Question about Samsung SC-L906 Camcorder
No pic or sound when recording
I switch the position from off to camera then I press the red record button, I can hear the mechanism it sounds like its recording like usual but then when I rewind the tape and press play on the player mode I see nothing but verticle colored lines then snow at the point where nothing is recorded tried listening for sound but heard nothing at all. Do I need a new camera? I've only used this camera like 5 times during the first year and only had it for 2 years. Is this also something normal for these type of camcorders.
  • 1 more comment
  • kakali Nov 12, 2007
    With power switch ON in Camera mode; either on LCD screen or Viewfindler except display no picture could be seen ( both in easy or custom feature) While recording; it appears that recording is in process; but nothing happens except sound gets recorded without any video picture.
    Further battery charging level display is not appearing at LCD screen display.
    Will appreciate help to resolve this issue
  • Anonymous Dec 13, 2007
    want to know service center in mumbai?
  • zapata22 Feb 22, 2008
    try to rec but nothing no sound or pic what do i do
  • 116 Answers
Please get a Hi 8 cleaning cassette and run it in the camera for a few seconds. you may have to do this several times for the head to be completely cleaned unfortunately for Hi8 you will not hear the sound when there is no picture on playback.
Posted on Sep 23, 2009
No audio (can't hear and can't be heard)
Is ther ea built in microphone on camera if so, down at the time double click the sound icon, goto options then properties then recording, in the drop down menu pic usb device or what ever looks liekthe camera. and press ok. goto options again and if it has addvance higlighted click it and then turn up mic and click advance button and give it some mic boost.
also goto cotrol . start settings control panel. goto sound and audio devices, click the audio tab and make sure this camera is selected as your recording device. press apply then ok and try again. hope this helps in some way
Dec 03, 2009 | HP USB Web Camera
Handycam CCD TR517 Doesn't record
These models have a switch for 3 different modes of record. one where you press the red button once, one for having to hold the red button in and a 5 second record feature, check this mode. also check and make sure the tape you are using did not have the record save switch slid into record save position..
Jul 20, 2009 | Sony Handycam CCD-TR517 Camcorder
Cant record
Set that switch to Camera to record live view. Press red button to start recording and press again to stop recording.
Apr 17, 2009 | Sony Handycam DCR-PC110E Mini DV Digital...
Marantz pm 7200 integ.amplifier
Dear Sushant,    I do not think your use of an equalizer has caused any problems.  I will explain the proper use of the source/direct button.  This button's function is to monitor the output of a recorder connected to the record outputs of your amp.  When this button is pressed on the sound going to the speakers comes direct from the "source" (cd, radio tuner, phonograph etc.) when in the off position you can monitor the recording of whatever source is being recorded via the tape deck.  This switch must be off to record through the amps record outputs.    To test this, put a blank tape in the tape deck, choose the source as phono and place the dec in record/pause.  With the source direct button pressed on you should hear a change in volume when moving the amp's volume knob only.  When source direct is off you will be able to hear the output of the tape deck, so adjusting the tape deck's record level will also affect the volume coming out of the speakers.  more record level in/ more level out.!    Below is copied from page 9 of your user operation manual for Marantz's explanation of the source/direct button.  image.tiff
best of wishes, Michael Mittelsdorf
Jan 05, 2009 | Marantz PM7200 2-Channel Amplifier
Cannot operate svr-925 digital recorder, need manual
How to Record:
1. Make sure HOLD switch (on side of unit with pocket clip) is set to off position (slide to right is off - to left would be hold)
2. For best results set unit with mic(rophone) which is on top of unit toward sound source and press REC/STOP button (Top button on front of unit just below LCD display). Recording will begin and will be indicated on LCD display.
> Red Record LED will be on and the message number, recording time will be displayed on the LCD.
3. To stop recording, press REC/STOP button one time.
* If no other buttons are pressed within 1 minute at stop position, it will power off automatically.
4. Pause during recording by simply pressing MODE/PAUSE button- press button again to resume.
There is a Voice Operated System (VOS) Recording button on left side also. You can record with voice activation to conserve recording space but I have found that you lose a portion of the recorded sound as it activates and if there is no sound for a very few minutes the unit powers off and you will get nothing further recorded. I recomend just keeping VOS in off position.
