Question about Kenneth Cole Kc1850 Touch Mens Watch
Setting the Kenneth Cole KC 1850 - Kenneth Cole Kc1850 Touch Mens Watch
SOURCE: Kenneth Cole KC3754
www.genevawatchgroup.com will come up on google, I got it to come up today, 20 Nov. '07 and clicking on the first heading that came up, "geneva Watch Groiup" I got on and was able to print out a repair service sheet for Kenneth Cole
Posted on Nov 21, 2007
SOURCE: Kenneth Cole Reaction watch date set problem
I just dug my watch out after not wearing for a few years and had the same problem. There is an easy way to adust this watch's time and alarm, basically one way to enter both.
1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours). You can only move minutes, hours, etc forward, no way to move backward. You will start off with the second display blinking, probably skip that unless you need to adjust seconds. Depress the upper right button to shift to the next option (minutes) and you will see the minute display blinking. Adjust the minutes by depressing the lower right button. When finished depress upper right button to move to next option (hours) depress the lower right button to move the minutes/hours/month/date forward as necessary, when you finish just press the lower left button again and it pulls you out of adjust mode and you are back in regular time viewing.
I had to post this because I've had this problem in the past and it killed me. Its kind of intuititve after you get into the adjusting mode by pressing the lower left button- remember, initially it will put you into adjust alarm mode, but press again and you will get into adjust time mode.
Posted on Nov 12, 2008
escapement
  • 2334 Answers
SOURCE: Kenneth Cole Wrist Watch unable to remove link
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Hope it'll help.
Regards
Arthur
Posted on Dec 17, 2008
escapement
  • 2334 Answers
SOURCE: Cracked glass on the dial
I have no idea how the things work in India, but any Kenneth Cole dealer shop must be able to sort your problem ( at least it is worldwide experience ). So, visit your nearest Kenneth Cole store and ask for help.
Do not forget to rate, please.
Posted on Feb 06, 2009
  • 8 Answers
SOURCE: Kenneth cole reaction KC1408 changing battery problem
You have to take the back off. If it has about 6 slots around the back, then it screws off. If it's flat, then you can pry it open. If you pry it open, it,s very difficult to get it back on all the way. You may have to get some tools, or go to a repair shop.
Posted on Mar 03, 2009
Kenneth cole kc 1104 I would like black
Certainly, press a $50 and a $20 bill to the monitor and hold it there for 5 minutes. We will dispatch it to you.
Thank you for your order.
KENNETH COLE KC1104 Buya
Jan 09, 2016 | Kenneth Cole Watches
KC 3982 how do I change 24 hr setting to 12 hr AM/PM setting
kc 3982 Hold the top right button, then push once the bottom left button. That should do the trick.....I just got the same watch, Do you know how to change the time?
May 01, 2011 | Kenneth Cole Watches
I am looking for a replacement band for a Kenneth Cole Reaction watch. The model number I believe is KC 1376 and there is another number P93-06. Any help would be great.
Thank you for contacting FixYa.<br /> According to previous customers on FixYa, Kenneth Cole are extremely hard to find and KC company has been of no help or assistance.<br /> I am afraid your best bet is going to be:<br /> <a href="http://www.watchbands.com/">http://www.watchbands.com/</a><br /> Good luck. <br /> Jewel<br /> Please be sure to rate me.
Aug 27, 2010 | Kenneth Cole 1213 Wrist Watch
Where can i get a manual fot the kenneth Cole touch screen watch?
i have not been able to locate downloadable KC manuals. You can try at this link:
http://safemanuals.com/brand-user-guide-instructions-owner-manual/KENNETH%20COLE
Otherwise you can call 1-800-KEN-COLE to see if they can send you the info or email a downloadable version to you.
Good luck..
Aug 12, 2010 | Kenneth Cole Digital Chronograph KC1411...
I have a Kenneth Cole watch (KC 1555 U54-09) and the leather/rubber strap is perished. Whwere to get a replacement?? Can I replace with a Stainless steel strap I am in Seattle,WA now
Call this certified Kenneth Cole watch repair company and speak to the representative. Not sure if they are on the West Coast.
Geneva Watch Group
1800-874-0907
Aug 09, 2010 | Kenneth Cole Watches
Feb 06, 2009 | Kenneth Cole RK5034 REACTION
Watch bands f/ Kenneth Cole
Replacement watch band (f) can be purchased from amazon, take a look here: Amazon com kenneth cole band Watches Women Clothing Shoes Jewelry Wish you best of luck. Cheers
Jun 22, 2008 | Watches
Kenneth Cole Kc1850 Touch Mens Watch Logo
Top Kenneth Cole Watches Experts
Ansel Alberto
Ansel Alberto
Robby Otts
Robby Otts
Level 1 Expert
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
