Question about Dishwashers
Power switch blows fuses on whirlpool dwh b10
5 Suggested Answers
dahaka
  • 347 Answers
SOURCE: Whirlpool DWH B10 - under IKEA
Hello Shazzastu,
I think there is on manual online for the product you need,
However i advise you to click Here and contact Ikea to install your dishwasher
Good luck,
Dahaka
Posted on Jul 25, 2008
  • 423 Answers
SOURCE: is this hot or cold feed
This dishwasher should be connected to the hot water line under the sink. If it is connected to the cold line, you will have very poor cleaning. The hot water should be 120 degrees (F) minimum and less than 140 degrees.
Posted on Apr 18, 2009
  • 574 Answers
SOURCE: Whirlpool / IKEA Dishawasher DWH B10 - castor wheel
make sure there aren't any screws through tabs at the top front of the washer that fastened it to the counter top.
Posted on Jan 04, 2010
  • 1456 Answers
SOURCE: DWH B10 F3 - no heat.
Hello
The majority of dishwashers are not connected to hot water from the mains but heat up the water internally using the heating element, located in the tub of the dishwasher, controlled by a thermostat. When the dishwasher has a fault with heating, the program will run but not complete and will show an error code on the display panel. Dishes won't be cleaned properly and the detergent won't dissolve.
If your dishwasher does bring in hot water externally from the mains to check the water is warm and there are no problems with the inlet. If the dishwasher heats internally then it is most likely a faulty heating element or thermostat. A fault like this will usually require a replacement part and a repair, but you can check the heating element with a voltmeter to ensure that it is the cause of the problem before calling out for a service engineer.
Posted on Sep 10, 2011
Just need to know how to operate DWH B80
Hi Wendy the link below has two user manual downloads on it, I hope you find what you're looking for....CHEERS..
http://lastmanuals.com/manual/WHIRLPOOL/DWH-B80-W
Mar 24, 2016 | Whirlpool DWH B80
Try checking this link for the user manual http://www.serviceforce.co.uk/pdf_search.asp
Hope that helps..........
Jul 24, 2008 | Dishwashers
What turntable motor do I need for a whirlpool MW B10 W microwave?
Refer your inquiry directly to Whirlpool or an appliance parts supplier.
Jun 11, 2014 | Whirlpool GH7155XHS Microwave Oven
Whirlpool dwh b10 stuck on rinse cycle
sounds like your heating element has open circuit duff fit a new element should work fine
Sep 26, 2012 | Washing Machines
DWH B10 F3 - no heat. Stops at rinse and beeps + flashes 3 times
Hello
Sep 10, 2011 | Whirlpool Dishwashers
Whirlpool dwf b10 manual
Try this site
http://www.whirlpool.co.uk/support_instructions-for-use_instructions-for-use.content.html
then enter in DWH B10 and you should be able to download a PDF manual
Oct 12, 2010 | Dishwashers
Jan 04, 2010 | Dishwashers
Is this hot or cold feed
Apr 17, 2009 | Dishwashers
Wont start
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dishwashers Logo
Top Dishwashers Experts
