Question about Garmin GPS
Garmin Rino 665t will not turn on anymore, installed new batteries, tried USB still nothing
SOURCE: Magellan Explorist 500 LE Power
eXplorist units have also some hidden and service functions. Like, if unit is off, you can to press:
- IN + PWR - to full selftest of unit (screen test, keypad test, NMEA test)
- OUT + PWR - to serial port test
- ESC + PWR - to burn-in process
- LIGHT + ENTER + RWR - tp uploading of new firmware
- NAV + PWR - to call Service Function window (see below)
- NAV + MENU + PWR - to force power off, equal remove batteries.
- GOTO + OUT + POWER - clear memory and set all settings as default.
IN + PWR helped to power up my unit.
Posted on Nov 15, 2008
  • 4090 Answers
SOURCE: the new GARMIN 255W can not be detected by computer
take it back to seller for replacement or repair
Posted on Jul 06, 2009
MicroSofty
  • 75 Answers
SOURCE: Garmin Rino 530 radio noise even with squelch turned up. Hissing
Are you carrying a cell phone with you at the time? A cell phone can interfere with these units. You may want to call Garmin to ask questions on this problem. They are very helpful and professional.
Posted on Dec 31, 2009
  • 638 Answers
SOURCE: Electrical burn Garmin Rino
I would suggest sending it to Garmin for an estimate of repair. We have no way of knowing the damage that has been done.
Posted on Apr 15, 2010
  • 638 Answers
Send it to Garmin with a letter detailing what you did and ask for an estimate of repair.
Posted on May 20, 2010
How do I get a new battery for my Garmin Rino 530 HCx?
buy one :
https://buy.garmin.com/en-US/US/shop-by-accessories/batteries/lithium-ion-battery-pack-rino-/prod1166_010-10569-00.html
Jul 26, 2014 | Garmin Rino GPS
My rino 655t wont take a charge
That unit has a special charger and harness.
Very similar to the Motorola
The Rino 650 and 655t includes a rechargeable lithium-ion battery. If the battery is not charging, ensure the battery is secure and the device is connected via the included A/C charger. The battery will not charge when connected via USB cable.
May 02, 2014 | Garmin Rino 655T Topo Gps 2-Way Radio
I've got a pair of Garmin Rino 110 that we use when outdoors. Recently, with full batteries and clear skies in the desert, not surrounded by trees, mountains, buildings, etc... both of the Rino 110s...
  • That RINO should have no issues picking up satellite signals in the conditions you were in. If you were inside a building I may buy it but not in an open desert. Sounds like they are feeding you a line to me. I might try to get my money back on that one. One thing is for sure, you were in about the best conditions for using that unit. If it failed you then, it will more than likely fail you when your life may rely on it. It would seem that a different GPS/GMRS unit will be necessary to give you that security.
Regards, Tony
May 10, 2011 | Garmin Rino 110 (14 Channels) 2-Way Radio
Garmin Rino 110 Posted by nightjar on Jun 29, 2008 My two 110's have same problem. With two new sets of different brand NiMh rechargeables the problem still exists. Both units get warm and flatten the...
Re : " Both units Garmin Rino 110, overheat and flatten the batteries within 2 hours"
That is a factory defect related to a bad contact inside the unit.
If you contact garmin and insist to talk to a supervisor (second line) you can have both Rinos replaced.
Ensure it is not a bad batteries problem first testing a replacement battery, both batteries may have deteriorated at same time.
Buy first a replacement battery at Garmin eTrek, Rino 110/120 NiMH Battery,
If that does not solve the problem call Garmin:
See: Garmin | Contact Us
Feb 09, 2009 | Garmin Rino 110 (14 Channels) 2-Way Radio
Garmin Rino 530 battery wont charge
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Nov 15, 2008 | Garmin Rino 530
Garmin rino 530HCx freezes up
pull battery off to reset or hard boot cpu! Its a computer.
Oct 20, 2008 | Garmin Rino 530 GPS Receiver
Rino 120 Send note
This sounds like the new firmware version may not work on the
older model.
The best solution would be to contact Garmin
Product support at (913) 397-8200 or 1-800-800-1020
Monday - Friday, 8am-5pmCDT or by email at sales@garmin.com
Pat
Aug 09, 2008 | Garmin Rino 120 2-Way Radio
Rino is burning through the batteries.
sounds like the battery needs to be replaced, mine last for days. it may have burned a memory into the battery
Jun 18, 2008 | Garmin Rino 530 GPS Receiver
Garmin 120 will not turn on
i talked with garmin tech today, he said to hold the button below talk, and the wheel and the power at the same time to master reset....it did not work for me but it might for someone else
Apr 03, 2008 | Garmin Rino 120 2-Way Radio
Garmin Rino 130 no Power
There first 2 main thing to check..... the off on switch.... and the fuse. Insie the radio there is a very small fuse.... its a surface mount component fuse... very small. That could be the problem. Also check the contacts on the radio..... if you have a way of connecting the correct voltage directly to the radios power terminals using jumpers I would definatly do it. Your most likly going to have to take the raio apart and and connect the battery to trace the power through it. The small fuse will be one of the first components after the positive power input. If this seems too much..... bring it to a radio shop... they can do all this quickly
Sep 20, 2007 | Garmin Rino 130 (14 Channels) 2-Way Radio
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
