Question about Building Materials
How to open the lamp dome for lynx model 455 plus
2 Suggested Answers
  • 3197 Answers
SOURCE: hello does my lynx 455 plus sensors have lights
Not familiar with lynx but every sensor I have seen or heard of has a light. It is the only way to tell when they are pointed correctly at one another.
Posted on Jan 08, 2010
2009g6 dome light comes on all by its self why
The dome lamp switch has 3 positions: DOOR, OFF, and ON. When in the DOOR position, the dome lamp operation is controlled by the body control module (BCM).The ON position provides a ground for continuous operation. Ground is provided at G302. The OFF position turns OFF any dome lamp operation. The courtesy lamps, may be manually turned ON by placing the instrument panel (I/P) dimmer switch in the DOME position. When the dome lamp switch is in the DOOR position, the dome lamp will illuminate when a door is opened. When a door is opened, the courtesy lamps turn ON. After all the doors have been closed, the courtesy lamps will remain illuminated approximately 10 seconds after the last door closes. When the driver places the dome lamp switch in the OFF position, the dome lamp will be disabled.
Do you hear any chimes when the light comes on ? Door ajar switch problem , maybe . Picture of car with door open light lit on the instrument cluster ? When does it come on , when driving or sitting still or both ?
You mite want to take it to a qualified repair shop and have it checked for DTC'S - diagnostic trouble codes .
DTC B2555 05: Passenger Compartment Lamp Control Circuit Short to Battery or Open
The body control module (BCM) applies battery voltage to the courtesy lamps through the courtesy lamps high control circuit. When any door is opened, the door ajar switch contacts close and the BCM receives a door-open input. If the BCM receives a door lock or unlock input or a rear hatch open input, the BCM will activate the courtesy lamp high control circuit, providing battery voltage to all of the dome lamps, reading lamps, rear compartment lamp, and vanity mirror lamps. In the event that any of these lamps were to remain illuminated for more than 20 minutes with the ignition switch in the OFF position, the BCM will deactivate the courtesy lamp high control circuit to prevent a total battery discharge condition.
Do you know how to do basic automotive electrical testing ? How to test inputs and outputs of a control module ? in this case the BCM - body control module ? Find wiring diagrams at
http://www.bbbind.com/free_tsb.html also watch this video ECM Inputs and Outputs Diagnosis
Jan 19, 2017 | 2009 Pontiac G6
I am having trouble linking my Lynx 455 to my Tesla Model S Homelink. Is there a compatibility issue? Does the remote continue to send a signal with the button pressed?
The Model S uses a homelink system for the garage opener, and according to their compability list, the Lynx is not there. So Homelink does not guarantee the functionality of it. If you don't get it to work while following the correct procedures from Tesla, I recommend you get the universal receiver kit from homelink.com Note that there is a difference in transmitter frequency between US and EU universal kits, so make sure you get the correct one. good luck!
Jun 27, 2015 | 2015 Tesla Model S
How & where would I get parts to repair my Lynx 455 garage door opener, installed in 1989 ?
Wow - lots of hits. Google: Lynx 455 garage door opener parts
This will start with service vendors who have parts and are close to you. After that, you will see the manufacturer pages.
Mar 03, 2015 | Building Materials
How do I lower beep volume on honeywell lynx plus?
Your four digit code, volume then the down arrow key.
Aug 29, 2012 | Honeywell | Ademco LYNX Plus LYNX Plus
The interior lights on my father-in law's 2000 Safari are all inop (6 spots plus two dome lights) I can't find a fuse in the engine box for them. Is there another fuse box. The van has a dome overr
Does the van have remote keyless entry (RKE) system ?
Interior Lighting System Description
Vehicles with the optional remote keyless entry (RKE) system have interior lighting controlled by the body control module (BCM).
This vehicle uses a delayed interior lighting system.
The system functions as follows:
• The dome lamps will illuminate when any door is opened.
• The dome lamps will remain on for 20 seconds after the last door is closed.
• The delay is canceled and the dome lamps will go out when the ignition switch is turned to the ON position.
• The illuminated entry function will not operate when the dome lamp defeat switch is in the OFF position.
• The interior lighting system is protected from battery rundown by the retained accessory power (RAP) system. The RAP system functions by shutting down interior lights after 10 minutes (when ignition is OFF).
Interior Lights Circuit Description
When the interior lamps circuits are closed/enabled, the courtesy lamp relay is activated by the two following coil circuits:
• CKT 690 (GRY/BLK) which is the courtesy lamp enable output of the body control module (BCM) driving the coil side of the relay.
• CKT 1732 (ORN) which is the coil output side of the relay going to the potential grounding switches/sources.
When the courtesy lamp relay is enabled, CKT 156 (WHT) (courtesy lamp output) is enabled by the closed contact at the relay and then grounded by CKT 750 (BLK) at G110.
Some of these circuits can also be activated with the headlamp and panel dimmer switch. When this happens, the coil output side of the inadvertent power relay is grounded to the body control module (BCM) via CKT 1393 (DK BLU)
CKT 40 (ORN) from the courtesy fuse drives both input sides of the inadvertent power relay. When the contact is pulled closed, CKT 1732 (ORN) is supplied power, thus driving any lamps/circuits attached that circuit and providing ground.
The body control module (BCM) also monitors the following four door inputs:
• CKT 49 (DK BLU) -- LH door jamb switch input
• CKT 54 (ORN) -- RH door jamb switch input
• CKT 775 (PNK) -- Side door jamb switch input
• CKT 656 (YEL) -- Rear door jamb switch input/liftgate strut switch input (depending on option content)
When the doors are closed, the body control module (BCM) is in a floating state of 0-2 volts. When the doors are opened, the courtesy lamp relay is activated, sending power to the courtesy lamps.
