Question about Alpine MRV-F345 Car Audio Amplifier
VLT Error Hi everytime i connect my amp to my 12V battery or a 13.8V AC to DC power inverter my amp displays VLT which is supposed to indicate too high a voltage but the display still reads around 12 volts or 13.8 volts when on the inverter?? plz help
  • 55itot9598tt Apr 20, 2008
    yeh same to mines help whats wrong with it
  • mikey_rage Jun 21, 2008
    I also have the same problem mine just flashes up VLT then shuts down straight away in the car or on a 12v battery
    may need to contact alpine
Change battery never worked i put it in my friends car and is still the same
Posted on Apr 22, 2008
Did you get your amp fixed i have same if you can
Posted on Apr 21, 2008
Chenge battery
Posted on Sep 29, 2007
3000 watt eliminator with OLP and LUP CODES any Ideas
Assuming you have a 12VDC In 120V AC out 3000W inverter.
LUP indicates battery voltage is low, so firstly make sure:
1. You 12V battery is good, it's large enough a minimum of 75AH and probably much larger is recommended and it's fully charged.
2. Verify you are using the correct size copper wires from battery to the Inverter DC INPUT(s). If you keep wire short the wire size can be smaller, but if the DC input wires are longer then you will need to use thicker copper wires.
At MAx load you would be taking 250 AMP from battery, so for a 5% Volatge drop of .6 V for a 10 ft length of cables from battery to Inverter you would need to use a 1AWG copper cable.
OLP is a overload condition, which means you may have to many high powered AC powered things connected to the Inverters AC outlets or maybe something that has large start up surge, ie devices large electric motors.
Or it could be all due to a faulty Inverter.
Oct 22, 2016 | Eliminator Electronics - Others
Xantrex inverter error codes
This information expands upon the error code information contained in the Link 2000 Owner?s Manual.
E-01 Inverter high DC/Battery voltage shutdown Battery voltage has risen above 15.5 VDC for 12-volt models or 31 VDC for 24-volt models.
E-02 Inverter low DC/Battery voltage shutdown Battery voltage has dropped below 10 VDC for 12-volt units or 20 VDC for 24-volt units.
E-03 Inverter or Charger overtemp shutdown Unit will reset automatically after it has cooled sufficiently.
E-04 Battery overload Caused by excessively discharged batteries. See section in inverter owner?s manual titled ?Charging overdischarged batteries.?
E-05 AC Backfeed AC power from an outside source has been fed to the AC output of the inverter. Potentially damaging to the unit. Disconnect incoming AC power and correct the situation.
E-06 Electronic Overload Inverter overload caused by too large a load or a short circuit. Reset by cycling power switch or connecting incoming AC power.
E-07 Triac control error Triac has overheated. Shut down unit and allow to cool.
E-08 High battery voltage shutdown during charge mode Check all charging sources for proper voltage. Reset by cycling the power switch.
E-09 Spare
E-10 Link 2000 de-powered This indicates that power was removed and restored to the Link 2000.
E-11 Spare
E-12 Battery #1 voltage sense leads open Blue wire is not connected to battery #1.
E-13 Battery #2 voltage sense leads open Violet wire is not connected to battery #2. E-14 Inappropriate Charged V selected for sensed voltage This value defaults to 13.2 for a 12-volt system, 26.4 for a 24-volt system. If this setting is above the voltage limits of the charging source, this error code will be displayed. Please refer to page 9 of the Link 2000 Owner?s Manual
E-15 Incoming AC polarity reversed Check incoming AC wiring for a reverse polarity condition.
CCC Indicates battery being charged. Displayed when Time remaining is selected. LO BAT More than 50% of declared capacity of battery 1 or battery 3 has been consumed.
OL Meter reading out of range U xx Designates a user setup CEF. Please read the sections pertaining to CEF on pages 19?22. A Designates Alternator output current on a Link 2000-R. is a number from 1?200. P Indicates Percent of charge mode selected. is a number from 1?100.
on May 14, 2015 | Xantrex Technology Electronics - Others
How do I remove electrical interference on my dvd recorder?
Hi David
You need to figure out how the interference is getting inside.
Look at the external connections.
HDMI Cable or Perhaps the Power Connector.
Noise from the power cable would be most likely.
A Ferrite Bead can often be clipped onto power lead to dampen electrical noise. Electronics supply stores have these.
If an AC to DC external box is used. What is the required DC input to your DVD ?
For example if the AC is dropped to 12v DC and then plugged into player via a small connector. You could get your own connector and supply from a 12v vehicle battery. Be careful to maintain correct polarity to tip of connector.
Use a cheap multimeter to check voltage & polarity.
Substitution....This would prove that the noise source is from the Power Supply.
Apr 07, 2015 | HDCVT SCART/ HDMI to HDMI Video Converter...
I mistakenly connected energy source at the AC inverter output .Inverter is 5KVA cyberpower inverter.After correcting the connection, It cannot switch from DC to AC( fault signal is displayed on its...
It's shorted out, either replace the part or buy a new one.
If you need UPS, Surge, or Power Related help don't hesitate to contact me!
Daniel • • Power & Systems Innovations • 800.260.2259 •
Sep 24, 2013 | Cybernet Systems CyberPower DC to AC...
Alpine 345 amp flashes VLT
If the fault occurs even with the engine switched off , there is no reason of excess voltage but if the inverter DC-DC convertor within is faulty it can cause this error.
You can remove the covers and check for any visible signs of capacitor leak or burning. Unless the circuits are isolated the fault cannot be traced or confirmed. It can be a short in any of the regulators or drivers but has to be confirmed.
Dec 23, 2011 | Alpine Car Audio & Video
No power to refrigerator unless it is hooked up direct. Think it is 12 volt dc supply connection. Could this be the problem only able to get partial # on part c1c 5122 is all we can read.
there is an inverter built in to the power supply that converts dc to ac to run the compressor if the fuse is ok. you will have to replace the supply . or for traveling you could hook up a small inverter to opperate the fridge while traveling this could be connected to the 12 vlt line for fridge power as it will not take much more power than the the fridge needs.
Feb 21, 2011 | Thetford Norcold® Model DE0061
175 watt 350 peak inverter 12v dc to 110 ac need a fuse but don't know what size to use. old fuse is missing.
15/16 amp would be recommended.
You could to try a 20 amp, but you will risk overheating and the possible failure of the vehicle circuit fuse.
Jan 30, 2011 | NexxTech 175W Power Inverter
Q7 12V socket Inverter Wattage Question
no you need to know the wattage of the item you are trying to power. To find the wattage of the item you are trying to power is simple. Some will say directly others will give you the amps (ie. .5amps, 1.2 amps.) you take the amps and multiply it by the volts that it says. All this info is on the item you are trying to power with the inverter. The answer is what it will take to power that item. example .5amps x 240v = 120 w so in this instance you would need an inverter that would produce at least 120w so in this case the 150w inverter would work. Good Luck, have a grt day
Apr 01, 2010 | 2009 Audi Q7
REM input on Car power amps
you should connect it to the 12v positive of the power supply, maybe install a switch in line between the amp and power supply.
May 14, 2008 | Car Audio & Video
Alpine MRV-F345 Car Audio Amplifier Logo
264 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
