Question about Hori PS3 Racing Wheel
Steering won't work - Hori PS3 Racing Wheel
2000 dodge caravan horn won't work at steering wheel only
probably need a new clock spring. it sits behind the steering wheel. have you tested the horn pad (switch) itself?
Apr 06, 2013 | 2000 Dodge Caravan
Steering wheel won't lock, key won't come out
If the ignition normally only locks with the vehicle in park position, then check the switch on the gear lever mechanism is working.
If not, then you'll have to jiggle and wiggle that key out or replace the ignition lock.
Nov 10, 2012 | Volkswagen Cars & Trucks
I replaced my power steering pump in my 1994 toyota pick up and the power steering still won't work? What else could be wrong?
If you are saying the steering is difficult to turn you could have a blocked hose or a problem in the gearbox.
Or something in the front suspension such as a faulty ball joint.
Jul 15, 2012 | Toyota Pickup Cars & Trucks
Kia rio steering wheel is locked and won't turn
Okay, I just had this same problem with my 2009 Kia Rio and I did this. So not to down everyone's post on here -- everyone is correct -- by turning the steering wheel back and forth and turning the ignition key at the same time is a correct method. However, after talking to a Kia Serviceman, he told me you have to do it hard -- meaning turning it violently back and forth hard (madman style). In order to do this operation, I had my wife sit in the driver side and turn the key while I was on her left side grabbing the steering wheel and violent moving it back and forth like a madman, and after about 2mins of doing it the key turned over -- problem fixed. Do not worry about breaking anything; turning the steering wheel violently hard is a must -- this was told to me by a Kia service Rep. Remember -- have someone assist you; either turning the key or violently turning the steering wheel back and forth. Hope this works for you!!!!!
Apr 06, 2012 | 2007 Kia Rio5
Key won't turn in ignition
On many vehicles, the key locks the steering wheel. If the wheel is turned, it can keep the key from turning. While trying to turn the key, push the steering wheel hard to the right and if that doesn't work, push the steering wheel hard to the left.
Gary
Sep 30, 2011 | Cars & Trucks
Steerin wheel is locked and won't turn when engin is on
If the steering wheel is completely immovable, then something is jamming it. You'll need to pull the column covers and look under the dash.
If the steering wheel is very hard to turn, then your power steering is not working. Check the steering pump belt (could be broken) and check the steering fluid level.
SD
Jun 13, 2011 | 2002 Mitsubishi Galant
My steering wheel is stuck and when I put my key in it won't turn either. It starts to turn but won't go all the way
hi,it maybe a good idea to remove the steering collum covers to visually inspect it can be the ignition bolt just being loose or the steering lock or ignition it self is on its way out.
May 19, 2011 | Volkswagen Jetta Cars & Trucks
It is leaking power stering fluid and i cant find from where
Hi
Follow the pipes by hand from the power steering pump to the steering rack,you should get an oil deposit on your hand where the leak is. hope this works. check the pump it self for any leaks.it could also be the seals of the steering rack and into the steering bellows and it won`t show you the leak at least until now.
Peter
Nov 15, 2010 | 2003 Acura MDX
Honda 2001 ex stopped running and steering locked up
you say stopped running steering locked up the steering lock is mechanical and has nothing to do with the actually running of the engine so i am presumming that the car was idling stalled on its own and the steering as you tried to restart it locked or the steering won,t turn it won,t if the engine s not running as it is helped by the power steering pump which doesn,t work unless then engines running but if the steering has just locked up then you won,t be able to turn the steering in which case you,ll need a new steering lock not that big a job yates210456
Jul 20, 2008 | 2001 Honda Accord
Hori PS3 Racing Wheel Logo
Top Hori Video Game Consoles & Games Experts
James Wishart
Are you a Hori Video Game Console and Game Expert? Answer questions, earn points and help others
