Question about Euro-Flex Monster 1200 Handheld Steam Cleaner
I have a monster clean blaster. It gets hot but won't shoot out steam. It drips a bit. That's it.
Steam mop won,t steam. Have tried all suggestions in user guide. Water won,t heat up. Machine becomes warm. Water ' vinegar will slowly drip out of base - so not blocked. Help,,
It could still be blocked, not totally blocked but enough to keep the steam from coming out as strong as it should.
Mar 14, 2017 | Vacuums
I have the euro steam blaster s3325 when I turn it on, the steam ready **** comes on right away not heating can the heating element be replaced? thanks
There is a device attach to the heating element called a thermo fuse, this devise brakes down when it get to hot.
open the machine and replace it with the same value. it is written on it..
Nov 20, 2012 | Euro-Pro S3325 Handheld Steam Vacuum
My ez1 Monster Floor Steamer - green light goes off when I lower the handle and stops steaming
It could be calcium deposits in the tank. Clean it with white vinegar. Good luck!
Nov 10, 2012 | Euroflex Ez1 Monster Floor Steamer -...
My steamer gets hot but no steam if very little is coming out what do i do
clean it with lime away where the steam comes out it has had hard water build up that has clogged your openings
Apr 06, 2012 | Euro-Flex Monster 1200 Handheld Steam...
I have the Shark Steam Mop, Model number 120544 (gold case) purchased at Costco in April 2010. The water heats up to steam, but never reaches the cleaning heads; water drips out of the handle to the...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
Feb 12, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop wont steam anymore. just gets hot and drips all over the place.
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Here also is a link to get any of the Shark Manuals that you need.
heatman101
ae
Oct 11, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Euro-flex monster baby 1000 watt will not release steam
try running a descale through the unit. probably blocked with mineral deposits. Descaler available at most steamer retailers
Sep 20, 2009 | EuroSteam Vapor Steam Cleaner Vacuum
I can't get my shark steam blaster model EP95 to create steam?
pull the (3) coasters/feet out and unscrew the 3 screws. take off the one end of the steam"boiler" (two clamps). tilt open end up and pour white vinegar [carefully] in there, prop up so it does not fall over, and soak overnight. dump out lime and water scale and rinse out a couple of times. Be very careful to not get water on electrical parts.
Take an air pig and blow out the line (Black) from where you disattached it to where the steam comes out [at the handle]. Be sure to mark electrical connections [4 on one, 2 on the other] so you don't blow a breaker switch like I did.
Oct 26, 2008 | Euro-Pro S3325 Handheld Steam Vacuum
Euro-Flex Monster 1200 Handheld Steam Cleaner Logo
20 people viewed this question
Top Euro-Flex Vacuums Experts
JoeVacs
Are you an Euro-Flex Vacuum Expert? Answer questions, earn points and help others
