Question about Crown Audio Players & Recorders
Will a crown xls 602 220v work on a 110v cord
Trouble shooting crown xls ampilifier602
There are two similar circuits , use the good channel as a guide in
troubleshooting.
Aug 17, 2012 | Crown XLS 602 2-Channel Amplifier
Crown xls 802 service manual
Here you are. On the Crown web site.
Crown XLS 602
Jan 01, 2012 | Crown XLS 802 D Amplifier
I have a Crown XLS 802 amp that works fine but the fans do not work. They, however, are not frozen. Any help is appreciated. Jim
It is capable of detecting cooling fan failure so I would presume it hasn't decided to engage the fans yet.
Jul 21, 2011 | Crown XLS 602 2-Channel Amplifier
My crown amp (model xls 402) lost sound and the fault light came on
Chances are you have a failure in the final amp stage.
Check the voltage on the buss where the output transistors merge via the equalizing resistors. The voltage here should be very near zero.
Jun 02, 2010 | Crown-Audio XLS 402D Amplif 300 with 8o...
No power to Crown XLS 602 Amplifier
Hi...
There may be some internal fuses on that unit.
You can open it by taking the cover off and looking for fuses and discolored parts.
It may have a thermal fuse on the power transformer which then will require service
Check the web for service people in the UK
Mar 31, 2010 | Crown XLS 602 2-Channel Amplifier
There is a red light shinig inside my CROWN XLS
Lots of electronics have lights (LEDs) that turn on when they are plugged it. Most people just don't notice them. If it is working properly, then the light is normal.
Mar 04, 2010 | Crown XLS 602 2-Channel Amplifier
The fault light immediately comes on my Crown XLS 602 power amp immediately upon turning it on. It will not go out?
Hi try disconnecting the speaker outs and turn off bridge (if its on) If it doesnt work still, then suggest direct to a crown agent. The amp has a 3 year no fault warranty. Hopefully its still in!
All the best
Aug 04, 2009 | Crown XLS 602 2-Channel Amplifier
Crown XLS 802 D Amplifier Transformer!
You will need AC to AC converter that will accomodate US to UK mains. Look for power requirements of your amp on name plate and match with available converters online. Make sure power line frequencies match in/out requiremnts
Apr 17, 2008 | Crown XLS 802 D Amplifier
Hooking up 2 speakers to 1 speakon output
Power Output (1 kHz*) Stereo Bridge-Mono 8 Ohm 4 Ohm 8 Ohm XLS 802 500W 800W 1600W XLS 602 380W 600W 1200W XLS 402 300W 450W 900W XLS 202 200W 300W 600W *1 kHz Power: refers to maximum average power in watts at 1 kHz with 0.5% THD. It depends on the impedence of the speakers. Carfull as you could burn up this amp if you exceed the resistance rating on it. Go here on all of the specs of this model of crown amps. http://www.crownaudio.com/amp_htm/xlsspec.htm Good Luck
Mar 27, 2007 | Crown XLS202A 2-Channel Amplifier
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
