tablet
WHERES JUSTIN BIEBER
he went to poop and the pigs ate him
Mar 18, 2011 | Gateway Tablets & eReaders
My shift key does not works. My cap lock does
Try pressing " Fn + Capslock" at the same time. this will realease your shift and release numlock. if that doesnt work try Fn + F11 I cant remember the exact placement of the keys off the top I i do remember is was a Function button combination with the Caplock key to get it back to normal.
Aug 30, 2010 | Lenovo Tablets & eReaders
Apostrophes key in laptop keyboard is not working, how do I fix it?
It's possible there is a mechanical problem with that key (broken, dirty).
But just in case you also use a usb keyboard with the laptop make sure that you did not disconnect (the usb keyboard) with the number lock engaged. If so you can either use the virtual keyboard to disengage the number lock or reconnect the usb keyboard and disengage the number lock. Then check if the problem is fixed when the usb keyboard is disconnected.
Jul 09, 2009 | Tablets & eReaders
How do you keep the Caps Lock on the Panasonic U1 on
hold the shift key and it should be the same there should be a cap locks
Jun 04, 2009 | Panasonic Toughbook U1 Ultra Tablet PC
No keyboard instructions
You need to press the Function button, then the num lock button. The function button may be labeled FN or F in a different color, the same color as the num lock button.
If that doesn't work, go to start, all programs, accessories, accesibility, on screen keyboard....it will display a regular keyboard on your screen, then click on the num lock key on that keyboard.
May 24, 2009 | Compaq TC1100 (/) PENTIUM M 753 1.2GHZ...
Panasonic Toughbook CFU1 Rugged Ultra Portable Intel Atom Z520 133Ghz 1GB DDR2 16GB SSD 56 WS (CFU1AQB2ZAM) Tablet PC Logo
29 people viewed this question
Top Panasonic Tablets & eReaders Experts
Michael Galve
Michael Galve
Jerry Umali
crveno
crveno
Level 1 Expert
Are you a Panasonic Tablet and eReader Expert? Answer questions, earn points and help others
