Question about Moultrie D55 Digital Camera
Camera will set up ok and count down, then goes to Rdy and a few seconds later lights go out. Settings are correct and San Disc has been formatted. Pictures will not take, despite 100% battery.
Samsung dv331agr wont turn.
This dryer is notoriuos for the belt popping off if you turn the drum counter clockwise
Jan 23, 2014 | Samsung DV331AGR Dryer
Need correct day and time on Olympus FE 170 digital camera
How do I set the date and time on the FE-170?
To access the clock controls, turn the mode dial to any shooting mode except [GUIDE] and then press the [MENU] button. Next, press the Right arrow on the arrow pad to select the [Setup] icon. Using the Up or Down arrow, navigate to the menu item depicting a clock. Press the [OK] button to access the clock settings feature.
Set the year, month, day, hour, minutes and date format using the following procedure: Use the Up and Down arrows to select values, and press the Right arrow to advance to the next item. (The FE-170 uses a 24-hour clock.) When all information has been entered, press the [OK] button to set the values. Press [MENU] twice to exit the menu.
To set the time precisely, with the cursor on either "minutes" or "date format," press the [OK] button as the time signal strikes 0 seconds.
The date and time settings will be returned to the factory defaults if the camera is left without batteries for approximately three days. Custom settings may be canceled more quickly if the batteries were only loaded into the camera for a short time before being removed. Before taking important shots, check that the date and time are correct.
Oct 22, 2012 | Olympus Fe-170 6.0 Mp 3x Optical Zoom...
New Easy share m530..by accident trying set up switched to foriegn language.How do I get to english? all instructions are in other lang.
You'll just have to count the options carefully to get the right one. First press the MENU button, there will be two 'tabs' and you want the second one, you'll probably have to press "right" to get it. Now press "down" and count through these options:
  • Date and Time
  • LCD Brightness
  • Share Button settings
  • Red Eye reduction
  • Orientation Sensor
  • Camera Sounds
  • Video Out
  • Image Storage
  • Language
  • Reset Camera
  • Format
It might be easier to go to the bottom where About is, and go "up" by three...
If you get it right, when you press OK on the right one, you should see many languages including English IN ENGLISH. If you do, go ahead and select it and press OK. If you don't... back out and don't change anything!
Mar 25, 2011 | Kodak EasyShare M530 Digital Camera
I have a digital camera and the model is C1033 , i put a san disc drive card in with a memory card in the san disc and on christmas day it worked fine, a few days later i couldnt take a picture and it says...
Sound like the card is corrupted. Take it out and try in a card reader, search for image recovery software if you can't read the card properly. When you've finished trying to get the images off the card format the card and retry in the camera.
Jan 02, 2011 | GE C1033 Digital Camera
How do you set the timer on a Finepix F50D, I don't have the manual with me
Press the bottom part of the ring around the menu/ok button to activate the timer. Press once for 10 second count down and twice for 2 second count down. Then press the picture button as normal and the count down will start.
Nov 26, 2009 | Fuji Finepix F50FD Digital Camera
Problem with taking picture with SD card
The only thing I can recommend is using the brands of memory cards that Casio recommends. They are Panasonic, San Disc, Toshiba. Make sure the card is formatted with the camera before use.
Nov 07, 2008 | Casio Exilim EX-Z750 Digital Camera
Answer to your question
You will need to get into the bios, and set the CD drive to boot before the hard drive. Since your in this uncompromising loop, remove the hard drive, then start the machine. It should go to the initial Toshiba screen and you will see the prompt on what to press to get to the bios, or utility set up. Once your in the bios, find the boot order and set the CD drive over the hdd. Then put the hdd back in, the recovery or operating system disc in the CD drive, and start the machine. It should now boot from the disc. At this point you will want to do a system repair. If the repair doesn't take, then reformat the hdd, and install a new operating system. If the hdd will not format or you have any issues during or after the install, then the hdd has failed and will need replaced. If you need any futher aststance, just ask.
Aug 28, 2008 | Toshiba Tecra M1 PC Laptops
S630 lens out and wont turn on
Cameras belonging to the S Series really do have a battery type option that needs to be set up first for proper power connection.
Recommended batteries are just:
- Alkaline (Non-rechargeable)
- Nickel-metal Hydride (Rechargeable)
Just the proper battery type by:
- Pressing MENU/OK button
- Scroll to the right until you are in SETUP 2
- Keep on scrolling down and look for battery type
- Press the right button to pick up on 2 options
like Alkaline and Ni-MH
- Press MENU/OK for changes to be saved
- Keep pressing MENU/OK to get out of the MENU
Once, it's done, camera needs to be turned off for a few seconds
so that settings made will be refreshed with the camera.
As you turn camera on, you're now ready to take many pictures.
ALKALINE (Non-rechargeable) batteries when set to the correct battery type will really take a maximum of 100 pictures.
For the Rechargeable batteries (Ni-MH), when those are fully charged, and the battery type is set to Ni-MH, it will be taking more than a hundred of course.
I hope this help you a lot.
Jan 11, 2008 | Samsung Digimax S630 Digital Camera
Low battery?
Cameras belonging to the S Series really do have a battery type option that needs to be set up first before taking any pictures for proper power connection.
Just set the proper battery type by:
It really doesn't matter if you'll be using 2500mAh. So long as those are the recommended batteries, those will work.
If it still does not work, call the Manufacturer.
Dec 15, 2007 | Samsung Digimax S630 Digital Camera
Why can't I play my cds?
'no rdy' meens not ready so you disc tray is stuk take it a part and dose it make a noise az if the cogz are sliping if so the lil band in side you disc tray has broke
Oct 18, 2007 | Durabrand W600 Shelf System
Moultrie D55 Digital Camera Logo
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
