Question about Canon imageRUNNER C5180 Color Copier
I have an Canon IRC5180, the colorprints and copys are blue, there is no edge on the paper. The machine do 10 copys perfect, nr. 11 is totally blue, i see the other colors on the print too, they are normal on the blue background. If i run calibration mode with open covers, i see on the transferbelt the colorpatterns, but i see too, that the belt is always cyan coated over the whole time. I blieve the cyandrum is ok, exchanging with another did not helped, same sympton. I think the drum is sure ok, cause 10 copys are normal at very nice copy, Nr. 11 was inacceptable. sometimes the machine stop with an errorcode, indicating that the cyan drum is defective, but changing them did not solve the problem, same as before... The blue background is 100% of the page, it is a adgesless print... Any idea or help?
  • 19 Answers
SOURCE: Copying from Colored Paper
No..The exposure will only give you an overall lighter or darker copy.. Dave UK
Posted on Feb 25, 2007
  • 62 Answers
SOURCE: Canon NP-4050 printing almost completely black pages
This problem appears to be that the scanlamp cable has fatigued and become open-circuit. This can be checked by selecting A3 and pressing the START button while having the lid up. Watch to see if the light stays on all the way through the forward pass of scan cycle, it can be intermittent. Make sure that the machine is unplugged before attempting to replace the cable.The drum is definitely on its way out at that amount of copies, but can be made to last a fair bit longer with some fine-tuning.
Posted on Nov 09, 2007
  • 67 Answers
SOURCE: My Canon IR c3200 started to print olors out of focus...
you have miss regrestion there are several ways to correct this process 1-go into service mode -function-clear-dc con -ok then take machine off unlug from wall outlet replug turn machine on 2-replace your itb assy. 3-there is another way but you have to be next to the machine and fimilar with second level service mode.
Posted on Nov 22, 2008
  • 615 Answers
SOURCE: Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Posted on Mar 28, 2010
  • 4041 Answers
SOURCE: Printer willl print color but does not print black and white
Hi There You can try/
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 28, 2010
Tray 1 has defaulted to a landscape orientation--cannot find a way to redirect it to portrait. NOT an issue with placement of paper to be copied.
There's a dial on the front right corner on each paper tray that tells the copier which paper size is loaded in that tray. In the case of letter size paper it also indicates orientation. If the short edge is facing the front of the copier the dial should be on LTR, if the 11" edge is closest to the front the dial should be set on LTRR.
Aug 25, 2011 | Canon imageRUNNER 4570 Copier
We spend a large portion of our day desperately trying to load paper and always getting the "paper loaded with too much skew" message. The paper is straight and on the blue line, i'd love to trun...
What type of paper are you using? It's common on cheap canvas or fabrics. Make sure the beginning of the roll about 10 inches must be straight in right side (blue line side). The paper slips upward freely and straight before lowering blue lever. Also this problem appears when your room is dry (low moisture) then PP sticker and some photo paper will curl. This checking feature is very useful for printing on whole roll in a single feed.
Mar 22, 2011 | HP Designjet Z6100 InkJet Printer
How can I found out the stats on a Canon NP 6551 (ie total pages, etc...)?
NP6560 Main Specifications
Main Unit
Type: Console
Platen: Stationary
Photoconductive material: Amorphous Silicon
Copying system: Electrostatic transfer system
Developing system: Toner projection system
Fixing system: Heat roller system
Acceptable copy stock: Paper drawer:17 to 24-lb bond (64 to 90 g/m2); plain paper
Stack bypass:17-lb bond to 110-lb index (64 to 200 g/m2); plain paper
(However, Keep in mind that the paper weight that can be used varies
depending on the type of the Sorter being used.
