Question about Tools & Hardware - Others
Chamberlain waxmaster w109 manual
Need foam replacement
3 Suggested Answers
  • 20 Answers
SOURCE: I have a Waxmaster 900 type 2 auto polisher by
try machine mart
Posted on Jul 31, 2009
txdallas
SOURCE: How do you remove the foam from the waxmaster?
First off, it's a left-handed thread. I wedged the plastic part with a screwdriver to stop it from moving. Get a socket that fits the hex head and turn (counter-clockwise when facing the bolt head). It came off pretty easy. The problem is a replacement, I couldn't find it. I used 1300l glue to re-attach. I then took a hot glue gun and filled the seam between the plastic pad and foam (the entire circumference). Any industrial glue from a hardware store may work. I must admit, I haven't tried the fix yet, although it seems pretty solid. That's how they are attached at the factory, clear glue.
Posted on Sep 26, 2012
How do you replace battery in chamberlain remote, garage door model 2487355
Do you have the Chamberlain 248735S garage door opener? Chamberlain doesn't have a 2487355 garage door opener; there are the 248735 and 248735S openers.
Most of the Chamberlain remotes are simple to open. Use the visor clip or a flat blade screwdriver to pry the two parts of the remote housing apart. There should be an open space on one edge of the short sides of the remote where you can insert the blade to begin separating the remote housing. Once started, you may be able to separate the rest of the housing by pulling the two sections apart with your hands. See page 32 of the user manual to see a picture of the separated remote or http://support.chamberlain.com/articles/How_To/How-do-I-remove-and-replace-the-battery-in-my-remote-control-1484145519292/?q=change+battery+in+remote&l=en_US&c=Brand%3AChamberlain&fs=Search&pn=1 for the procedure. Replace the battery with a 2032 coin cell battery, if you have the 248735S. Replace the battery with the correct replacement coin cell battery for other garage door opener models. Make sure that the side of the battery with the + faces the section of the remote housing with the buttons. The manual for the 248735S is currently here: https://www.chamberlain.com/CatalogResourcesV3/en-us/shared/files/tucmanuals/114A4256.pdf . Support and manuals for other models of Chamberlain garage door openers can be found from their support page: https://www.chamberlain.com/parts-and-support .
I hope this helps.
Jul 30, 2017 | Building Materials
Chamberlain waxmaster 900w parts
Waxmaster Polishmaster Buffer Pads Bonnets
based on the price there are no repair parts. Unfortunately it's disposable.
I need switch set #41P90100 for Waxmaster
We have no parts here nor can we order any.
Oct 06, 2016 | Building Materials
Why is it when they get old enough to start needing repairs no one responds anymore? Not just this but everything.
Craftsman (LiftMaster) Garage Door Opener Won't Open or ...
? 9:29
https://www.youtube.com/watch?v=w4bgS9_u2u0
Aug 9, 2011 - Uploaded by Kris Kasprzak
Learn how to replace stripped gears in your Sears Craftsmanautomatic ... This instructions should be good for a Liftmaster,Chamberlain, ...
Manual Disengage for LiftMaster/Sears Garage Door ...
? 1:24
https://www.youtube.com/watch?v=y6q5I_JaEoI
May 21, 2012 - Uploaded by Brandon Bailey
Manual Disengage for LiftMaster/Sears Garage Door Opener ....to Replace the Circuit Board on Chamberlain Liftmaster, Sears, and Craftsman ...
Nov 08, 2015 | Sears Craftsman LiftMaster Chamberlain...
Waxmasters
Buffing pads, you will need to use one with long knap. Look like wool.
Aug 07, 2014 | Waxmaster Tools & Hardware - Others
If I use an old webcam with no Windows 7 driver, I get audio, not video. I bought a W109 VGA webcam. If I unplug my old webcam and speaker jack and just plug in the USB for the W109, I get "problem...
you need to have correct drivers for this device in win 7 or you will get strange errors- especially when using just the usb connect- it cannot translate the signal- if you are getting audio with the mic plug but not on usb this is the case. go the the web cams makers site and download the drivers
Jun 13, 2011 | Computers & Internet
Do you sell replacement pads for the 9" waxmaster w109
Replacement parts for waxmaster w109 can be found at amazon, take a look here: Amazon com waxmaster w109 parts. I hope this was helpful. Cheers
Aug 18, 2010 | Chamberlain Standard Duty Polisher/Waxer
I inserted a screwdriver in a slot of the holder and unsrewed it, counterclockwise. I could not find a replacement so i glued it back on.
Sep 06, 2009 | Chamberlain Standard Duty Polisher/Waxer
Tools & Hardware - Others Logo
106 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
