Question about Garden
Mower deck belt digram - Garden
  • 10865 Answers
SOURCE: Installing mower belt
The pulley at a wierd angle is the tension pulley. You may get the manual on line for free if you are lucky but not all mower manufacturers are that generous. What kind of mower do u have?
Posted on Mar 31, 2009
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
mickey813
  • 472 Answers
SOURCE: We have a Weatern Auto Wizard Riding Lawnmower.
19c5756.gifHOPE THIS HELPS LET ME KNOW
Posted on Nov 19, 2009
  • 146 Answers
SOURCE: Swisher 60 deck belt breaks after mowing about 15 minutes.
Even though the routing is correct, have you checked that every spindle and idler pulley turns freely? These bearings can freeze up or bind because debris builds up in them. Also, if the bushings on the idler pulleys can wear, causing them to misalign. Keep checking. Also - is the belt snapping clean, or do you see a burnt, worn spot?
Posted on May 28, 2010
Testimonial: "Thank you for your help. The belt is snapping clean. You are correct in your assessment to what the problem might be. We checked all the above and did not correct problem. We put three washers on top of small idler pulley to bring it down and better align routing. Bought heavier belt at auto parts. Believe the bolt head was touching belt where it routed throught to larger idler pulley."
  • 4 Answers
SOURCE: mower deck belt diagram for poulan 42 inch ride mower
Go to Craftsman, Order Tree or Parts Tree.com and input your model number. Choose the correct tab and go to the mower deck. It will give you a good over view of how the belt routes. Hope this helps.
Posted on Nov 08, 2011
Belt is to long, is there a deck adjustment?
Jim, Double check to make sure you have correct belt for the deck and are installing it in the correct configuration as per manual or drawing on deck. Very few lawn tractors have deck belt adjustment, most do not, most deck belts have a spring loaded tensioner to take up the slack.
This could be some of your problem, the tensioner/idler pulley sometimes seize up and must be lubed up till they move freely, or your belt could be loose. Look in your manual or try google searching your make, model #, deck belt adjustment.
How to Change Riding Lawn Mower Deck Belt
Mower belt tensioner repair question to the Garage Gang
lawn mower deck belt routing Google Search
May 20, 2016 | Garden
Belt change 1972 craftman rider mower
Dan, Mower deck belt diagram /replacement links below. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Riding Mower Deck Belt Diagram DIY
Riding Mower and Garden Tractor Belt Routing Diagrams
deck belt diagram craftsman riding mower Google Search
Apr 10, 2016 | Craftsman Garden
How can i get a diagram of how to change a v-belt on a cub cadet 60" recon mower
There is a site that I use frequently. Go to Partstree.com and enter your model # then look up the diagram. Usually there is a digram on the deck .
Sep 14, 2014 | Cub Cadet Garden
Dont know wheter to get primary mower belt or secondary mower belt for craftsman gt3000 48 inch deck mower...?
primary belt goes from the engine to the deck the secondary goes on the deck and connects the blades together
Aug 24, 2012 | Craftsman 48" Cut Riding Lawn Mower Deck...
I have a craftsman riding mower model # 971.274822 and recently replaced the mower drive belt. Although it is the correct belt, 42", it is really loose! How do adjust the tension? Thanks
there is no adjustment on the drive belts but you do have a clutch adjustment to do this you have to remove the mowing deck (NOTE) draw a digram of the way the deck belt runs adjust the clutch lever from the bottom of the mower, test mower with out the deck on and if this solves the problem reinstall the deck....
Jul 26, 2011 | Garden
I need the belt digram for a 50" craftsman lawn tractor, it has two belts on the deck.. any help?
You need exact model numbers. Go to www.searspartsdirect.com
put in your model number and see parts list. Go to the right hand side of page and click on manuals.
Aug 02, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Need digram to install deck belt for blades
You are going to need to find the model number under the seat.
Go to www.precisionope.com and look up under OEM parts. You should find a parts list and diagram to route the deck belt.
Oct 06, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
I am trying to replace my mower deck belt. I
got to www.searspartsdirect.com eneter model # for the tractor & it should give you the option to look at & the chassis & deck to help route the belt or give you the right belt part #
Jun 05, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Looking for craftsman ys4500 belt digram
sometimes the route is on a sticker on deck or under foot rest on the mower look if not get a hold of me i'll help
Apr 22, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
