Question about HP (D7580-60003) Motherboard
Line in I am using Windowsxp and I have a problem getting audacity to work with line in. I cannot access line in from the program. However the audio works normaly. Help please. fredje1
    Novelist:
    Scholar:
  • 167 Answers
Open control panel > Speech and audio devices > Audio > Sound recording > Advanced Change the device to "Line" just make a tick mark This should solve your problem
Posted on Sep 27, 2007
  • Deepu Amalan
    Deepu Amalan Sep 27, 2007
    If your system is equipped with 6-channel audio this doesn't apply.
    You should change it form the application that accompanies the audio driver.
    Usually this is accessible from the system tray
SOURCE:
Getting lidl silvercrest turntable / audacity to transfer records to computer
Assuming you've installed the Audacity software, first check your recording device. If you use Windows, first check the Audio Control Panel. For Windows 7, click Start > Control Panel > Hardware and Sound. Under Sound, click on the Manage Audio Devices link. In that window, click on the Recording tab. Select the USB option and make it the active device.
In Audacity, you may also need to make sure that this is the recording device that is active. That should be the third drop down from the left in the Device Toolbar. (If it isn't visible, click View > Toolbars and check it.) The Device Toolbar is right above the recording trace section in my version of Audacity.
Now click Record (the red circle) and start your turntable. Do you see a change in the trace? You should see a flat line for up to 10 seconds and then see this change to a set of high and low values.
If you don't get this, check if your USB ports are working. If you use a USB hub, try a direct connection. Check the device manager under Universal Serial Bus for a triangle with a red x or a yellow triangle. Try updating the driver by right clicking on the device. Also check Windows Update (for an optional update) or your computer manufacturer site for a new driver.
Unfortunately with the USB, you can't hear the recording as it is made. Do a short recording and then stop it. Then play back the selection. Adjust the input volume level lower if your trace is hitting the top of the box. This is clipping and your recording won't include the full signal from your record.
I've used Audacity for recording cassettes through the line in port. You can do this with some turntables if you add a pre-amplifier and use RCA to 3.5 mm adapter. Connect to the line in on the back of the desktop (blue).
If you could not install Audacity, go to http://audacity.sourceforge.net/ to get a version that works on your computer's OS.
I hope this helps.
Jul 05, 2012 | Audio Players & Recorders
Transfer music form fostex 440 to a PC
Step one- download the open source program Audacity. http://sourceforge.net/projects/audacity/?source=directory
Get an 1/8 inch stereo jack to stereo RCA outputs (some digital cameras with vieo capability have these cords.)
Plug your tape deck "Line Out" to the "microphone" input of your sound card if it does not have a "Line level Input." You will have to adjust the microphone level once you enable it in the microsoft windows audio settings accessible through the control panel file.
If you are using a mac, you will have to open the CDEV to set it up.
Then it is simply a matter of getting used to using the program, which does not take too long. Just remember to save either each tape side or each song as it's own project.
All open audio files in the display will play simulataneously, which is why you want to close them and start new.
If you need other tweeking types of programs to reduce hiss or potentially disk pops, there are some offerings also at sourceforge http://sourceforge.net They cater to Windows, linux and Mac.
The sampling rate you choose- if not variable- will affect sound quality and file size.
Feb 05, 2012 | Fostex Music
When I plug in my rca vr5220-a to the usb port on my mac it no longer recognizes the drive.
Your best bet is to play the recordings through the headphone connector to a pc audio line-in connector and capture the audio using something like Audacity. Then output them using audacity to mp3 to play on your mp3 player. I suspect that a similar program is available for mac also.
These VR5220 units are notorious for their failing USB feature.
Mar 10, 2011 | RCA VR5220 Digital Voice Recorder
How can I record a CD, which will contain songs from SINGSTAR singing by me and my friends ? Is it possible ?
plug the audio out from the ps3 to your computer and record it with audio recording software.If you don't have audio recording software on your computer you can download audacity for free.This program is cross platform and easy to use.You may need to buy a plug that converts rac a/v to you sound input on your computer.You can get these at radio shack or on line for cheap.
audacity.sourceforge.net/download/
http://www.shopping-headquarters.com/shop/pc/viewPrd.asp?idcategory=&idproduct=5458
Mar 19, 2010 | Sony Singstar Microphone for PS2
Copy audio tapes to CD's
Hello Trevor,
Easiest way I can think of is as follows:
1. Connect the "phones" of your cassette player to the "Line in" of your PC. Line In is coloured blue, you will need a a 3.5" to 3.5" male audio cable.
2. Next, install some sound capturing program on your computer. I can recommend Audacity: http://audacity.sourceforge.net/
3. Start the cassette player, check the volume levels, do some short test records. Once you are satisfied with the result, rewind and record side A of the cassette, then side B. Using again Audacity, you can cut the desired parts of the record and save them in the format and quality you like, I guess *.mp3.
4. Burn the files to a CD. You can use CD Burner XP Pro: http://cdburnerxp.se/
I hope that I have been very helpful. :)
Nov 13, 2009 | Audio Players & Recorders
How to record from Casset tape to CD disk? Thank you !
You can do this with your PC. Download a program called Audacity. It's free. With it, you can record audio from your Line IN connector. You'll need to connect your cassette player to the Line in on your PC. Start Audacity, set it to record and play your tape.
If you want to save the files as a .mp3, you'll also need to download the LAME mp3 encoder. In any case, when you have the file recorded, export it as a .mp3 or .wav and then use your CD burning program to create the CD.
Nov 06, 2009 | Durabrand CD-2086 Personal CD/MP3 Player
No sound coming through when recording from hi fi tape to computer
This is actually simple to do. Connect the line out on your tape player to the line in on your computer. Then download a free program, from the net called Audacity at http://audacity.sourceforge.net/. The program is totally free and works great. Some recording studios use this program. In the middle of the main Window on Audacity set it to record from Line in. This is from the small drop down menu next to the little microphone icon. Then hit the record button on Audacity and play your tape. You can record each song individually or you can record the whole side of the tape at once and separate the tracks when you save them. You can even use this program to clean up the sound on your recordings. I have transferred many of my tapes and records to CD using this process. I hope I have been helpful and good luck
Jul 01, 2008 | Genius Soundmaker Value 5.1
I cannot access the turntable thru my USB hub.
I received an updated driver from Numark but that still did not solve my problem. It turned out to be some sort of incompatability with my USB 2 card. When I plugged the turntable into my old USB 1 slot, my computer recognized it immediately. The new Audacity and MixMeister programs that were sent as a fix from Numark are just burning programs and not drivers for the device. I can now convert my old vinyl with ease.
Mar 10, 2008 | Numark ttUSB Turntable
Audio line in
Do you have the line in volume control turned up and not muted ?
You need to go into Options - Advanced controls - of the volume control to get the sliders for all of the inputs.
Nov 25, 2007 | IBM ThinkPad T40 2373 Notebook
HP (D7580-60003) Motherboard Logo
49 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
