Question about Furniture
Koldfront wine cooler has become noisy - Furniture
bobotfel
  • 236 Answers
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Posted on Jan 21, 2008
  • 3 Answers
SOURCE: Noisy Wine Fridge
The problem is likely with one of the two fans. A new fan is available from Danby (1-800-263-2629). My noisy fan is the condensor fan located at the bottom rear of the device. After removing the cooler from under the cabinet, the source of the noise was obvious. You will need to tell them whether it is the upper fan or lower fan. Leave the cooler upright for a few hours before you plug it in so that you do not damage the condenser. Price for the fan from Danby is $20.15 including shipping. Users Manual is available at http://www.danby.com/manuals/DWC512BL.pdf -Ron
Posted on Apr 13, 2009
  • 286 Answers
SOURCE: u-line 75WC wine cooler - rust on inside back wall
This happens when the racks get too close to the evaporator. Or bottles. You can try to use hot water but usually you will need to buy new racks for the unit.
Posted on Jun 15, 2009
mrbobfixit
  • 259 Answers
SOURCE: Are red wines stored on the top or bottom of the
http://www.haieramerica.com/en/asset/archived/BC112G.pdf
is the link to your manual.Typically in a dual temperature zone wine cooler whites are stored in the bottom and reds on top as whites are better a little colder and the cold air will drop to the bottom of the unit.
Hope this helps!
Posted on Jun 14, 2010
  • 31 Answers
SOURCE: Why are wine coolers so noisy?
Compressor-run wine coolers may be slightly noisy at times; however thermoelectric coolers are completely silent.
Posted on Jul 31, 2012
Plugs in but wont turn on
Koldfront 12 Bottle Stainless Steel Slim-Fit Thermoelectric ...
www.amazon.com/Koldfront-Bottle-Stainless-Slim-Fit...
Amazon.com, Inc.
Rating: 3.7 - ‎42 reviews
Koldfront 12 Bottle Stainless Steel Slim-Fit Thermoelectric Wine Cooler - Black/Stainless Steel ... Item model number, TWR121SS .... the fridge. so you hvae to take out a wine bottle to reach it an usually I would like the controls on the door and only turn in .... The door can be reversed which the description did not mention.
www.edgestar.com/Koldfront-12-Bottle-Stainless-Steel-Slim-Fit-Thermo...
Koldfront 12 Bottle Stainless Steel Slim-Fit Wine Cooler Primary Image ... steel, the Koldfront 12 Bottle Slim-Fit Thermoelectric Wine Cooler (TWR121SS) is ... cabinet and stainless steel accents ensure that this freestanding unit will look ... Power: 70 W/0.95 A .... Unfortunately, your browser does not support video elements.
www.walmart.com/.../Koldfront-12-Bottle-Stainless-Steel-Slim-F...
Walmart
$109.99 - ‎In stock
Jan 20, 2016 | Koldfront 12 Bottle Stainless Steel...
I have a DIHL CF-18TN wine cooler which seems rather noisy . Can you help
You might want to post this question in the wine coolers section so that the proper expert sees it.
Sep 02, 2012 | Compaq Presario CQ5110F (NP185AA ABA) PC...
Jul 31, 2012 | Furniture
Noisy when running
condenser fan blades are cover with lint or the fan motor may be going out. Clean fan blade first before doing anything else. If noise stops after cleaning the fan blades; hooray! If not you might have to replace the fan motor itself. Test and re-check before taking other step(s)
Jan 04, 2011 | Haier BC112G Wine Cooler
Motor in wine frige is noisy???why
That motor is an evaporator fan motor. That noise occurs when the bushes in the motor start to wear. The motor is not in effect repairable but has to be replaced. Normally a 9 watt evaporator fan motor is installed into those wine coolers.
Aug 31, 2010 | Haier BC112G Wine Cooler
Does not chill drinks
you wrote that the wine cooler "only cools to 12 degrees minimum" I don't understand the problem?
12 degrees is really cold, in fact its freezing.
Oct 29, 2008 | Sunpentown Platinum Trim Cabinet...
U-line 75WC wine cooler - rust on inside back wall
Sep 17, 2008 | U-Line 75WC Wine Cooler
Fan noise
Sometimes the bearing gets dry. Take it out and try to put a small amout of household/3M oil on the shaft to see if it helps. Some have small holes that are for putting oil into to feed the bearings.. You may be able to do this without taking it out. Be very sparing with the oil to prevent getting too much in it.
Feb 15, 2008 | Danby DWC283BLS Wine Cooler
Wine cooler noise
Dec 30, 2007 | Danby Silhouette DWC512BL Wine Cooler
Furniture Logo
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Furniture Expert? Answer questions, earn points and help others
