Question about Minka RC223 Remote Control
Change frequency rc223 ceiling fan remote - Minka RC223 Remote Control
  • 26 Answers
Here is the maual for that remote.
http://www.minkagroup.net/sites/default/files/product_manuals/RC223-English.pdf
Basically you will need to set the dip switches on both receiver above the fan, and on the remote handheld.
Note the suggested answer from ercupa190 (ernesto) is not correct as you're asking about remote controls and not house wiring standards in different countries.
Posted on Oct 26, 2014
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: Change frequency rc223 ceiling fan remote
sir the frecuency only can be alter if the fan has transformer inside TAP by 50 or 60hz. Otherwise, you must consult to the factory, if they have some transformer for installing with the TAP for o.k 60hz or 50hz whatever you will use.
God bless lyou
Posted on Aug 03, 2012
God bless lyou
Aug 02, 2012 | Minka RC223 Remote Control
Need to program Hampton Bay Ceiling fan remote control CHO88T7030T, HELP!
Change the battery. This is the first step when troubleshooting a ceiling fan remote. The easiest fix to any remote control problem begins with battery replacement. A 9-volt battery is needed to operate all Hampton Bay ceiling fan remotes.
Check the light switch used for the ceiling fan. The light switch found on the wall must be in the "on" position. This allows the ceiling fan to be operated by remote control
Re-program your remote. If battery replacement fails to get your remote working again, try to reprogram the remote. Open the battery cover you will see 4 dip switches. These switches must be set to the same position as the receiver on the fan. Use the screw driver to move the dip switches either up or down.
Follow the previous step to change the frequency if the ceiling fan is randomly turning on or off. Other electronic devices such as garage door openers can interfere with the ceiling fans receiver, causing it to randomly turn on or off.
Sep 10, 2011 | Televison & Video
I moved into a house with 2 hunter ceiling fans with remote control. Both are set to the same frequency. Where is the transmitter located on the fan to change remote frequency setting?
Typically it is directly under the very top cover. it is slide under the hanger on the ceiling. Just remove the 4 screws and drop the cover and it should be there.
Apr 27, 2011 | Hunter Heating & Cooling
Need to reassign remote frequency for a SMC OJ44V Ceiling Fan
As long as you have the pins in the same position on both the remote and receiver, everything should work fine.
Jan 06, 2010 | Casa Vieja Prelude White Ceiling Fan
Have a hunter ceiling fan with light kit and remote. Lights have started turning on and off by themselves ?
This is likely caused by stray frequencies in the neighborhood. Change the frequency on your system and see if the lights go off less frequently.
See the manual for the remote system. You'll need to go into the top of the fan and change some little switches (dip switches) and set the same frequency on the transmitter (what most call "the remote").
Charlie
Aug 20, 2009 | Hunter 52" Ceiling Fan With Light And...
I just had a stereo put in with a remote and now my fan won't come on. I suspect the remote control setup for the stereo has done something to the fan????
The RF (radio frequency) can interfere as you suspect. Most fans allow you to change the frequency that it's programmed to. Check your mnual to see if you can change yours.
Jul 13, 2009 | Hunter 52" Ceiling Fan With Light And...
Ceiling fans on same frequency
There should be dip switches in/on both the remote control and the ceiling fan that enable you to change the control frequency. The only thing that you have to ensure is that the two components are set to a matching frequency.
The switches in the remote are located in the battery compartment just above the batteries. Remove the dome on the ceiling fan and you should find the switches for that unit. Just compare the two and match whatever changes you make from one unit to the other.
Originally answered by d0n0r in this question
May 25, 2009 | Universal Remote Control Hampton Bay...
WE LIVE IN A CONDO AND SOMEONE IN THE COMPLEX HAS A hAMPTON bAY CEILING FAN WITH A REMOTE JUST LIKE US. wE MUST BE ON THE SAME FREQUENCY AND WHEN THEY TURN THEIRS ON IT WILL MAKE OURS COME ON WHEN WE HAVE...
Feb 18, 2009 | Universal Remote Control Hampton Bay...
Mind of it's own
your remote and fan is set to someone elses frequency by little toggle switches
you will have to remove fan to where it hangs make sure power off
find the remote sensor inside electric case at ceiling in the fan
this is a dip switch to control frequencies
09c4f2f.jpg you will see something like this adjust the dip switches
means change the dip switch for fan
then on remote open the remote battery pack find the dip switch in there
change those dip switches to the same as in ceiling fan
put fan together and turn back on power
your fan should now not pick up the other frequency of another remote and they have a span of about 50 yards to pick up frequencies
Jun 07, 2008 | Hampton Bay 24002 Ceiling Fan
Minka RC223 Remote Control Logo
88 people viewed this question
Top Minka Televison & Video Experts
Are you a Minka Televison and Video Expert? Answer questions, earn points and help others
