SOURCE: Help setting up Yamaha RX-V461
USE A OPTIAL OR COAX DIGITAL LEAD FROM DVD 2 AMP ,SET AUDIO OUT ON DVD 2 BITSTREAM THEN AMP WILL DECODE DOLBY DIG AND DTS "6 ICONS ON AMP".
HOOK UP DVR WIYH PHONO CABLES AND SET DECODE MODE 2 PROLOGIC2 2 GET SURROUND SOUND.DO NOT USE AUTO SET UP FOR LEVELS AS MOST AMPS ARE NOT VERY GOOD AT THIS,USE THE TEST TONE AND YOUR EARS .
RULL OF THUMB SET FL,FR,CEN AT ZERO REARS +4 SUB AT 0.
TUNE RADIO 2 STATION THEN PRESS AND HOLD PRESET NUMBER TO LOCK IN I THINK!
HOPE THIS HELPS.
CABLE GUY.
SOURCE: Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag. press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
SOURCE: Yamaha receiver RX-V663
Make sure you have an analog RCA audio cable from the source to the receiver. Digital coaxial or optical will not work for zone 2 or zone 3. By adding an analog cable it will not affect your main zone, it will always go to digital first. Hope this helps
Testimonial: "great feedback. "
SOURCE: Yamaha rx-v456 av receiver, shut down with optica cable
Does it work without PS3 attached?
When receiver turns off, it is usually due to badly connected/configured speakers. Try powering on the receiver without speakers.
