Question about Audubon Society Audubon Singing Bird Clock
The clock will not run even after putting in new batteries. clock is not green it is light wood in color, if that matters.
Flashing red light on Morphy Richards 732000 Supervac
If it is supposed to go green then the battery is not being fully charged. Unit is under warranty and now is the time to have matter addressed.
Aug 20, 2015 | Vacuums
Joyful Crystal Bells Musical Table Clock Faux Wood with
The sensor/sending unit in the clock movement is bad. The movement needs to be replaced.
Nov 26, 2013 | Rhythm Clocks Joyful Crystal Bells Musical...
Hello! I have a 59017 timer, and this is my problem: When I put the timer in Timer option, If I have all the pins in off, the timer run ok, but if I put one Pin in On mode, The timer run ok but when find...
You don't say if this is new timer installation.
Or if timer was working before and suddenly stopped working.
I also own Woods 59017 timer from Home Depot.
1) New timer installation:
Open following link to access manual and read wiring instructions.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59017
2) Old timer that stopped working:
If timer dial does not rotate, then the timer is broken, does not have power, or is wired wrong.
If timer stalls when it gets to a pin, then the clock motor has gotten weak, and is overheated and will stop working.
3) Buy new GE 15070 timer from Home Depot for $18
http://waterheatertimer.org/GE-timers-and-manuals.html#15070
4) Buy new Woods 59017 at Amazon for $11 plus shipping
http://www.amazon.com/Woods-59017-Mechanical-Repeats-Switch/dp/B002MO3LWQ
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 03, 2011 | Woods Mechanical Inwall Timer 59017
I am replacing a light switch with a woods 59007 timer switch that has red, black, green and white wires.The current switch has only black, white and a bare wire and no other red or black wire. What do I...
1) Woods 59000 series in-wall countdown timer has extra wire to run electronic clock circuit inside timer, just like plugging in ordinary alarm clock.
2) Open following link for wiring instructions, and to download online manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59000
3) Instructions:
How to wire 59000 and 59017 in-wall timers
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground along with green wire.
5) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Feb 21, 2011 | Woods Hardware & Accessories
I have a wall switch and two outside ligthts. there appers to be two black wires to old switch. Timer has white, black, red, and green. I hagve tried all wiring scemes and get lights to stay and not turn...
You posted under the ST01C timer.
ST01C has black, red and blue wires, and has a battery to run the clock.
You have black, white, red and green.
So your timer has an electronic clock and no battery.
Let's go through the wires one at a time.
You can add a comment and I will help further if needed.
Old switch has 2 black wires.
One of these wire is black-Hot
The other wire is black-to-Load (load is your light, fan, motor)
Black-Hot connects to timer-black wire
Black-to-Load connects to timer-red wire
NOW ... if these wires are reversed, the timer will not operate, so simply reverse the wires.
There are two wires to go:
Timer-green wire goes to bare copper wire.
Timer-white wire is the wire that runs the clock inside the timer. This is just like plugging in your alarm clock so the clock runs.
The timer-white wire connects to the other white wires located inside the box.
These white wires are usually twisted together and covered with a wire nut.
So untwist the wire nut and add the timer-white wire to these wires.
What if your box does not have these other white wires?
Then in that case, connect the timer-white wire to the bare copper and the clock will run.
Nov 06, 2010 | Intermatic Inc. ST01C Digital In-Wall...
The old timer that was there quit working tryed to put a new woods one in but cant get it to work help
The following wiring diagram works for Woods, GE, Hagar, Leviton, Sylight, Utilitec, some Intermatic in-wall timers.
It does not apply to Aube timers or Intermatic battery-operated timers.
If the wires are not connected correctly, the timer will not operate as expected.
Click the manual override and see what happens.
If the lights do not turn ON with the manual override, then the wiring is suspect.
If the lights blink, then you have put the red and white wires together.
If the lights turn ON, but timer clock is not working, it is possible you have the black and red wires reversed.
If the white wire is not connected correctly, the clock mechanism will not operate.
Review the wiring.
Black-timer wire goes to black-hot-wire from breaker
Red-timer wire goes to black-wire going to Load (lights)
White-timer wire connects to the Neutral wires that are usually twisted together and covered with a wire nut.
IF your box does not contain those white wires, then you can work-around by connecting white wire to bare ground wire.
Nov 02, 2010 | Woods 59028 Programmable Timer Switch...
Can't migrate pokemon from emerald to diamond
When you get the message"Internal battery has run dry, the game can be played, however clock-based events will no longer occur" mean a glitch inside the coding of R/S/E games has been activated, stopping the internal clock. So AKA It does not see the time between migrating as 24 hours, Lilycove Dept. store no longer allows lotto tickets, berries don't grow, the berry master doesn't give berries out, no more migrating...etc.
Try putting the game pak in a gba, then firered or leafgreen into another, press select B on the leaf green pokemon title screen and followe the directions. a similar one is in emerald though it wont fix itself. Try pokemon colluseum pre-ordered CD.
Oct 22, 2009 | Nintendo Pokemon Emerald for Game Boy...
Orvis wood reel battery clock
Apr 05, 2017 | Home
Audubon Society Audubon Singing Bird Clock Logo
204 people viewed this question
Top Audubon Society Home Experts
john h
Tom Chichester
Are you an Audubon Society Home Expert? Answer questions, earn points and help others
