Question about Ricoh Office Equipment & Supplies
SOLUCIONAR CODIGO SC 820 RICOH - Ricoh Office Equipment & Supplies
  • 65 Answers
SOURCE: printer wont do anything ricoh aficio 1515 pcl 6
The first thing to try is to turn the machine off, then back on at the red "main power" switch located on the left side of the machine. If the code returns it is indicative of firmware problems or a loose connection.
At this point I would seriously recommend getting a service tech to come out. However, if you want, you can take off the back cover (MAKE SURE THE POWER CORD IS UNPLUGED) and double check all of the connections by (GENTLY) pressing them into their connections. Hope this helps. Let me know.
Posted on Nov 25, 2008
SOURCE: tengo una fotocopiadora ricoh aficio
Limpie o cambie si es necesario el thermistor de la unidad fusora, luego presione total clear key tecla amarilla, introduzca 107 y mantenga presionada la tecla clear stop tecla naranja, mas de tres segundos hasta que el tablero cambie a sertvicio, apague y encienda el interruptor principal y listo...
Buena suerte...
Posted on Dec 07, 2009
SOURCE: Ricoh aficio 1022 sc 546
problema ricoh aficio 1022 copia en blanco aparece codigo
sc 193
Posted on Jan 07, 2010
  • 903 Answers
SOURCE: codigo sc-322-000 copier ricoh aficio 450
sc322 is an error generally caused by a component in the laser unit. However, sometimes a faulty door switch can cause this error as well. The switches in question are the three micro-switches that change state when the right door is opened or closed. They are located on the front right side of the copier, above the fusing unit and behind a plastic cover. If you can remove these switches and test them individually, you can probably find the faulty switch. If not, you can replace all three as a set and hopefully the sc322 error will go away (once you reset the machine).
If replacing the switches do not fix the error, then the problem lies somewhere in the laser unit, possibly with the polygon mirror motor, but your best bet is to replace the whole laser assembly if you can.
Hope that helps!
Posted on Nov 03, 2010
  • 525 Answers
SOURCE: hola tengo el problema de un codigo sc-322 en una
Laser synchronization error
Symptom:
The main scan synchronization detector
board cannot detect the laser
synchronization signal for more than 10
consecutive 50 ms intervals.
Possible Cause:
• Poor connection between the laser
synchronization detector board and
the SBCU board
• Laser synchronization detector board
out of position
defective
• SBCU board defective
• LD unit defective
Posted on Jan 22, 2011
SC 820 AT STARTUP ?
SC-820: Control board or software
Call Ricoh for service.
Mar 06, 2016 | Ricoh Aficio MP3350
Codigo sc 542 en ricoh sp 3510 como resetearlo
Oi por favor. Gostaria de resolver meu problema com minha impressora ricoh 3510sf que estar dando o erro sc542. Me manda resposta. emiliomartinscte@gmail.com
Apr 09, 2013 | Ricoh Aficio SP 3510SF Laser Multifunction...
CODIGO DE AVERIA SC 553 RICOH MP 8000
la fotocopiadora marco sc553 y no se desbloquea que debo hacer
Jan 31, 2013 | Office Equipment & Supplies
Sc 395 ricoh aficio 3045
fix copier is a youtube channel
fixing error in videos
this is a video see you how to fix sc 395
https://www.youtube.com/watch?v=cI6o6mYOqow
Jul 05, 2012 | Ricoh Office Equipment & Supplies
Ricoh 1515 is locked up with error message SC:820 code 612. How do I fix the problem
820 Self-diagnostic error: CPU
Symptom:
• An unexpected exception or
interruption occurs during the self-
diagnostic test.
• An error is detected in the MBU.
Possible Cause:
• Defective controller
• Defective firmware
• Loose MBU jumper
Code 820
MBU error (The jumper is loose.)
Set the jumper (on the MBU) correctly.
The following codes are displayed:
• SC: 820
• code: 612
• detail: 40000000
Feb 03, 2011 | Ricoh Aficio 1515MF All-In-One Laser...
Codigo sc 440 aficio 350 (fotocopiadora
Hello sir; SC-440 means main drive motor locked ,suggestion; 1, check the connector isn't connected, 2, replace main motor.
May 06, 2009 | Ricoh Aficio 450 Copier
sc 193
Oct 20, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
Ricoh 1515
a minha ricoh 1515 vem apresentando constatemente o codigo cs 929, como fazer para solucionar este problema. pois os tecnicos não resolvem.
maninhosales@hotmail.com.
emmanuel buonafina.
fone 81 32425587
81 86123213.
May 28, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
ERROR SC 490 SAVIN 9940DPC
the error code SC490 is telling you that the exhaust fan is not working correctly. Look for a fan that is not turning "ON"
May 08, 2008 | Ricoh Aficio 450 Copier
315 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
