Question about Garden
Spark plug gap for briggs and stratton engine model 461707 plug rj19lmc?
  • 133 Answers
SOURCE: 4 cycle, 5hp briggs and stratton, lawn mower
Try taking off the engine shroud and cleaning the magnets on the fly wheel. Also clean the two little prongs on the magneto. Also clean the end of the spark plug wire. I use fine sand paper or emery cloth.
Good luck and let me know if this helps.
thanks roundo4
Posted on Sep 06, 2009
rwvanlue
  • 486 Answers
SOURCE: Briggs & Stratton 6.75 lawnmower. Won't start.
1) Determined that there is spark?
2) Have you used a type of spark tester?
3) What is the condition of the plug. Brown or dark brown is OK. Black or silver is NOT Ok.
*If you do not have a spark tester,
a) remove the plug, and with it connected to the wire,
b) find a portion of metal around the cylinder that you can ground it on, and then pull the rope.
c) If the plug is black, you may see spark, but you should replace the plug.
*** PLEASE NOTE ; if there is excess fuel in the cylinder or on spark plug,
it can catch fire, so be carefull to cover the hole with a heavy rag so that any fuel
cannot be exposed to spark plug durning test !!!!
Get back with me on how this issue works out.
thanks, rwvanlue
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your local lawn & garden dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
Posted on Nov 26, 2009
  • 23 Answers
SOURCE: engine wont start
go to youtube and type in valve adjustment on briggs,very simple procedure to do.
Posted on Apr 23, 2010
  • 252 Answers
SOURCE: I need to know torque
here is web site for manual
http://www.briggsandstratton.com/engines/support/operators-manuals/?NTT=+461707+0145+e3+
from the top of my head 160 in/lb torque setting
pattern gos top centre , botm left,top left , centre right , top right , centre left , centre right then centre left , then botm right
cheers pauly46
Posted on May 30, 2011
dcurryn601
  • 60 Answers
SOURCE: Need to know the spark
go to Briggs and statton.com
Posted on Jul 25, 2011
What is the spark plug gap for Briggs 20.5 hp
For a proper answer more info is needed. Here's a Briggs site that has spark plug gaps listed. Gap is not hyper critical for running.
.030-.045 will work. The only time I've seen gap matter was when it was too close like .005, the engine wouldn't run.
What is the right spark plug and gap for my small engine Briggs Stratton
Sep 21, 2017 | HP Garden
Spark plug gap
How to Gap a Spark Plug - YouTube
? 2:57
https://www.youtube.com/watch?v=IuW3svdqKZM
Oct 15, 2012 - Uploaded by ChrisFix
How to correctly gap a spark plug. This is a fast and easy video on how to gap a spark plug and spark plug gap ...
FAQ: Find My Engine Spark Plug & Gap ' Briggs & Stratton
www.briggsandstratton.com/.../identifying-the-correct-s...
Briggs & StrattonFollow this step-by-step image guide to locate spark plugs in different Briggs & Stratton engine types. ... Spark Plug Type & Gap Chart for Briggs & Stratton Engines. Now that you've found the part you'd like to replace, you can use the chart below to identify the genuine Briggs & ...
Spark Plug Gap - AutoZone
Dec 15, 2015 | Cars & Trucks
What size spark plug wrench is needed for lawn mower - model # 917.370441?
13/16 for the Champion RJ19LMC, Briggs & Stratton 591868
May 28, 2015 | Garden
BRIGGS AND STRATTON 550 SERIES
Identifying the Correct Spark Plug and Gap
What is the correct spark plug and gap for my engine?
Due to the variety of engine and equipment configurations, your best source for spark plug information is your engine or equipment Operator's Manual. However, the following general guidelines will get you pointed in the right direction.
This guide provides the common spark plug part numbers used in our L-Head and Overhead Valve engines. For information regarding the service/replacement of spark plugs, please visit our Servicing the spark plug FAQ. Please be aware that the size/shape of the spark plug varies depending on engine design.
Briggs & Stratton L-Head Engines
(also referred to as Flat Head or Side Valve Engines)
Sep 29, 2014 | Briggs & Stratton Garden
What is the spark plug gap seting fot Champion RJ19LMC?
.30 is the standard for most lawn mower engines...you might check the "engine specifications" in your owner's manual to be sure.
Aug 22, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Spark plug gap for a rc12yc on 22 hp engine
Gap setting for a Champion RC12YC spark plug is .030
Apr 15, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Spark plug gap fpr a
Typical old Briggs flathead "L-Head" engines require about a .030" plug gap.
Jun 05, 2010 | Briggs & Stratton Garden
Garden Logo
73 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