5. To erase a recording: Select the message number you want to erase and while it is stopped (the message number will appear in LCD with the length of recording showing also)
Press and hold the ERASE button until the LCD begins blinking "ERASE" then, while it's blinking simply press the erase button again and the recording will be erased.
6. To play back a recorded message find your message by "toggling" the switch on the right side of the unit that says INDEX. That switch is the fast forward/reverse play etc. To Play simply push the switch in. This button/switch takes a little practice to use but the Play portion is straight forward. Use the front buttons to pause and stop during playback.
Hope this helps.
Jan 04, 2009 | Sims SVR-S825 Handheld Digital Voice...
I'm having a problem with the sound. Simply put, when taking video my Olympus 570UZ doesn't record any sound. I've looked at the manual and read about silent mode etc... but even checking the settings it...
Put in on the video mode,Then press the menu button scroll through till you see a microphone pic this will be in the off position enable this in the on position it will now work you have to do this every time you shoot a video.
Jun 26, 2008 | Olympus Camedia C-150 Digital Camera
A properly functioning camcorder will report this if it has both a card for recording and a tape mechanism for recording, with a switch set "in card position" when you press the movie mode record button. If you have a camcorder like this, look for a button marked "photo" that is used specifically for snapping still photos.
May 18, 2007 | Canon MV530i Mini DV Digital Camcorder
Does the L410 do audio recording?
Videos with sound is possible or you can record sound memos as well
Recording and Playing Sound Memos
You can record and play back sound memos for your photos while you view them on the LCD screen.
1. Turn the Mode dial to playback mode.
2. Press the MENU button. Playback Menu 1 is displayed.
3. Select Sound Memo by using the u d buttons, then press the r button.
4. Press the OK button and then start recording.
5. When you are finished recording, press the OK button. You can play or delete the sound memo or record
a new memo.
6. Press the MENU button twice to exit the menu.
When you play back a photo that includes a sound memo, the icon appears on the screen. Press the OK
button to play the sound.
You must have at least one photo saved to record a sound memo.
Sep 13, 2005 | Epson PhotoPC L410 Digital Camera
Playing MPEG's
* The MPEG Playback function works in M. PLAY mode only. * You can play moving picture images on the Memory Card. * To hear sound during MPEG4 playback, you must hook up to a PC and listen to the PC's speaker. (You cannot hear it from the speaker on the camcorder or a TV) 1. Set the mode switch to MEMORY CARD position. 2. Set the power switch to PLAYER mode. 3. Press the MENU button and turn the MENU DIAL to highlight MEMORY. 4. Press the ENTER button to enter sub-menu. 5. Use the MENU DIAL to select MPEG4 from the sub-menu. (M. PLAY SELECT) 6. To exit the menu, push the MENU button. 7. Using the (FWD) and (REV) buttons, search for the moving picture that you want to playback. 8. Press the PLAY/STILL button. The moving pictures recorded on the MEMORY CARD begin playing back.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
How Do I Make An MPEG Recording?
You can record video with audio onto the Memory Card. Follow the instructions below. Recording moving pictures onto a MEMORY CARD 1. Insert a Memory Card into the slot on the camcorder. 2. Set the mode switch to MEMORY CARD position. 3. Set the power switch to CAMERA mode. 4. Press the START/STOP button, the images are recorded on the MEMORY CARD in MPEG4. * You can record 10 ~ 20 seconds continuously. * You can record a still image on the Memory Card by pressing the Photo button instead of the START/STOP button. 5. Press the START/STOP button to stop the recording. Notes: * Moving images that you recorded are saved in *.asf file format on the Memory Card. * The moving picture images on a Memory Card are smaller size and lower definition than those on a Tape. * The sound is recorded in mono. * The following functions cannot be operated in M.REC Mode. - DIS (Digital Image Stabilizer), Digital Zoom, Fade, Program AE, Digital Special Effect, Slow Shutter. * Don't insert or eject a tape during Memory card recording as it may record noise. * Don't eject the Memory Card during recording as it may break the data on the Memory Card or the Memory Card itself.
Samsung SC-L906 Camcorder Logo
63 people viewed this question
Top Samsung Video Cameras Experts
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
