Question about Caitlin Cary - While You Werent Looking
While driveing at high speeds with a load on my truck started to make a rolling movement insted of just up and down after hiting a bump on hwy.
  • 46 Answers
Sounds like either a shifted belt in the tire, or a broken suspension part. What year/make/model?
Posted on Oct 20, 2013
Vibration from somewhere when coasting at high speed
Check centre bearing on tail shaft, for excessive up and down movement.
Aug 28, 2014 | 1994 Ford F150 Styleside Supercab
What would cause a knocking noise under car during movement?
am I reading this right it doesn't do it over bumps,steering
or braking but when you are driving, could you give more info like does it only happen when driving or turning corners, high or low speeds or both thanks in advance
Jul 27, 2014 | 1999 Peugeot 406
Husqvarna too slow when mowing
Some self-propelled mowers include a speed control, but sometimes it may seem that no matter how you adjust it, the mower just creeps along at a snail's pace. Most likely this isn't a mechanical malfunction, but an adjustment is probably needed.
Very tall or thick grass can bog down a self-propelled mower, but adjusting the height of the blade may allow it to roll through and cut the grass at normal speeds. If the blade is low, the amount of cutting required may slow down the movement of the entire mower. The frame of the mower may also stick in the high grass. Raise the blade little by little until the mower rolls at the appropriate speed. Going up hills may cause a similar response.
It's possible the drive belt on the mower can slip. Inspect this part to see if it is loose or cracked, and replace the belt to restore power.
May 08, 2012 | Garden
2005 Escape hesitates on HWY driving
change the ignition coils and sparkplugs. Im assuming your vehicle is over 70K???
Aug 20, 2009 | 2005 Ford Escape
1974 johnson outboard motor 25hp stalls when hiting high end
Not familiar with that specific motor but had similar vintage smaller HP Johnsons. From my experience it sounds like it could be that the high speed carb adjustment is too lean. What I would try is running the backing off the high speed screw 1/4 turn to 3/4 turn, then test. If works better, screw back in in 1/8 turn increments until the problem recurs, then back out 1/4 turn and leave it there.
Jun 30, 2009 | Sport & Outdoor - Others
Rear suspension left side makes a knocking sound while driving
There are a few suspension parts that can cause knocking noises. Such as swar bar loose, strut mounts going bad. You should really have a shop do a complete suspension check.
Jun 22, 2009 | 2005 Pontiac Montana SV6
Suzuki samurai started shuttering under load.(driving hwy speeds) Seemingly from the transfer case, the stick vibrates. Could a short drive in L4 with the hubs in "Free" be the reason?
Check the universal joints in the jackshaft between the gearbox and the transfer case.
Driving a short distance in 4low with hubs unlocked shouldn't do any harm.
May 09, 2009 | 1989 Suzuki Samurai
Chrysler Voyager Diesel W reg - creaking noise over speed bumps
Lower Control arm Bushings, I have Sprayed them down with PB Blaster and they *******
I Know its a Unconventional fix but it worked on mine
Jan 13, 2009 | 2003 Chrysler Voyager
Caitlin Cary - While You Werent Looking Logo
44 people viewed this question
Top Precision Series Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Precision Series Vehicle Part and Accessory Expert? Answer questions, earn points and help others
