Question about AcuRite Acu-Rite 00593W Wireless Weather Station
Outdoor humidity stuck on 99% - AcuRite Acu-Rite 00593W Wireless Weather Station
Recently purchased clock with tempature and humidity dials, humidistat not working It is outdoors in southwest Florida and it says the humidity is 50 %,no warranty or instructions
what makes you think that the humidity is not correct
it is a indicator that will not move much so don't expect it to move around like a temp gauge or barometer
May 15, 2017 | Humidifiers
I have the weather channel indoor outdoor thermometor and the outdoor temp and humidity are not showing up on my wall reader
With mine, this indicates that the battery needs replacing on the INDOOR unit. For some reason they don't pick up the signal from the transmitter. I use batteries 3 to 1, indoor to outdoor.
Feb 23, 2017 | Weather Channel Measuring Tools & Sensors
How to set up taylor `model 1731
  • Indoor (32°-122°F/0°-50°C) and outdoor (-4°-140°F/-20°-60°C) temperatures. Lower outdoor temperatures achievable with lithium batteries; Indoor and outdoor humidity. Includes temperature and humidity trend indicators; Daily min/max recall for temperature and humidity. Features a calendar and clock with alarm; The wireless remote sensor transmits up to 200 ft. The base station and wireless remote require 2 AAA batteries each, not include. If you want essay related topic you can go for custom essay writing service will get better result.
New Generation Custom Essay Writing Service with Intelligence EssayCaptains
Feb 06, 2017 | Taylor Health & Beauty
La crosse support
Check the battery in the outside sensor. If the outdoor sensor is hard wired to the clock (or fresh batteries doesn't fix the issue) the unit needs to be replaced.
Jan 16, 2014 | Home
To much humidity coming from unit into house
An air conditioner removes heat (cools), and removes humidity. Your unit is either undersized or there's a leakage of outdoor air entering the conditioned space.
Aug 30, 2013 | Mitsubishi Heating & Cooling
Is there an online manual for Springfield 91756 Wireless Thermometer w/Indoor/Outdoor Temperature & Humidity
Yes. Took awhile to find it, but here is the link: https://docs.google.com/gview?url=http://www.weatherconnection.com/manuals/91756.pdf&chrome=true
Aug 07, 2012 | Springfield Measuring Tools & Sensors
There seems to be humidity in the watch
If the humidity has been condensing or happening for a period of tmie longer than 3-4 hours, this watch should be taken to a Certified Master Horologist in your local area as soon as possible. The timepiece should be opened, dried out, resealed, and water tested.
If humidity comes and goes away within 3-4 hours it is a normal occurrence from extreme temperature change (A/C to outdoor heat, vice versa) (Outdoor cold to indoor heat, vice versa).
Jan 16, 2011 | Giorgio Armani Emporio Armani AR0584 AA...
Doesnt cool as well as have been told
There are allot of conditions that affect the cooling, outdoor humidity, if it is between 10 and 15% humidity, then it should work well, anything above 30% outdoor humidity, it won't work. That is just nature, but duct sizing or is it a single drop? Also if you are running it in a home, you will need to open windows to allow air to excape, or it will fill the home like a ballon and then you will have reduced air flow and no cooling.
Is the pad clean? Is the full pad wet? The water level needs to be set so that when it is turned off the water level is about 1/4" below the top of the of the pan overflow pipe.
I hope this gives you a basic idea.
Sincerely,
Paul Gibson
Apr 30, 2010 | Mastercool 67680 Evaporative Cooler Air...
Water only runs with humidistat in test/reset mode. Aprilaire 600 with an Aprilaire 56 Automatic Humidistat, both about 5 years old. Water line is clear, and test mode runs fine for the 1 minute interval....
you need to make sure your humidity level in the house isnt higher then what your humidifier will provide at any givin outdoor temp. this chart is in the owners manual. you cant remove the wires going to the ODS or it will give an error unless you have a resistor to put in its place. Anyway if the humidifier works in test mode according to AA it works so you may have higher humidity than you think, the highest your gonna get is 45% as the temp outside drops it will allow less humidity so it doesnt cause window condinsation (property damage) here is a copy of the chart. the #s on the left are the dial setting
TABLE 2 – % Relative Humidity Guide
Outdoor Temperature (°F)
-10°F 0°F 10°F 20°F 30°F 40°F
10% 10% 10% 15% 20% 25%
2 10% 10% 15% 20% 25% 30%
3 10% 15% 20% 25% 30% 35%
4 15% 20% 25% 30% 35% 40%
5 20% 25% 30% 35% 40% 45%
6 25% 30% 35% 40% 45% 45%
7 30% 35% 40% 45% 45% 45%
Nov 28, 2009 | Aprilaire 600 Humidifier
Humidity too low
I corrected the problem...RH is rising nicely!! Installed by "professionals" on my Trane XV90....I redid their wiring and now have the following setup...
600A water supply coming from hot water line.
Removed orifice inside incoming feed tube.
control incoming water flow from saddlevalve on hot water supply ( make sure its a nice solid flow, no drips, but no "force" too it either)..enough to insure entire evaporator unit is wet and water is slightly flowing out of bottom to drain.
I also have it wired to run when ever the furnace blower is on. Heat or no heat. XV90 is variable speed, and by doing this the 600a is always adding moisture, until it reaches correct RH%
Also, I disconnected the outdoor temp sensor. I went to Radio Shack and bought a 47K ohm resistor ( 1/2 watt....4 pack for 99 cents). Installed that in place of outdoor sensor...now runs in manual mode. Have unit currently set to number 5.
Jan 14, 2009 | Aprilaire 600 Humidifier
AcuRite Acu-Rite 00593W Wireless Weather Station Logo
79 people viewed this question
Top AcuRite Measuring Tools & Sensors Experts
Tom Chichester
Are you an AcuRite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