The headlamp and panel dimmer switch also activates the following interior courtesy lamps when the switch is placed in the PARK or HEADLAMP ON positions:
• RF power window switch
• RH power door lock switch
• LH power window switch
• LH power door lock switch
• LH outside rearview mirror control switch
• Rear radio control head
The dome lamps can be disabled by closing the dome lamp defeat switch located on the headlamp and panel dimmer switch.
Courtesy or Dome Lamps Inoperative
Step
Action
Value(s)
Yes
No
Important: Verify functional bulbs before beginning diagnostic procedure.
Did you perform the Lighting Diagnostic System Check?
YES - Go to Step 2
NO - Go to Diagnostic System Check - Lighting Systems
Are all of the courtesy/dome lamps inoperative?
YES - Go to Step 6
NO - Go to Step 3
Activate courtesy/dome lamps
With DMM, check for battery voltage from inoperative lamp CKT 1732 (ORN) to ground
Is battery voltage present?
B+
YES - Go to Step 4
NO - Go to Step 5
Repair open in CKT 156 (WHT) between inoperative lamp assemply and S214.
Is the repair complete?
NO - Go to Step 10
5
Repair open in CKT 1732 (ORN) between inoperative lamp assemply and one of the following splices:
• S258
• S301
Go to Step 10
6
Turn the courtesy lamp switch to the ON position
Check for battery voltage at BCM C2 cavity B12.
B+
Go to Step 7
Go to Diagnostic System Check - Body Control System in Body Control Systems
7
Verify continuity of the following three circuits with DMM:
• CKT 1732 (ORN) between courtesy lamp relay and body control module
• CKT 156 (WHT) between courtesy lamp relay and S214
• CKT 750 (BLK) between courtesy lamp relay and S206
Are all of the circuits functional?
Go to Step 8
Go to Step 9
8
Replace courtesy lamp relay.
Is repair complete?
Go to Step 10
9
Repair the inoperative circuit.
Go to Step 10
10
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 2
Mar 01, 2018 | 2000 GMC Safari
Hello does my lynx 455 plus sensors have lights
Jan 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
Saturn Turn Signal / Dome Light Issues
The interior lamps system consists of 2 main features. Illuminated entry and a battery saver feature that will turn the interior lights off after 20 minutes if they are left On with all doors closed and the ignition Off. The body control module (BCM) controls both of these functions. Battery power is supplied by the BCM through CKT 1732 to the following lamps:
• The dome lamp
• The map lamps
• The rear reading lamps
• The rear dome lamp
• The cargo lamp
• The glove compartment lamp
• The courtesy lamps
• The sunshade lamps
The BCM also controls the ground circuit side of the dome lamp and reading lamps for illuminated entry. The dome lamp and reading lamp will remain on for 20 seconds after the ignition key is removed and the last door is closed. In addition, if the vehicle is equipped with remote keyless entry (RKE), the dome and reading lamps will turn On and stay on for 20 seconds after an UNLOCK signal is received from the keyless entry transmitter.
The reading lamps, dome lamp and map lamps can be turned On at any time by moving the appropriate switch to the On position.
The rear dome lamp is fed battery voltage through CKT 1732 from the BCM, through the liftgate ajar switch, and is grounded through CKT 650 to the rear ground splice pack. The rear dome lamp will turn on when the liftgate is opened. The cargo lamp is fed battery voltage through CKT 1732 from the BCM, through CKT 744 and grounded through the decklid ajar switch.
The courtesy lamps are fed battery power through CKT 1732 and are grounded through CKT 745-- left front, CKT 747--left rear, CKT 748--right rear, CKT 746--right front. These circuits will ground through the door jamb switches. The courtesy lamp will be illuminated when the affected door is opened. For example, when the right rear door is opened, the right rear door courtesy lamp will turn on.
Not a fuse problem , if the BCM had blown fuse other thing's wouldn't be working as well . . Probably wiring or BCM . Using factory diagnostic,s instead of guessing as to what the problem is , is the proper way .
Interior Lamps Diagnosis
Symptom
Procedure
Important: Before proceeding with these diagnostics, check for DTCs. If DTCs are present, complete the associated diagnostics. If the condition still exists, return to this chart.
All of the interior lamps are inoperative when any door is opened.
Chart 1
The dome lamp is inoperative in the ON position, but OK in the door position. The map lamps operate normally.
The dome lamp switch is faulty. Replace the dome lamp switch.
The dome lamp is inoperative in the DOOR position, but is OK in the ON position.
Chart 2
The dome lamp is inoperative in any position and both reading lamps are inoperative.
Disconnect the dome lamp connector (BLK 3-way).
Check for voltage at terminal "C" CKT 1732 ORN wire.
If OK, the dome/map lamp is faulty. If no voltage is present, there is an OPEN in CKT 1732.
Either the right or the left sunshade mirror lamp is inoperative.
Chart 3
Either the right or the left rear reading lamp is inoperative in the ON or the DOOR position.
Chart 4
The rear reading lamp is inoperative in the ON or the DOOR position.
Chart 5
Battery rundown protection is shorted to ground - B1482.
B1482
The left rear reading lamp is inoperative in the ON or the DOOR position.
Chart 6
Dec 12, 2017 | 1998 Saturn SL
Building Materials Logo
62 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