SADF tray : transparencies and labels
Acceptable originals: Sheets, books, and three-dimensional objects (up to 4.4-lb or 2 kg)
Maximum original size: 11" x 17"
Copy sizes: Paper drawer: STMT, STMTR, LTR, LTRR, LGL, and 11" x 17"
Stack bypass: 4 1/8" x 5 7/8" (horizontal placement) to 11" x 17"
Non-image areas: Leading edge: 1/4" (4.5 mm)
Left and right side: 1/16" (3 mm)
Trailing edge: 1/16" (2 mm)
Warm-up time: Approx. 6 minutes (at temp. of 68°F)
First copy time: Max. 2.8 seconds
[LTR size, direct copying, Manual Exposure Control, Drawer 1 (top
drawer) selected 1→1-sided mode]
Copy speed: Direct (100%) LTR 60 cpm
65 cpm (Accelerated mode)
LTRR 49 cpm
11"X 17" 30 cpm
LGL 40 cpm
STMT 60 cpm
STMTR 60 cpm
Reduction 11"x 17" → STMT 56 cpm (50%)
11"x 17" → LTR 48 cpm (64%)
11"x 17" → LGL 40 cpm (73%)
11"x 15" → LTR 48 cpm (73%)
LGL → LTR 49 cpm (78%)
Enlargement LGL → 11"x 17" 30 cpm (121%)
LTR → 11"x 17" 30 cpm (129%)
STMT → 11"x 17" 29 cpm (200%)
Magnification: Direct 1:1.000
Reduction 1:0.500 (11" x 17"→STMT)
1:0.647 (11" x 17"→LTR)
1:0.733 (11" x 17"→LGL/11" x 15"→LTR)
1:0.786 (LGL→LTR)
Enlargement 1:1.214 (LGL→11" x 17")
1:1.294 (LTR→11" x 17")
1:2.000 (STMT→11" x 17")
Zoom 1:0.490-1:2.040
Paper feeding system: Drawer 1, 2 (1,500 sheets x 2)
Drawer 3, 4 (550 sheets x 2)
Stack bypass (50 sheets; stack approx. 1/4" high)
Multiple copies: 1-999
Power source: 120 V, 60 Hz
Max. power consumption: Less than 2.0 kW
Dimensions (H x W x D): 46" x 25 3/8" x 28 1/2"
(1169 x 643 x 725 mm)
Installation Space (W x D): 40 5/8" x 28 1/2"
(1030 x 725 mm)
50 3/8" x 28 1/2" (1280 x 725 mm)
[With copy tray (option) attached and stack bypass auxiliary tray extended]
Weight: Approx. 462 lb (210 kg)
RDF (Standard equipment)
Originals: STMT to 11" x 17" size (STMT-size cannot be placed horizontally.)
Original tray: LTR 15-lb to 110-lb bond (52 to 200 g/m2)
11" x 17", LGL, LTRR, or STMT
15-lb to 32-lb bond (52 to 128 g/m2)
SADF tray: 11" x 17" to STMT
11-lb to 110-lb bond (38 to 200 g/m2)
Max. power consumption: 120 W
Original tray capacity: Original tray: 11" x 17" or LGL
50 sheets (20-lb bond or 80g/m2)
100 sheets (20-lb bond or 80g/m2)
1 sheet
Original replacement speed: 60 sheets/minute (LTR, horizontally placed)
Power supply: 24 V (supplied from main unit)
Dimensions (H x W x D): 6 7/8" x 25 3/8" x 21 1/4"
(174 x 643 x 539 mm)
Weight: Approx. 56.3 lb (25.5 kg)
These specifications are subject to change without notice.
Energy Saver
Additional Functions
Display Contrast
Enter a ID number with the Number ( 1 - 0 )
MEMO: ? If you make a mistake entering an ID number, press
the C
key. Then, enter the ID number again.
? You cannot enter two identical ID numbers.
? If you enter and store "000000" in place of a current
ID number, that ID number is canceled.
? You can store up to 1,000 ID numbers.
Press the [OK] key.
If you want to store another ID number, repeat
steps 3 to 5.
After entering all the ID numbers to be stored,
press the ID key. The display returns to the ID
entry screen.
Canceling the ID Mode: Clearing All ID Numbers
If you clear all the ID numbers then you can make copies without having to enter an ID
Press the Additional Functions , ID , Stop , and Additional Functions keys in that
1 order.
