Question about Yaesu FT-920 Transceiver
Ft 920 low power on ssb mode - Yaesu FT-920 Transceiver
2 Suggested Answers
WV6Z
  • 7 Answers
SOURCE: FT-920: When the TUNER switch is pressed, the
Have you tired performing a general reset (see page 92 of your Operator's Manual). If you have tried this and still have had no luck, be sure that you have established a good ground to earth and that you are not getting a lot of RF back into your 920.
If you do not have a manual for your rig, one can be downloaded here http://www.download.n7tgb.net/yaesu/FT920/man_ft-920.pdf
You can also call Yaesu Tech Support for free/additional help at 714-827-7600, or join the Yahoo FT-920 User's Group at http://groups.yahoo.com/group/YaesuFT920/
Hope this helps......
Posted on Jun 26, 2009
Yaesu 857D very poor audio out on SSB.
Dbl check your swr in am mode.. Ch your ssb power and mic gain default is 50 on both on hf .. If you use the mh-59 you will need to reduce the mic gain to 35 and it needs to be set for remote mic in the menu. Also the ssb needs to be set 2.5k wide with the ssb carrier zeroed both tx and rx
Apr 29, 2016 | Yaesu FT-857D transceiver
Radio power`s on but no transmit or receive on ssb however it will transmit with full power on fm
If your receiver was operating previously but now the SSB option is not working, very likely the sideband detector has failed. I'm not directly familiar with your Yaesu unit but, in most Yaesu transceivers, the SSB chip and control circuit (including diodes) is identified in print on the main board.
May 16, 2015 | Yaesu FT-990 DC Transceiver
Yaesu ft-990 no receive or transmit
Lynn, SSB (Single SideBand) only applies to AM (Amplitude Modulation) transmission. There is no way to broadcast SSB in FM (Frequency Modulation) mode.
May 16, 2015 | Yaesu Radio Communications
Distortion
turn the mic gain down, you need a meter or sprectrum analyzer to see what you're doing
Apr 17, 2014 | Yaesu FT-920, 990, 1000, 2000, FTdx-5000,...
Yaesu ft 920
how much of an amperage power supply are you using, you need at least a 20amp power supply, or maybe your power supply if going bad
Apr 17, 2014 | Radio Communications
Can someone slove my problyn why the receive on my yeasu ft-990 is so low please help
NEI! (Not Enough Information) I'll simply point you to the amateur radio repair yahoo group:
http://groups.yahoo.com/group/Amateur-repairs
That's the best place to ask such a question, but you better have a bit more information so people can help you.
Oct 26, 2013 | Yaesu FT-920, 990, 1000, 2000, FTdx-5000,...
I have a galaxy 88 and when u try to use it on ssb the radio will only do half power even with ssb power all the way up!
there is a ssb regulator bad or the power is turned down
this how to adjust ssb power output SSB ALC:
Mode to USB.
MIKE GAIN to maximum.
Inject two-tone audio signal of 500 Hz and 2400 Hz, 30 mV (-18 dBm) atMIC jack adjust VR12 Key TX; adjust for 25 watts PEP.
Sep 12, 2012 | Galaxy Radios DX- 88HL Base CB Radio
How to adjust frequency on transmit??? Galaxy
hELLO THERE
hERE IS SOME MODIFICATIONS FOR THIS RADIO
Galaxy Mods DX 2527 - VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...Hi Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VC 1....10.240, VC 2....10.240. DX 2517- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5....FM Deviation, VR 6....SSB Carrier Balance, VR 7....TX Offset, VR 8....CW Beep Level, VR 9....RF Meter, VR10...Final Bias, VR11...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM/FM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM/FM Low Power, VR601..13.8 Volt Power Supply. DX 22B- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...High Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VR21...TX Offset, VC 1....10.240, VC 2....10.240. DX 11B- VR 1....AM/FM S-Meter, VR 2....SSB/CW S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...CW Tone Level, VR20...Final Bias, VR21...TX Offset, VR601..13.8 Volt Power Supply, VR803..AM/FM Low Power. DX 77HML, DX 88HL, and DX 99V- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...AM/FM Low Power, VR20...Final Bias, VR21...TX Offset.
Unmarked VR in R189..AM/FM Medium Power for DX 77HML only. DX 33HML, DX 44V, DX 55V, DX 66V, and DX 73V- VR 1....AM/FM S-Meter, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 8....RF Meter, VR12...Low Power AM Modulation, VR13...AM/FM High Power, VR14...High Power AM Modulation, VR16...AM/FM Low Power.
Unmarked VR in R188..AM/FM Medium Power (DX 33HML only)
Unmarked VR in C139..Med Power AM modulation (DX 33HML only) DX 949,DX 959- VR 1....AM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM Squelch Range, VR 6.....SSB Carrier Balance, VR 7....TX Offset, VR 9....RF Meter, VR10...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM Low Power, VC1....10.240. DX 2517 and DX 2527-
Symptom:Buzzing or motorboating sound in either the transmit or receive.
Problem: TR602 is oscillating
Cure: Replace C602 with a .01uF cap {Cap is located in the power supply board}.
RG 66,99,DX2517 Replace Q54 2SB754 60watt 7A with a higher power 2SB817 100 Watt 12A. Derating of this component will cool operation, provide better voltage stability,decrease wobble, allow voltage increase to 14.5 volts comfortably. (replace 10 volt caps in this section of the radio to a minimum of 16 volts before increasing supply voltage to this level)and provide faster swing rise time, Replace Q37 2SA473 to a 2SA1012-0 or ECG153 this will improve the clarity and volume of the modulation and it will also run a lot cooler.
Nov 12, 2009 | Galaxy Radios DX-949 40-Channels Base CB...
Jun 25, 2009 | Yaesu Radio Communications
Yaesu FT-920 Transceiver Logo
223 people viewed this question
Top Yaesu Radio Communications Experts
Steve
eradiostore
eradiostore
Nyte_Ryder
Are you a Yaesu Radio Communication Expert? Answer questions, earn points and help others
