Question about Garden
Homelite htc 12 wont start - Garden
2 Suggested Answers
SOURCE: homelite htc-12 tiller starts but tines won't turn
No I don't need any help with this problem. I oiled it well and it broke free and works fine now
thank you
Posted on Feb 18, 2009
Homelite htc 12 tiller.. motor runs ok but tines wont turn under load free wheeling they turn but under load no clutch?
Hi bh1149...
You have bad gears on the inside of the tiller gear box...
I had this same problem with mine.
You will have to take the gearbox apart in order to know what parts are bad.
Be sure to check the lube more often when you install the new gears/parts.
Go to the following website and order your parts.
Please take time to rate me
http://www.ereplacementparts.com/homelite-parts-c-18807.html
Sep 08, 2011 | Homelite Consumer Products Tiller...
I have a homelite htc 12, Its starts fine but when I speed it up it stalls and wants to dye. how can i fix this ?
Check tank filter first, should be easy to blow threw. Cut wire from clothes hanger, 8 to 10 inches bend hook at one end, reach in tank pull fuel line out of tank remove filter. replace if needed.
Sep 01, 2011 | Homelite Garden
Homelite tiller htc-12 carb adjustment How to adjust carb
I would like to refer you to an excellent tutorial by one of the major 2-stroke diaphragm carburetor manufacturers. This will tell you how to adjust and " tune " that carburetor.
http://www.zamacarb.com/tipspage.html
May 05, 2011 | Garden
Homelite starts with strarter fluid and then stops
Does the pumper bulb fill with fuel when pumped? I had a similar problem with a Homelite--which turned out to be the location of the carburetor lower-chamber gasket. The diaphragm needs to go to the carburetor body (pin inward), then the gasket and cover plate. Go to:
www.drystacked.com for a 12 page PDF document on Walbro carburetor theory, troubleshooting, and repair. Hope this helps!
Mar 29, 2010 | Homelite ZR10926 16" Chain Saw
No high throttle
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwill need to disassemble the carburetor and spraywith carb.cleaner. Make sure the small screen is free of debris.(Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals canbecome blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Jun 18, 2009 | Homelite Consumer Products Tiller...
Looking for a primer pump for Homelite htc12 tiller
Hi, I live in cedar rapids, Iowa. I just bought a primer bulb for my htc-12 homelite tiller. You should be able to order as many as you need, but I don't have the part #. Find out what the part # is and call this # 1-319-393-0443. They have 2 sizes, the bigger one is for the chain saws, the small one is for the tiller.( they have both) Carefully pry the plastic band off the primer bulb, press the new bulb through the band, then go get a tube of permetex weather strip adhesive ( orange box, black adhesive). Don't buy any other brand!. Lay a thin bead around the base of the bottom of the ring, press into place and let dry for a couple of hours. This adhesive works on almost any thing, and is not affected by gas, oil, or anything.
Apr 24, 2009 | Homelite Consumer Products Tiller...
Tines won't turn.
Sounds like you hit something (like a rock or a big root) to make it Stop suddenly and smash one of the gears in the housing, The shaft that runs through the housing has a brass gear that is easily damaged when it comes to a sudden stop from hitting something. Snow blowers are famous for this problem.
Apr 17, 2009 | Homelite Consumer Products Tiller...
Homelite htc-12 tiller starts but tines won't turn
thank you
Feb 17, 2009 | Craftsman 8.50 Torque Rating Dual...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
