Question about Roadmaster Granite Peak 26" Mens Mountain Bike
Brakes on. can't move - Roadmaster Granite Peak 26" Mens Mountain Bike
My front right brake is locking up in drive when i press on them?
this sounds like you have a brake caliper seized and will need replacing. it could also be a bad brake flex hose that has come apart internally not allowing the brake fluid to return when you take your foot off the brake pedal. most of the time the caliper is the problem.
Mar 06, 2015 | 1998 Mercury Mountaineer
HAND BRAKE RELEASESD CAR WILLNOT MOVE
Release hand brake. Pull it again. While feeling for the normal tension have an assistant listen at the rear wheels to see if the brakes are moving and releasing when you release the hand brake. Possible causes:
-binding or stuck cable
-broken parking brake handle ratchet mechanism
-seized calipers, or if drum brakes faulty drum brake hardware/springs
May 11, 2014 | 2005 Hyundai Elantra
HOW To Remove Brake Disc's On 1994 toyota Pickup (4WD) with AUTO LOCKING HUBS, I WANT TO REPLACE Brake Disc's
you need to remove the brake pad and brake caliper , before remove brake caliper ,you need to loose the studs of the brake caliper brackets, after you move the brackets ,the brake caliper and brake pad will loose out, then you move the studs on the wheel hub,after the wheel hub is moved, it will be very easy to take out the brake disc. if you want to buy new brake parts ,just visit us. www.fiverhope.com
Oct 08, 2013 | Cars & Trucks
My Cadillac will not move out of park
Does the shift lever move at all? Are you stepping on the brake pedal when you try to shift out of Park? Do your brake lights illuminate when you step on the brake pedal? There is a safety feature that will not allow the shifter to move without applying pressure to the brake pedal. It is a solenoid wired to the brake pedal switch through the brake relay, which is protected by a fuse in your fuse panel.
Oct 01, 2013 | 2000 Cadillac Seville
Dodge neon 2001 parking brake stuck car won't move
the brakes are locked up from sitting just so long just force it to move and free the brakes
Dec 06, 2012 | 2001 Dodge Neon
Loss of front brake pressure well moving
Some how your reinterducing air into the system but not sure where.
Oct 22, 2012 | 2001 Harley Davidson FXDL Dyna Low Rider
Using my front brake lever,my brake feels tight after awhile its normal feeling,my problem is the brake lights want work any ideas
If I understand you, you are saying that after using the front brake a bit, the lever does not move as far and your front brake light won't work.
If so, there is no adjustment on the brake light switch per se, but you can loosen the bolts on the master cylinder and move it slightly away from the right switch housing. Move the master cylinder just slighty towards the center of the handlebars. The brake light switch in the front of the switch housing. When you pull the lever, the switch moves out and turns on the light. You shouldn't have to move it more than about an 1/8" or so. Try that.
Good Luck, Steve
May 06, 2010 | 2003 Harley Davidson FLSTCI Heritage ...
BMW Z4 will not move, seems like parking brake is still on?
Will the car roll? Put in neutral and try moving it? If not, your brakes might be the issue. Was the emergency brake on while stored? If it was, it is probably is locked in place. Your brake light wouldn't be on if this is what the problem is. Let me know how u make out.
Mar 21, 2009 | 2003 BMW Z4
On my 2003 Chevy Suburban, the emergency brake won't release.
there is a cable running from handle to brake assembly it is probably broke there is a release lever under there on brake about a one inch lever hold down on brake and move this and let up on pedal.
Nov 20, 2008 | 2006 Chevrolet Suburban
Roadmaster Granite Peak 26" Mens Mountain Bike Logo
51 people viewed this question
Top Roadmaster Cycling Experts
ptpumpman
ray gallant
Mark Schmit
Mark Schmit
Are you a Roadmaster Cycling Expert? Answer questions, earn points and help others
