Question about Canon Pixma iP6210D InkJet Photo Printer
Canon pixma MG6320 - during installation the screen indicates "support code 5100" and won't proceed. it looks like the ink carriage won't release.
SOURCE: Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Posted on Jun 21, 2008
  • 71 Answers
SOURCE: Error Code 5100
Carriage error. Paper or the print mechanism is blocked.
It could mean the rollers don't grip the paper, there is torn paper keeping the rollers from turning, the paper can't stick to the rollers etc.,
http://noel.bouvet.free.fr/ip4200/Canon%2520Servicemanual_ip4200.pdf
Posted on Sep 01, 2008
  • 412 Answers
SOURCE: Canon Pixma MP830 error 5100
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 09, 2009
SOURCE: canon printer pixma mp110
My Pixma MP110 keep on displaying "CHECK PRINTER (5800)" Please have m to solve this problem
Posted on Mar 17, 2009
pineworks
  • 4041 Answers
SOURCE: Canon pixma mp170 error code 5100
Hi You can Try
Seen lots of ths errors
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Posted on Jan 28, 2010
Giving me service error 5100
5100 is a carriage travel error, either something is stopping the carriage or there is ink or grease on the encoder strip.
Jan 07, 2010 | Canon PIXMA iP1600 Printer
Error 5100
- Carriage unit
- Timing **** strip film
- Logic board ***'y
- Carriage motor problem
Sep 13, 2009 | Canon PIXMA MP470 All-in-One Printer
Pixma MP160 has service error 5100
5100 says the carriage is not free to move all the way left and right, or there is ink or grease on the encoder strip, the plastic strip behind the carriage assembly. You can clean the strip with a Q-tip just damp with water.
Sep 10, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I own a canon printer MP470.it reads error code 5100 anytime i turn the printer on
5100 is a carriage travel error, something keeping the carriage from moving freely from right to left. Sometimes it is also grease or ink on the plastic strip behind the carriage. You can clean the strip with a damp Q-tip, but very carefully.
Aug 14, 2009 | Canon PIXMA MP470 All-in-One Printer
Error code 5100 on canon pixma mx700
5100 says the carriage is not moving all the way across the paper path. There could be grease or ink on the encoder strip, the clear strip behind the carriage. Or a small paper scrap inside stopping the carriage.
Aug 09, 2009 | Canon Office Equipment & Supplies
I am getting a Code 5100 error during the intial setup (right out of the box). I have installed and re-installed the ink cartridges and the Print Head. What am I missing?
5100 error means the carriage is not moving right and left properly, or there is grease on the encoder strip. Look at the clear strip with black stripes behind the carriage and wipe off any grease with a Q-tip.
Jun 30, 2009 | Canon PIXMA MP600 all-In-One InkJet...
I have just replaced 2 ink tanks and they are in correctly. But after printing only one page which is slightly out of alignment up comes the error 5100 code. What happened ?
The print carrier is being interfered with. Take out the cartridges and make sure that there is nothing interfering with the movement of the carriage. The paper being askew indicates that there is something inside the printer interfering with the paper path and the 5100 message indicates the obstruction is also affecting the ink carriage.
Apr 28, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Paper feed pulling to the right during paper feed
Dear all,
Error code 5100 indicates CR (carriage return) error occurs. There are 2 possibilities of this case: Film timing **** strip is dirty or carriage part is faulty. Look inside your printer. There is a film, installed in horizontal position. Try to clean this film first;wipe carefully with moistened clothe. If the problem still persist, it seems that carriage is faulty.
Regards,
Source:
Canon Inkjet Printer Forum
Nov 14, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Printer is flashing checkprinter 5100
dear bria13,
Code 5100 indicates carriage operation error. The printer performs initialization process (include carriage unit operation) at first time we turn it on. During this process carriage unit will move right and left reading film timing **** strip. If carriage unit can read film timing **** strip successfully then it will move to home position (originally on purge unit part). Otherwise error code 5100 shows.
Here are possibilities and corrective actions:
  1. Film timing **** strip become mist caused by grease or ink; wipe film timing **** strip with moistened cloth.
  2. Carriage unit faulty;replace carriage unit.
Find more article about canon ink jet printer here and please give your rating
Regards,
Nov 09, 2008 | Office Equipment & Supplies
PIXMA iP8500
Error 5100 on Canon Pixma iP8500. flashes orange 2 times. Sounds like the paper isn't being picked up. But I don't know how to fix it.
Jan 03, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Canon Pixma iP6210D InkJet Photo Printer Logo
old marine
old marine
