Question about Samsung HP-R4262 42 in. Plasma Television
Plasma TV PS-42Q7HX/XSJ
Hi, My Plasma TV is 7 mnths old, i use a harman cardon home theatre, I recently noticed that there is a row of about 10 pixels flashing on the bottom of the right hand side of the screen, these pixels appear only after you switch on the unit for about 2 hours, they are coloured in nutral colour as normal light. If you reboot the TV or change from AV1 to AV2 or vice versa, this problem disapears for a while and appears again as mentioned above. The subwoofer of the home theatre is in the same posision of the problem but the woofer is a meter aways. I tried changing the satellite receiver and the cable, or playing a DVD instead of TV, but it didnt help. Could you please help. Regards.
Hey, i had this problem with a CRT television once. My subwoofer would cause the same issue in that TV. There is a rather large magnet in the subwoofer that creates a field that will mess your TV up if it's too close to it. not sure if the same applies to the plasma, but i'd definately move it more than 5 feet away from the screen. sometimes it takes 24hrs or so for the tv to repair itself after doing so. hope this helps.
Posted on Jan 18, 2008
We have a Harman Kardon home theatre system that is between 5-10 years old. The subwoofer has SUB-TS5 on the back and is currently not working. We noticed in the past when watching an action movie that...
The sub-ts5 had glue that went conductive on the circuit board and when it is removed unit should work again a good tech should be able to fix this for you
Feb 04, 2011 | Harman Kardon Audio Players & Recorders
Lg plasma 50 trying to configure hdmi to play tv sound through panasonic home theater.
You will only be able to use the HDMI if you tv has an output for it(for other things beside built in DVD player of home theatre). It can not be an input. If you want everything that plays through your tv to then play through your home theatre the easiest way is to use white and red composite audio cables(some call them rca cables) More than likely you tv will have this output.They will go from the output of the tv to the input of home theater. If your home theater has a Blu-ray or DVD player you need to use the HDMI from home theatre out to in on the tv. If you tv happens to have and OUTPUT for fiber optic audio or digital coaxle audio on your tv and your home theatre has same but as inputs that will work as well with a better quality sound. However this is very rare.
Dec 13, 2010 | LG 42PB4D 42 in. Plasma HDTV
Hi I have just purchased a Panasonic Plasma TV and Panasonic home theatre. Everything works well except for I cannot get sound coming out of the home theatre when watching normal TV. I purchased the...
Try running the audio from each video source (NOT the TV, which is an output, not a source) to the HTR digitally so you'll get the best mutichannel sound possible. Then you can turn the TV speakers (assuming it has them) off for hi-end watching.
Aug 15, 2010 | Panasonic Audio Players & Recorders
Ghosting of picture from a Panasonic home cinema system
There must be a fault in the screening of the internal wiring to the scart outlet in the home theatre system. I simply changed the way the player was connected to the TV and the interference disappeared:-
1.) I used the RCA video outlet instead of the scart lead. Picture quality was not compromised. FYI the Panasonic Plasma TV I have has only RGB video input sockets at the back, so I used a scart to RCA adaptor to overcome this problem of connecting old technology to new.
2.) The surround sound when playing DVDs is generated directly from the home theatre system so there was no need to connect the audio from the home theatre system to the TV
3.) I used a pair of RCA leads to connect the "audio out" from the TV to the "audio in"on the home theatre system to provide the option of TV sound through the home theatre system.
Mar 18, 2009 | Panasonic Televison & Video
TV Audio won't come through the Home Theatre Speakers
why it doesn't come. just connect the RCA cable to the output pins of TV and connect them to the input female jacks of home theatre receiver. or if the TV has optical out and the home theatre reciever had optical in. thats the best option. just connect one optical cable to enjoy the 5.1 sound. tell me clear problem if u r nt solved.
kanny_amancha@yahoo.com
kanny-sounds.blogspot.com
Jan 26, 2009 | RCA RT2620 Home Theatre System System
RCA Home Theatre - Tuner problem
you may coldsolder the tuner first before replacing the new one,maybe it can works.
Apr 30, 2008 | RCA TruFlat 27F520T 27" TV
Can't wire up to LG plasma HELP
Ah, I assume you have put rca's from the TV audio out to the Audio in of the Theatre System! Then put the Audio System to Aux 1 / 2 and you should have sound through your Theatre System!
Feb 20, 2008 | Sony DAV-S500 System
Blue tint
This is usually caused by an over voltage on one of the panel voltages, if you open up the set and look at the panel you will find a sticker with the panel voltages on it, if you adjust the VS voltage down about 10 volts it will go away, if it doesn't the adjust the Vscan voltage down about 5-10 volt
Apr 11, 2007 | Samsung HP-P4271 42 in. HD-Ready Plasma...
Samsung HP-R4262 42 in. Plasma Television Logo
78 people viewed this question
Jerry Greenberg
Jerry Greenberg
