Question about Electrical Supplies
Looking for replacement starter for suzuki generator welder sw140
2 Suggested Answers
  • 6 Answers
SOURCE: lincoln welder 300 fails to generate
have you checked the"power on"light it should be on,if not you dont have "power in",also if the machine overheats the power trip will throw,check that also. let me know how you get on. kind regards. ronnie.
Posted on Mar 15, 2009
I have a 2007 miller bobcat it has spark cleaned carb new plugs new filter and it won't start
did you try a touch of starter fluid in the carb just to verify that the engine is getting spark? ethanol gas... if it hasn't run in a few months and you left the gas in it... you better revisit the carb cleaning
Dec 13, 2015 | Bobcat Miller 250 Welder Generator 907212...
I have a miller bobcat 225, it keeps blowing 30 amp inline fuse on a blue wire that runs to the hot side of the starter, any idea?
millerwelds.com will let you down load a manual for this unit, it can help you with this problem, also you can call miller and tech support should help
Jan 22, 2015 | Bobcat Miller 225 Welder Generator 907209...
Where is the 8A fuse in the generator ?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2014 | Eastern Tools & Equipment ETQ DWG6LE...
Restore magnetic field to welder generator?
Look on Youtube for videos on how to flash the field.
Sep 15, 2014 | Lincoln Ranger 225 Engine Driven Welder...
Welder will weld for about 30 minutes and then will not weld until the unit cools down. generator function is normal. the repair shop told me that the welding leads were bad so I replaced them and have the...
If you check the wire A4 which connects the bridge to the current selector switch, make sure the connections are clean and tight. The sense wire parallels it and dirty connections on A4 can make more current flow through the sense wire than normal.
It is also possible the current sensor may be faulty, or has a bad connection, or is even seeing transient spikes from brush noise. The sensor connects to terminals 3 and 4 of J2 the 4 terminal connector on PCB1. And looks like a plastic and metal donut The sense loop for welding is supposed to be a single loop through and the generator sense should be 3 loops through.
Sep 12, 2010 | Lincoln Ranger 250 Gxt Welder Generator...
My lincoln welder/generator with onan engine will only run for a short time when it shuts down. It doesn't matter if in use or not, either welding or generating. It is getting fuel and the coil has been...
The engine has low oil level shutdown. It may be the reason for stopping.
Use the welder only at level condition. Check the oil level, before every start.
If no result, find and check the oil sensor contact (if possible replace with good to check). Try with disconnected and shortened contact prior to buying a new one.
Other possible reasons you already checked
Aug 05, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
I have a lincoln handy core 35 - 88 amps and want to buy a generator what kind and how large should I get amp wise Noel B
It looks like this welder requires a 120 v 20 amp service. That works out to 2400 (2.4KW) watts, but you might want to get a generator in the 3000 (3KW)watt range to handle surging or if you want to plug something else in like a light or other accessory.
Mar 05, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
Electrical Supplies Logo
26 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
