Question about GE GSD5330D Dishwasher
Dishwasher not completely draining
GE5330D02ww does not completely drain in all cycles. Leaves about 1 1/2 inches of water when finished. I have cleanes all the filters in the mechine, the drain hose isn't kinked and their isn't any air gap valve in the system. I have put the drain hose in a bucket and it only drains about 1-1 1/2 gallons on drain cycles
5 Suggested Answers
  • 175 Answers
SOURCE: Washer does not drain, and leaves water in the
hi..The drain is clogged.check the strainer at the
bottom of your unit.Always rinse your dishes of food
before putting them in the washer.
check this out..
thank u..
kindly rate my response..
Posted on Jun 09, 2009
  • 3 Answers
SOURCE: Dishwasher drains but leaves behind about 1/2" of standing water
Water standing in the bottom of the tub is normal.
A small amount of clean water around the outlet on the tub bottom at the back of the tub keeps the water seal lubricated.
Posted on Jun 28, 2009
  • 10515 Answers
This needs to be investigate properly. Let me provide you with all the steps you need to follow ;-
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
If the detergent cup isn't opening, see the "The detergent cup doesn't open" section, below.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 02, 2009
  • 1075 Answers
SOURCE: My dishwasher is draining properly.
yes there is cleaners.Check filters at bottom of machine fiirst,then buy an cleaner.adrian,,,,
Posted on Jul 15, 2010
  • 618 Answers
SOURCE: GE model #GSD5130D00WW Dishwasher leaves standing
There is a valve in the rear of the machine under the screen. If it is worn will not drain well . unscrew the valve and check whether the rubber cone is still all there. run in pump cycle with the valve out to clean the unit out.
Posted on Dec 03, 2010
0 characters
1 Points
Dishwasher won't drain.Leaves several inches of water in bottom of unit after cycle is complete
Check for blockages in the base of the dishwasher under filter etc.
Also make sure the kitchen drain is clear and if you have garbage disposer run it prior to running the dishwasher.
Also need to confirm if the dishwasher pump is actually operating during the drain cycle. If the pump is faulty then it will not drain. Provide full model number of dishwasher if you need further assessment of the problem. Good luck.
Aug 30, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
The dishwasher does not drain-- it leaves about 1-2" of water in the bottom after running a cycle
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Aug 16, 2011 | Dishwashers
Leaves about 1/2 inch of water and doesn't completely drain
As long as the water that is left behind after the DW finishes is clean and there is no odor, your dishwasher is behaving normally and like 99% of all dishwashers. Clean water is left there to prevent the sump gasket from drying out.
Thanks for posting back what you end up finding, OK?
Aug 10, 2009 | Dishwashers
Water won't drain after cycle is done. Leaves 1-2 inches of water in bottom. Checked hose and its clear. Put hose going to disposal in bucket and water comes out when diswasher is cycling
it is easy track this path of water from bottom of m/c it will b afilter then small hoses to drain pump thenouter hoses <
Jul 13, 2009 | Dishwashers
My dishwasher does not completely drain. It leaves about 3 inches of standing water. What could be causing this?
Without knowing the model of this GE ? dishwasher, it is very hard to be specific. Most DWs have a float/switch that sense when the dishwasher is filled and empty of water. They can fail.
If you can run a cycle without the dishwasher over flowing but it simply does not fully drain, I would pull the lower spray arm and the filter beneath that arm. Look closely for debris that could be blocking the pump. SOme dishwashers simply have a timer that controls each phase of the wash, including the drain cycle. If something is blocking the drain pump, an obstruction could cause this problem.
Good Luck, Please report back with what you find.
Apr 05, 2009 | GE Dishwashers
jeff you can call customer service at 1-800-626-2001 and they can help but it sounds like your timer is missing the drain cycle
Jan 08, 2009 | GE GLDA690MWW / GLDA690MBB Built-in...
Water not draining out after wash cycle
frigidaire dishwasher model#MDR251RER0/serial#TH84453602 not completely draining. I hear when it the drain cycle begins but does not empty completely out.
Jan 05, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
GE GSD5330D Dishwasher Logo
99 people viewed this question
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Michael Thomas
Michael Thomas
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
