Unlock Dvd Player Code LG689D - Televison & Video
Unlock code needed for LG HT904SA DVD player
These WEB sites may have the code for your player.
Unlock DVD Players - Region Free Code
www.dvdexploder.com/ www.download-info.com/dvd/index_new.htm
Jan 08, 2013 | Televison & Video
Unlock code
can u tell if the dvd movies are in a particular format
Apr 06, 2008 | Panasonic DVD-S77 DVD PLAYER
Unlock the DVD player
follow the steps. God bless you
    • 1 Find the unlock code for the specific make and model of your DVD player. Unlock codes for more than 6,000 DVD player models can be found online at Videohelp.com (see the Resources section).
    • 2 Write down the unlock code for the make and model of your DVD player. The unlocking process can be as simple as a short number code, but on some DVD player models, the code is a complex series of numbers to enter and buttons to press.
    • 3 Turn on your DVD player. Remove any DVD that is in the unit.
    • 4 Enter the unlock code for your DVD player exactly how the code is listed. On some units, enter the code by using the remote for the DVD player. On others, you may need to enter the code on the unit itself or with a combination of the remote and the unit.
    • 5 Turn off the DVD player after you enter the code. When you turn the DVD player back on, the DVD player should be decoded and able to read DVD discs from any region.
Nov 13, 2012 | Televison & Video
Hi, I want to unlock my DVD player!! Can you help me ?
Hello
Find the unlock code for your Sony DVD player model. The DVD Demystifiziert and Video Help websites both provide unlock codes for Sony players that can be unlocked and made region-free. To view the code for your DVD player, click on the model of your DVD player in the Sony hack list on the website.
Perform the tasks included in the unlock code. For most Sony models that can be unlocked, the unlock code is not as simple as pressing a few buttons. You may need to open the tray on the player or power the unit on and off multiple times as part of the hack.
Turn the unit off and then on again after you have entered your unlock code, even if the code doesn't include this step. Once you power the unit back on, it should be region-free and should be able to read any DVD that you insert in the tray.
NOTE: Not all Sony players can be unlocked to be region-free. According to the DVD Demystifiziert page, no unlock codes are available for Sony models DVP-NC85H, DVX-11A, SLV-D980P and SLV-D500P.
Keep in mind that unlocking a Sony DVD player almost always voids the unit's warranty.
Oct 10, 2010 | Sony BDP-S300 Blu-Ray Disc Player
Unlock region code for JVC dvd player
if your dvd player is not region free it will not play us dvds it will only play burnt dvds and dvds from your region unless u buy a region free dvd player
there is no region free code for your dvd player
Apr 04, 2009 | JVC XV-E100SL DVD Player
Philips Portable DVD Player PET 730/98 Unlock Code Needed!
Philips PET730/05
Using remote control
Setup
Down arrow
Down arrow
Right arrow
212225 (you won't see anything!)
Left arrow
Down arrow
should now show region code box
Enter 0
Setup to save
Jan 09, 2009 | Philips PET724 Portable DVD Player
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Unlock region code
Keep Tray in eject position
Press Setup from remot
Go to preference page
Press"138931"
Using Navigation Key chane region code to "0"
Press "OK"
OR
open tray
press 98790
Jun 25, 2008 | Philips DVP3040 DVD Player
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
Unlock region codes
Hi All,
I am looking for the region unlock code for a Sony portable
DVD player.Model number DVP-FX720
Jan 12, 2008 | Insignia NS-PDVD8 Portable DVD Player
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
