Question about Whirlpool WED8800YC Cabrio Platinum High Efficiency Electric Dryer
High pitched noise in spin cycle in brand new Whirlpool Cabrio Platinum washing machine
jsrock516
  • 5911 Answers
SOURCE: whirlpool awm8121 - spin cycle high pitch sound/scretch
Front loaders are great for savings on water and electricity. Most of these machines only use about 5 to 7 gallons (US) of water and spin with a velocity anywhere between 1300 to 1800 rpms. This also saves on dry times because your clothes are virtually spun dry. Why am I telling you all this? People buy them with good intentions, but the common complaint I hear is that they are noisy. It is this spin velocity that contributes to that noise. You need to make sure that the foundation under the washer is stable. If your washer is located in a mobile home, upstairs laundry room, home with a crawl space, etc., sometimes these floors have a tendency to flex as the washer spins. If the floor flexes (even a little) the washer will vibrate and make noise. An easy fix to help redistribute to weight of the washer is to place a sheet of thick (at least 3/4" in the US) plywood under the washer to help reinforce the floor. This must be screwed down or affixed in such a way that it does not move. This will take care of any vibrating issues. Now, if your problem is strictly with noise from the machine, some of that is normal I'm afraid to say. However, if it sounds REALLY loud (like a rumble) this is a symptom of a rear bearing that is going bad. If that is the case, the entire back shell of the wash tub has to be replaced in order to replace the bearing as they are molded into the plastic. This can be an expensive repair job if you decide to pursue this option. Let me know if any of this helps. Kinda hard for me to diagnose without being there to hear it.
Posted on Jun 24, 2007
s_4u_11
  • 535 Answers
SOURCE: Whirlpool Cabrio High Efficiency Top-Loading
PROBLEM RESOLVED!!!
The best I could find by scouring the internet was that it was a communication problem between the central control unit and the electronic control box. I was getting F1 codes that would stop the wash, then diagnostics showed F68 and F41 codes.
Sears wanted to charge $65 just to come out and diagnose it themselves, and these appliance sites wanted to charge their own fees to offer solutions. So I took a chance and ordered a new electronic control box ($146.00 + S&H) and installed it myself.
There are three long screws behind the control unit "hood", in the back-top of the washer, facing straight up and down. After unscrewing, I lifted up the hood up and forward, and there was a black box - the electronic control. First, you should check all the wires and make sure the connections are ok. If that still doesn't fix it, unplug all the wires, and take the electronic control out by unscrewing one 1/4" bolt. Put the new one in and re-wire everything (it shows what wires go where on the electronic control box - named by colors). No more error codes!
This washer is only a year and a half old as well, I guess it will pobably be my last Kenmore/Whirlp
Posted on Sep 16, 2008
  • 11 Answers
SOURCE: Dishwasher Making Loud High Pitched Noise.
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Posted on Jan 15, 2009
  • 107 Answers
SOURCE: high pitched screeching noise when in spin cycle
Sounds like something is in the pump or the pump bearing went bad. The pump runs CONSTANTLY in agitate, it runs backwards and spin and drain the motor reverses, so if there's something in it, it'll make noise the entire time.
Posted on Mar 25, 2009
  • 864 Answers
SOURCE: NEW Electric Whirlpool Cabrio Steam Dryer; NO HEAT
Check temperature sensor.  Check to see if heating element is OK.
Posted on May 29, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Whirlpool Cabrio makes excessive noise during spin cycle
Your model has a bearing under the tub which is probably going bad and needs to be replaced. cabrio washer bearing replacement YouTube
Oct 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Our whirlpool top loading washer starts making a high pitched whirring noise in the beginning of the first spin cycle. Once it gets going full speed the noise stops. What could be?
If you can hear the motor humming during the spin cycle, it could signal a defective motor drive. It's possible for the motor to fail in just one direction, which may be why you only hear it some times.
This kind of issue often requires the help of a professional. To learn more about this issue, read Washing machine will not spin but will pump and agitate. I hope this helps.
Sep 12, 2012 | Whirlpool Washing Machines
My brand new Whirpool front loader 1073DD makes a high pitched whistle when starting to spin and spinning, is this normal?
That actually is a normal sound, The machine is spinning at such a high speed rpm that a whistling noise is a common occurence.
Jun 14, 2012 | Whirlpool Washing Machines
Whirlpool cabrio loud noise during spin cycle
The inner bearing will be faulty kindly replace the inner bearings as well as water seal before that kindly check whether the drum is freely moving with out any shaking If you find any shaking means you are suppose to change the drum only
May 15, 2010 | Washing Machines
Whirlpool washer; spin cycle not draining
It sounds like your water pump is broken. there is a motor inside that pumps the water out when the machine computer changes to spin cycle
Aug 06, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
High pitched screeching noise when in spin cycle
Sounds like the belt is worn and might need to be replaced. Let me know if I can do anything else. thankyou for asking.
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
The washing unit makes a high pitched loud noise
Check to see if you have a bra underwire or nail stuck in the spin tub. Look around inside the tub looking for something stuck in one of the holes. Dont use the machine until you find the problem or you cut the tub in half with like a nail or screw and then the machine has to be rebuilt $$$$
You may have other problems, However start here. Let me know if you have other questions
May 26, 2008 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool WED8800YC Cabrio Platinum High Efficiency Electric Dryer Logo
29 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
