Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Dishwasher my dishwasher fills with water but then does nothing! no water comes through the rotary arms!
  • 209 Answers
When i attend dishwashers hat have lost power to some part, i always check for broken wires inside the door skin, the wire harness inside the door skin gets hot and cracks with use when opening the door all the time the amount of times this fault has been the problem is weired to say the least after that then check the motor / capacitor etc for open circuit etc hope i have helped, if so rate me please
Posted on Sep 29, 2007
Not cleaning the dshes. Material lrft on dishes. Suspect poor water flow.
Fill with salt. Clean out all rotary arms. And put a dishwasher cleaner through. The rotary arms get blocked with lime scale.
Sep 16, 2012 | KitchenAid 24 in. KUDM25SH Built-in...
I have to initate the spinning of the sprayer arm.
uasally it isnt the spinning of the spary arm that does the fill it is controlled or a timed fill then the motor comes on if there isnt enough water in the unit it will not have enough pressure really need more info though
Jun 02, 2010 | Dishwashers
Spray arms not turning in dishwasher
Water pressure makes the arms move, so your pump must be defective
Aug 28, 2017 | Dishwashers
Whirlpool Model DU1145XTP89 It fills with water, arms turn
The clicking sound could be coming from an internal relay since you don't think it is coming from inside the machine.
Aug 04, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Dishwasher fills with water but does nothing else.
If your dishwasher drains and fills as it should and cycles normally, there is a problem with the spray arm assembly or recirculation pump. Esure that the spray arm is not clogged. Manually free up moving parts if the assembly can be removed.
Jun 25, 2009 | Kenmore Dishwashers
Frigidaire fdb949gf dishwasher won't spray water from arms
I found on my first dishwasher the arm holes were plugged. I had to clean out each and every hole with a small wire. They would not even turn until I cleaned them God luck.
Dec 22, 2008 | Frigidaire 24 in. PLD2850 Built-in...
I have a GE built-in, rotary dial. Twice now, the dishes are still dirty when the cycle is done, and the soap looks like it just dribbled down the inside door and landed in a pile on the bottom of the...
your problem is in the water ,,, eather not getting enough water into dishwasher or your lower spray arm isn't turning ,,,,, i would turn the arm into a prosition that i knew where it set and turn dw on and after you hear it starting to run open the door to see if it has turned ,,,if you have a load of water but arm is in same place the arm is bad ,,, if not much water then you most likely have a bad valve / larry
Dec 10, 2008 | GE 24 in. GSD2000Z Built-in Dishwasher
Dishwasher pump caviation
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Dishwashers
Spinning arms stationary
problem is usually debris in the end angled jet of the spray arm which is used to turn the arms. take them outy and patiently clean. very common problem
Apr 24, 2007 | Neff 24 in. S4443 Built-in Dishwasher
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
112 people viewed this question
Top Hotpoint Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
