Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
SANJAY SINHA Posted on Sep 27, 2007
Install screensaver I'M USING WINDOWS VISTA. RECENTLY I'M UNABLE TO INSTALL SCREENSAVERS.THE MESSAGE READSAS FOLLOWS.......msvbvm50.dll has stopped working.PLEASE HELP.THANKYOU
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Sep 27, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
233
Points
5
I didnt think Vista came with msvbvm50.dll. You could try to download msvbvm50 from the Microsoft website? Just a suggestion, not a definite fix. http://support.microsoft.com/kb/179492
Can't get Snood to run in Windows 10. Error is MSVBVM50.DLL is missing.
Friend Troy Shields, Tipton County Tennessee in FB, he's my go to guy when it passes my scope
Dec 26, 2015 • Cell Phones
1helpful
2answers
How do you get Windows 10 free update from Windows 8 to operate the screen saver?
How to customize Screensaver in Windows 10
RECOMMENDED: Click here to fix Windows errors and optimize system performance
There were times when computer monitors used to suffer from image burn-in issues caused by showing the same image for a long period of time and people used to install a screen saver to avoid the issue. The computer screens today no longer face the burn-in issues, but people still use the screen saver on their computer systems for fun's sake. Windows 10 comes with a six built-in screensavers. Let us see how you can customize screensavers in Windows 10.
Read: Are Screensavers necessary and still needed.
Screensaver Settings in Windows 10 You can get to your screen saver settings directly by typing 'Screen Saver' in the taskbar search box in the lower left corner of your system. Click on 'Change Screen Saver' and it will take you the Screen Saver settings right away where you can adjust the settings according to your own preferences.
Alternatively, right-click on your Windows 10 desktop, and select Personalize to open Personalization settings. Next click on Lock screen in the left pane.
Scroll down the Lock Screen settings and click on Screen Saver Settings. The following window will open. Here you can adjust the settings according to your preferences.
By default, Windows 10 offers the following six screensavers - 3D Text, Blank, Bubbles, Mystify, Photos and Ribbons - nothing new here. Select the screensaver from the drop-down menu and change its defaults Settings, if any are available.
For instance, the 3D Text screensaver lets you customize the text as well as a few other options.
The Photos screensaver lets you display your favorite photos as a screen saver.
Once you are done, click on save and exit.
Create Screen Saver Settings Shortcut
If you access the screensaver settings frequently, you can create its desktop shortcut as follows: However, it is easy to change the settings but if you change your screen saver often, it would be better to create a Screen Saver Settings shortcut on your desktop.
To create the shortcut, you have to right-click on your desktop and click on New > Shortcut.
Type control desk.cpl,,@screensaver in the location space in the wizard.
Click Next and give a name to your shortcut. Click Next and you are done. Give it a suitable icon of your choice.
Use this shortcut to change or adjust your screen saver settings whenever you want, quickly.
You can also create a shortcut to launch or change Screensaver state for a specific screensaver.
All my old emachine screensavers are not in the windows 7
Hi There
You don't get your old screen sever in windows 7, bcoz windows 7 is update and all the wallpaper & screen sever is changed.
If you want the same you installed same windows before you are using.
Thanks
Have a nice day....
Error loading C:PROGRA~2MYWEBS~1ar.binF3SCRCTR.DLL
You have MyWebSearch Toolbar Adware installed, or remnants of the program. Download, Install, and Run Quick Scan of Malwarebytes from www.malwarebytes.org. Usually you get MyWebSearch from installing Screensavers and Toolbars, or other bundled Freeware Programs.
Error message when accessing internet explorer on the computer
This happens on installing vista the first time If u can install despite this message(ignore), then restart in safe mode and if your Vista is genuine then ask microsoft to send this particular file(SHELL32 if I h'nt forgotten) replace where the original is supposed to be and after that it should be fine. The Only other option is to Install WinXP_SP3 & enjoy.....sodeep
2answers
Cant install a printer
HP PSC 1410 All-In-One InkJet Printer installation
Sreensavers have dissapeared
hi my name is wesley. when you change to a different version of windows it will start most of your applications from fresh so you will have to manually put the screen savers you want use.
2answers
Screensaver
Vista uses a different technology for screen savers than in the past. The screensavers and backgrounds are active. Older screensaver software (I inferred from your post that you had a favorite that both of you used and not one from MS) will probably not work here.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
