Question about Oliso TG-1000 Iron
My scorch guards do not come down. No lights come on either.
Shark iron g1462
the lights you witness are correct. once the iron has reached tempreture.
ensure the iron is stored in an upright position between ironing items if left laying down the iron may switch off as an anti-burn or fire safety feature as if left unattended. with the iron placed on its back plate with its point facing upwards the iron should stay on.
I hope this was useful.
May 14, 2014 | Irons
Shark Iron just quite working i have had it about 8 months and it has been good
given the potential danger, and relative low expense, would you just consider trashing this and buying a new one? I don't intend to sound short or sarcastic....it's just with the burning smell I would prefer you either return it for refund, call the manufacturer or trash it for a different iron.
Looking at epinions.com there is a comperable iron for around $40-$50 with 24 reviews and 3.5 stars out of 5.
http://www.epinions.com/prices/pr-Black_Decker_D2030_Iron
Feb 23, 2012 | Euro-Pro Shark Rapido Electronic Iron -...
Tefal prog 8 500 series iron not heating up properly -
My Tefal Program 8 400 iron will not heat up. Light is on but nothing coming through. I has used it 10 mins before this happened
Apr 05, 2010 | Tefal UltraGlide Easycord FV4256 Iron
My new black & decker steam advantage iron won't glide over clothes, it's almost like it wants to stick to the clothes.
check the instruction manual and see if it says to clean the surface before using it , if not try cleaning it and use it on something old in case it wants to scorch the fabric
Dec 11, 2009 | Black & Decker Irons
How do I clean my Black N Decker Advantage Iron
I work for Black & Decker customer service. Our number is 800-231-9786.
You can obtain a new manual for free by visiting www.useandcaremanuals.com. Below is the section from the manual on care and cleaning of your iron.
Care and Cleaning
This product contains no user serviceable parts. Refer
service to qualified service personnel.
It is not necessary to empty the water reservoir after each
use of the iron, if you iron frequently.
To empty the iron, hold the iron over the sink with the tip
pointing down. Water will stream out of the water fill
opening.
TO CLEAN THE OUTSIDE SURFACES
• Unplug and allow iron to cool completely. Wipe the
soleplate and outer surfaces with a soft cloth
dampened in water and a mild household detergent.
Never use abrasives, heavy duty cleansers, vinegar, or
scouring pads that may scratch or discolor the iron.
• After cleaning, iron with steam over an old cloth to
remove any residue from the steam vents.
ABOUT THE SELF-CLEANING SYSTEM
• Use the self-cleaning system to flush out minerals and
lint. If lint is allowed to accumulate in the vents, it can
scorch and cause brown spotting.
For Models D2000 and D2020: Clean about once a
month.
For Models D2010, D2030 and D2035: A "CLEAN"
indicator will appear in the digital display to notify you
when your iron needs cleaning (A).
• Fill the iron as described in "How to Use" but keep the
water level below the MAX line. Plug in the iron, set
the temperature to 6, and stand the iron on its heel
rest. Allow to heat about 3 minutes.
• Unplug the iron and take it to a sink. Holding it
horizontally over a sink, move and HOLD the variable
steam dial in the CLEAN position ( ). There may be
some hissing and spitting while self-cleaning. This is
normal.
• Stay clear of HOT steam and boiling water as it comes
out of the vents while lint, scale, and minerals flush
through! Continue to hold the variable steam dial in
the CLEAN position until all the water has emptied.
If necessary, rock the iron side to side and front to back
to empty it.
• When finished, release the variable steam dial, stand
the iron on its heel rest, and plug it in. Heat for about
2 minutes to dry out any remaining water then unplug.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Jul 03, 2009 | Black & Decker D2030 Iron
How do i use the self cleaner
Care and Cleaning
opening.
month.
normal.
to empty it.
Jun 26, 2009 | Black & Decker D2010 Iron with Auto...
Steam Press sp-660 will not steam with distilled water
Steamfast brand SP-660 steam press
contact Top Innovations
1-800-711-6617
Nov 10, 2008 | Steam Fast SP-660 Iron with Auto Shut-off
Oliso TG-1000 Iron Logo
24 people viewed this question
Top Oliso Irons Experts
Andrew Taylor
Andrew Taylor
ray gallant
Bill Boyd
Are you an Oliso Iron Expert? Answer questions, earn points and help others
