Question about GE Monogram ZEK958SMSS Cooking Products : Wall Ovens : Double wall ove
Purchase replacement for Part no. WB27K5048, GE Monogram oven, Model No. ZEK756GP2BG
3 Suggested Answers
  • 189 Answers
SOURCE: GE Monogram Trivection - self-clean cycle with oven racks in
Hello- First off, do not use 'self clean', or as most Techs call it: "Self- Destruct".  This 'feature' cheerfully sold by the salesman destroys more oven and range components than any other failure. Now- the racks had a thin layer of grease on them when the oven tried to turn stuff inside the oven to ash.  The grease is now a hard rubbery coating on the surface of the rack.  To solve this problem, you must determine by observation, where the rack touches the sides of the oven. These contact areas need to be cleaned thoroughly with scotchbrite and a small portion of oven cleaner. Make sure you use gloves. Sliding rack in and out to 'mark' these small spots works pretty good.  Once cleaned and wiped down, they should work fine. I recommend cleaning by removing as much 'stuff' by scraping and wiping down with moist cloth.  Turn on to 450deg for 30 min.  Much safer, less costly.                                                       Please acknowledge this posted solution if helpful.  Have more info if needed-  Thanks  -Ed
Posted on Mar 24, 2010
espressonist
  • 1711 Answers
SOURCE: Have a GE Monogram Oven Single Wall Unit. Began
F1 touch pad / ERC test This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single
assembly, in which case this test is not necessary. Simply replace the ERC
(Clock).
Warning: If you feel in any way uncomfortable performing this test or
making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound)
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Posted on Jan 01, 2011
Need wb27k5047 part
G.E. part# WB27K5047 has been
replaced by G.E. part# WB27K5048,unfortunately neither part # is available anymore unless you have access to one,there is a place to send in your defective range control and have it refurbished though
Feb 21, 2013 | GE Ovens
GE Monogram oven ZET1SMSS decals rubbed off. I called GE parts and they said they do not just sell the "overlay." They said I would have to purchase the control panel (~$400) to fix the problem. REALL
I had a very similar problem with my oven so I contacted www.ovenlettering.co.uk who supplied me with excellent quality replacement decals with super fast delivery!
The video on the website made it easy to apply them too
Feb 01, 2013 | GE Ovens
GE Monogram Range igniters keep firing even when oven is off.
I had the same problem. Had GE out, they said it might be something but they'd have to take the cooktop off and it might be $300 or it might not. I unplugged it and now use matches.
Apr 21, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
Door won't close properly
Very common problem, when door is not closing all the way. You need to pull it out a few inches and readjust hinges on each side.
Ge monogram oven repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | GE Monogram® ZET1038 Single Oven
F1 error/touch panel not working on GE Monogram Dual Oven
Usually, the F1 means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled, replace the oven control (also called clock or ERC), touch pad, or both.
I recommend a service call for this repair.
Jun 02, 2009 | GE Monogram ZET3058SHSS Stainless Steel...
Convection works but Microwave does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
duid
May 26, 2009 | GE Monogram® ZMC1095BFBB /...
try using a voltage stabiliser .it may just solve ur problem..
May 17, 2009 | GE Monogram® ZMC1095BFBB /...
Microwave stopped heating
I bought one built in Feb 2005, installed July 2005. Magnetron tube failed Feb 2007 - cost $127 labor to replace. Just failed again Feb 2008 - will cost roughly $135 to replace this time. Not good for such a high end machine!
Dec 01, 2007 | GE Monogram® ZMC1095BFBB /...
GE Monogram ZEK958SMSS Cooking Products : Wall Ovens : Double wall ove Logo
78 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
