Question about Jenn-Air JMC8127DD Microwave Oven
I need to replace the control panel on our Jenn-Air JMC8127DD Microwave oven. I have removed the clip screw & lowered the clip approx 1/4 inch. How do I proceed from here inorder to remove and access behind the face plate? thanks
MicrowaveSvc
  • 9047 Answers
SOURCE: Removing a built in Jenn-Air Microwave from it cabinet...
First of all, what are the symptoms? Please reply back and I'll be happy to share my thoughts.
Many parts can be accessed without removing the oven from the wall by just removing the control panel.
You need to be sure the cord is unplugged, then you remove the vent grille that runs across the top.
Then you'll see a screw holding the control panel in place. Once that screw is out, you can lift out and out carefully to separate the control panel form the chassis.
If you pull any wires off the control panel, mark and/or photograph them first to be sure you get them ALL back in the right place.
There may also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
Before you start, we have *critical* safety & disassembly info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
While they don't have their installation instructions online, the owner's manual is online here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 31, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Jenn-Air Microwave Bulb and Filters Inaccessible - Design Flaw - Help!
It's not a design flaw. The microwave was incorrectly mounted.
The installation instructions (installation kit) included a template for proper alignment of the microwave on the cabinetry.
If it had been aligned with the template, the two top grill screws would be easily accessible.
The grille must be removed to access the lights and the charcoal filters, which should be changed every 6-12 months if they are used.
If they are in place and not changed regularly, critical ventilation and cooling can be affected.
Your owner's manual can be downloaded free here, and it shows you how to change the bulbs and filter.
It will have to be remounted properly.
Posted on Nov 08, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: how do i remove a built-in jenn-air microwave?
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If not, try here.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If the fuse is good, it may be the magnetron thermal cutout (TCO or thermostat) or the oven cavity thermal cutout (TCO or thermostat).
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 09, 2009
  • 3 Answers
SOURCE: Jenn-Air JMC7000 Microwave stop working
I have the same unit and age the JMC7000 everything appeared normal on the display and countdown etc...But it would not heat,I trouble shooted the problem and discovered it was a faulty door switch I replaced it and it works like new again.I ordered the part from www.repairclinic.com it's an easy fix.and costs a few bucks...
Posted on Feb 06, 2009
tbreeze47
  • 3083 Answers
SOURCE: I have the Jenn-Air microwave
Most microwaves are similar in design, and here is how for a GE, which will most likely apply to the Jenn Air:
http://forum.appliancepartspros.com/microwave-repair/84864-microwave-lightbulb-replacement.html
This site explains the process:
http://forum.appliancepartspros.com/microwave-repair/165-microwave-interior-light-bulb-replacement.html
To discharge the cap, you can touch an insulated screwdriver across it's terminals, but just avoid the contacts and you will be fine.
Sorry to have to relay tough news, but how this helps you repair it.
Posted on Sep 10, 2010
Remove front panel from a jenn air microwave
I do not have that microwave, but the documentation that came with it may include a parts diagram that will provide a hint as to whether there is another piece holding it. Jenn-Air's support page for that unit may have more information. Failing that you might call their support , or their support site may have instant chat. Sorry I can't help specifically, but these are some avenues that have worked for me
Jan 01, 2015 | Jenn-Air JMC8130DDS Microwave Oven
How to remove JMC8127DD from cabinet
The wiring diagram for the microwave shows it is separate and distinct.
Usually slid-in counter top microwaves in this cubbyhole configuration have a trim piece surrounding & covering the front edges of the oven on all sides like a picture frame.
Normally you remove 4 or more screws in the trim frame, pull the frame off, then slide the oven out a little (there may be a locking tab on the cubbyhole's rails for safety) to unplug the cord, and then slide it out the rest of the way.
You can find installation instructions and other literature for this model for free download here.
You can find links to helpful exploded view diagrams and order parts and accessories for it here.
May 22, 2013 | Jenn-Air JMC8127DD Microwave Oven
Jenn air microwave quits working after 11-13 seconds of heating
open circuit switch when power reaches this switch it will shut down as switch is us
Aug 12, 2012 | Jenn-Air JMC8127DD Microwave Oven
Where is the high voltage fuse on a microwave
The thermal fuse monitors the magnetron temperature and cuts power, if it gets to hot and resets in no more than 20 to 30 minutes. Unplug microwave oven, remove top, "several screws" look over to the right, thermal fuse is mounted on top on the inner chassis, "round and thick with 2 wires clipped on"
Apr 16, 2012 | Jenn-Air JMC8127DD Microwave Oven
How can i disassemble a jmc7000adw
Although most open via a screw at the top or left side of the control panel.
Some require the cabinet / casing to be removed. If there is no visible screws at the top or sides of the control panel. Then the casing will need to be removed.
Mar 27, 2012 | Jenn-Air JMC7000 Microwave Oven
Some numbers on the control panel won't react when pressed...I can bang on it and it will work but not just by touching the numbers
mine did the same thing. i bet you have kids. kids are really hard on touch pads. the touch pad itself isnt too horribly expensive. id try a new one of those. teach the kids "gentle touch". cheaper in the long run.
Oct 27, 2009 | Jenn-Air JMC8127DD Microwave Oven
I have an old Jenn Air microwave above the range I need to remove
If you only need to remove the oven from the housing, there will be (should be!) 2 small screws at each side of the trim, 2 top and 2 bottom. Remove these and the oven should slide straight out. These screws will be into the side panels of the housing, but there may only be two fitted! Depending what you are intending to do next, you may have to disconnect the supply cable and/or dismantle the oven to replace parts. You will need two people to lower it to the floor, have a stool or similar handy in case the cable length is too short to allow this.
Good Luck
Thanks
Jun 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Jenn-Air JMC8127DD Microwave Oven Logo
32 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Dennis Boxerman
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
