When ever I try to access the Life Insurance exam on BSPN, I receive an error report Which has across the top, Server Error in "/Portals/BankersLife/SCORM/SCORMEngine/Central' Application. Then it has: Object reference not set to an instance of an object. The source error: An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be idenified using he exception sack trace below. Stack Trace: ReferenceException: object reference not set to an instanceof an object.] RusticiSoftware.ScormContentPlayer.Logic.DefaultIntegration.SetCulture(HttpRequest request) +14 RusticSoftware.SScormConentPlayer.CenttralInterface.Launch.Page_Load(object sender, EventArgs e) +384 System.Web.UI.Control .Onload(EventArgs e) +67 Sysem.web.UI.Conrol. LoadRecursive() +35 System.Web.UI>Page.ProcessRequestMain() +739
HWK UPDATE
Originally Posted by MIRYALA SRINIVAS viewpost.gifhwk Update server has crashed,ODIA TEAM is working to fix the issue ASAP.
So dont update your box.
We inform you when server is working fine
Br.
Vijendra Saini.
dear sir,
i have format my pc then i need to install what should i do????????
Upgrade log:
---------- HWK Update Client v 2.0.8.0 ----------
---------- HWK upgrade started:9/8/2009 8:19:09 PM ----------
-- Target Id : 62 CF 1 10
-- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003.
-- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007.
-- UFSx S/N : 71327
-- Features : 00000001
-- Licence 5 : True
-- UFSx Vendor: TORNADO
-- HWK ID : A1.04-PRO1-7ACEA977416000C9
-- HWK Status : 1, DL: 0
Locating HWK Upgrade server...
HWK Upgrade server found!
Preparing connection to server...
Connecting to HWKUpgrade server...
Server connection successfully established.
Authenticating on server...
Authentication stage error: Error: Server returned unrecognized reply
Jul 25, 2012 | Computers & Internet
I have a problem, i try to access the Avocent ts100 by hyperterminal in winXp, I used a usb to db9 cable but it didn't access to first page or menu, the hyperterminal configuration is 8n1n, only show...
plz
Authentication stage error: Server reported error:No more upgrade logs. Please contact your reseller. report.gif digg.gifdelicious.giftechnorati.giffacebook.giftwitter.pngstumbleit.gif quote.gif
Jul 13, 2011 | Avocent Cyclades TS100 (TES0061001)
Internet explorer http internal server error 500 help gave it a day still cant get online!!!
Error 500 to 504 are usually nothing to do with your system, they are errors created by the server you are trying to connect to.
Introduction
A server (not necessarily a Web server) is acting as a gateway or proxy to fulfil the request by the client (e.g. your Web browser or our CheckUpDown robot) to access the requested URL. This server did not receive a timely response from an upstream server it accessed to deal with your HTTP request.
Mar 21, 2011 | Computers & Internet
I have application error 302
Introduction
Your Web server thinks that your URL has been temporarily redirected to another URL. The client system is expected to immediately retry the alternate URL.
302 errors in the HTTP cycle
Any client (e.g. your Web browser or our CheckUpDown robot) goes through the following cycle when it communicates with your Web server:
  • Obtain an IP address from the IP name of your site (your site URL without the leading 'http://'). This lookup (conversion of IP name to IP address) is provided by domain name servers (DNSs).
  • Open an IP socket connection to that IP address.
  • Write an HTTP data stream through that socket.
  • Receive an HTTP data stream back from your Web server in response. This data stream contains status codes whose values are determined by the HTTP protocol. Parse this data stream for status codes and other useful information.
This error occurs in the final step above when the client receives an HTTP status code that it recognises as '302'.
Resolving 302 errors - general
The 302 response from your Web server should always include an alternative URL to which redirection should occur. If it does, a Web browser will immediately retry the alternative URL. So you never actually see a 302 error in a Web browser, unless perhaps you have a corrupt redirection chain e.g. URL A redirects to URL B which in turn redirects back to URL A. If your client is not a Web browser, it should behave in the same way as a Web browser i.e. immediately retry the alternative URL.
If the Web server does not return an alternative URL with the 302 response, then either the Web server sofware itself is defective or your Webmaster has not set up the URL redirection correctly.
Resolving 302 errors - CheckUpDown
Redirection of URLs may occur for low-level URLs (specific URLs within your Web site such as www.isp.com/products/index.html) when you reorganise your web site, but is relatively uncommon for the top-level URLs (such as www.isp.com) which most CheckUpDown users ask us to check. So this error should be fairly infrequent.
The 302 response from your Web server should always include an alternative URL to which redirection should occur. If it does, CheckUpDown automatically tries the alternative URL. This in turn may possibly lead to another redirection which CheckUpDown then tries. This continues for a maximum of 5 redirections. As soon as 5 redirections have occurred, CheckUpDown gives up and reports the 302 error for your account. So you should only ever see the 302 error if 1) your Web server gives no alternative URL on the 302 response or 2) the number of redirections exceeds 5. This second condition should be fairly unlikely - and may indicate a recursive pattern e.g. URL A redirects to URL B which in turn redirects back to URL A.
You first need to check that the IP name we use to check for your account is accurate. If you or your ISP have configured something so that any access using this name should now be redirected to another name, then you need to update your CheckUpDown account to start using the new name.
If you believe that the IP name we use is exact (should not be redirected), please try accessing the current URL using a Web browser. Note carefully which URL actually gets displayed, because your browser may silently switch to a substitute URL if it receives an 302 message from your Web server. If you see any evidence of a new URL, try accessing that directly from your browser. If this works (you see your Web site as expected), then this new URL is what you may need to update on your CheckUpDwon account. If this is a temporary redirection, then you may also need to reinstate the original IP name at a later date when the redirection is no longer effective.
If none of the above help, we can analyse the underlying HTTP data streams we receive from your Web server. These can provide additional information about the new URL(s) which your Web server thinks we should be accessing. Before doing this, we prefer you to identify any deliberate changes on your side, liaising with your ISP if needs be.
302 errors should occur infrequently, because top-level URLs do not change often. If they do change, then this is typically because a redirection URL is being suggested. This pervasive change is unlikely to occur by accident, so most often we can resolve this error by updating our system records for your account following a deliberate change of URL on your part, whether this change is temporary or permanent.
Aug 02, 2009 | Dell Pentium 4, 2.26 GHz (1W391)
During the setup i get an error 302
Jun 28, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Premium users are not allowed to access this server. Error???
Lets try to update your yahoo by doing so many problems will be solve, it will take few min depending in your conection.
Your rating is very important to me...
Was this helpful?
May 25, 2009 | Yahoo Mail
Facing problem with outlook plz help
Either the message you are trying to send is too big, e.g contains a too large attachment, or your mailbox on the server is full...
Mar 31, 2008 | Microsoft Office Outlook 2003 for PC
When trying to refresh a Business Objects error... DMA0007
If changes have been made to the universe it may well be that in Deski you're using a local copy of it,
I would first advise exporting the universe to the repository (cms ) and having another go in Infoview just to ensure that the same copy of the universe is being used.
If it still fails, you will need access to the Business Objects server as it could well be that the connection on the server is either missing, incorrect or using a different version of middleware.
The fastest way to check on the server, is to launch Deski directly on the server and import the report > refresh it and see if you get the error.
If so then we know that it's a connectivity issue.
Sep 11, 2007 | Business Objects BusinessObjects...
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
