Question about Husqvarna Garden
Pull cord is stuck on my husqvarna CRT 52 tiller
  • 2712 Answers
SOURCE: crt or srt tiller?
* CRT or SRT -- These are two terms you will see on rear-tine tillers only. o Counter Rotating Tines are best for heavier duty jobs and for breaking new ground. o Standard Rotating Tines are good for aerating the soil and help propel the tiller forward.
Posted on Aug 27, 2008
landsend
  • 1066 Answers
SOURCE: I just purchased a troy
remove the spark plug.  And pull the cord again.  if the carb float is stuck down or you overfilled the oil you could be hydro-locking the engine.  Check.
Posted on Mar 29, 2009
SOURCE: Pony Tiller (1985). Pull cord does not pull/frozen in machine.
see if the motor turns over pull the spark plug put some lubricant inhole other wise pull off pull cord assembly try turning crank becarfull not tobreak rings moveback and forth little bit at atime if it turns over check pull cord out
Posted on Mar 30, 2009
  • 398 Answers
SOURCE: Pull cord stuck
it sounds like the recoil spring in the "housing" is jammed( or something is broken) youll have to take this apart without breaking it. you may have internal engine damage if it was unusually hot and the pullcord jammed. try using a richer oil mixture for fuel also if you fix the pullcord. hope this helps, keep me posted.
Posted on Apr 24, 2009
  • 115 Answers
SOURCE: trying to put on pull cord on tiller.
you remove the cover, bend three tabs and the wheel will come out. Replace the cord in the manner that it is removed, rewind spring and install wheel, then bend the tabs back down.
Posted on Jul 04, 2009
Where to buy Husqvarna parts for a CRT 50
try going through an authorized Husqvarna dealer or the Husqvarna website.
Oct 02, 2012 | Husqvarna 14" Tiller with Briggs 900...
Husqvarna CRT 650 Tiller gearbox is locked up
first check the linkage rods make sure that its not in forward and reverse at the same time if not you need to open it up to find the problem
Jul 25, 2012 | Garden
My Husqvarna CRT81 Rear Tine Tiller - the rope won't pull to start it. We used it about 2 weeks ago too.It's about 13 years old, but we have been using it quite a bit. I took the rope mechanism off and it...
It sounds like you have a stuck rod or piston. When these freeze you will not be able to crank the unit over. I would recommend a over haul of the engine or replacing the engine
Feb 13, 2010 | Husqvarna PRRT850X 960920015 CA 17" Rear...
I have a briggs and startton lawn mower and the
under the pull cord housing is this little arm that pulls out when you pull the cord. Thus, the little arm locks into place on the pulley and turns the flywheel which turns the motor over. The arm inside may need to be greased and worked a bit. Sometimes the springs do fall off
Jul 10, 2009 | Mantis 2-Cycle Tiller
Engine runs backwards?
Starter clutch needs to be cleaned or replaced. What is the model # and type # on the engine
May 17, 2009 | Husqvarna Garden
Pull cord stuck
Apr 18, 2009 | Mantis 2-Cycle Tiller
I just purchased a troy bilt bronco crt tiller. Put oil and gasoline in. Pulled the cord. It started. Ran maybe 15 or 20 seconds and stopped. When I tried to start it again, the cord would not...
Mar 29, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Garden Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