Energy Saver
Display Contrast
Press the [OK] key.
MEMO: ? If you want to stop all the ID#s from being cleared,
press the [C] key.
Press the [CLEAR ALL ID#s] key.
Press the [STORE USER ID#] key, then press
the [OK] key.
All the ID#s are cleared.
If you press the [OK] key, you will return to the
Standard mode.
MEMO: ? Storing all the ID#s under "000000" will also clear all
the ID#s.
In the ID mode, the copier keeps track of the copy quantity made under each ID number (up to
999,999). You can view the copy total for each ID number in the touch panel display.
1 order.
After pressing the [COPY TOTALS] key, press
2 the [OK] key.
Press the [?] or [?] key to check the copy totals
for a department. The copy totals can also be
displayed by entering the department number.
Press the Number keys ( 1 - 0 ) for a four digit
department number and it appears at the top of
the display. When you finish checking the copy
totals, press the [OK] key.
Copy Totals (Check Totals)
The following procedure describes how to clear the copy totals for all ID numbers to zero.
Copy Totals (Clear All Totals)
1 order.
Energy Saver
Display Contrast
Energy Saver
Display Contrast
2 the [OK] key.
Press the [CLEAR ALL TOTALS] key. 3
Press the [OK] key.
MEMO: ? To cancel clearing all totals, press the [C] key. 4
The copy totals for all ID numbers are cleared to
zero. If you press the [OK] key the display
requesting the entry of an ID number appears.
MEMO: ? You cannot clear the copy totals for ID numbers
Dec 21, 2010 | Canon NP 6551 Black and White Copier
We tried printing and copying with the setting set at LTR and LTR-R and we checked the paper tray and every time we make a copy or print it prints out the entire document perfectly centered across the...
It seems to me to be a problem of the Blue paper cassette size dial is set wrong. First see what the settings are from the display by pressing the paper select button. Most people have it set for the upper cassette to be LTR ( 8 1/2 X 11 inch paper - length running from front to rear in the cassette ) and the lower cassette to be LTR-R ( 8 1/2 X 11 inch ) or Legal ( paper length running left to right). Check to make sure the blue dial agrees with what's in the cassette. Try doing the testing by putting the paper on the glass first and closing the top. If this is correct and the problem is in the Documnet feeder then one of the raised flags may be broken or the sensor bad. The left one is for letter, the second one for LTR-R or legal and the third is for 11 X 17. The opening and closing fo the side guides also helps to determine paper size. Hope this helps you.
Nov 30, 2010 | Canon imageRUNNER 2270 Copier
We have been a given a fax machine but we need to change the number on the top of the fax paper?
if is a l350!open the cover over the one touch speed dails,press data registration and set!It says user settings,press set,Scroll to unit tel nr,press set,type in your nr,press set and there u go!
Mar 11, 2010 | Canon FAX-L350 Plain Paper Laser
We have a 1025iF Canon copier. I'm trying to
the first counter 101 is total of the machine every paper that gets out of the machine(print,fax,copy,reports)and the 201 its only about copys.
Oct 27, 2009 | Canon Office Equipment & Supplies
Cutting off the bottom 1/2 inch of 8-1/2 x 11 inch paper.
Notice where the metal retainer beneath the glass cuts off the view of your document you wish to copy
and make allowances on your copy. Most printers disallow some portion of the edges of any document
for handling the transport of the document through the feeder, or in the cases of contact copiers, a portion
of the sheet as you have experienced, so that the edges need not be so carefully adjusted to avoid the dark
line in edge copied formats.
Format all documents so that you do not need to copy the portion excluded.
Sometimes this can be accomplished by reducing the size of the document.
Apr 14, 2009 | Canon Office Equipment & Supplies
Poor copy quality - lines on paper
Hello sir; The problem is caused by drum cleaning blade, you need to replace drum cartridge or drum blade if you can.
Jan 23, 2009 | Canon NP 6551 Black and White Copier
Samsung tv settings
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
Mar 25, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Canon imageRUNNER C5180 Color Copier Logo
old marine
old marine
