Question about Canon imageRUNNER C5180 Color Copier
I have an Canon IRC5180, the colorcopys and colorprints are totally blue in the output, The machine copy normal and i see the other colors too, but 100% of the paper is blue, no edge visible. The machien done some 10 copys normal, Nr. 11 was with blue blackground... if i run the callibration looking to the transferbelt (with open covers) i see that him do the testpatterns etc., but the belt is always blue coated too... Somtimes machine stop with errorcode, saying the drum is worn out, changing the drum did not helped to solve the problem... Any idea? I am sure, the drum is ok and not EOF cause the image quality was going worse from very nice to totally unacceptable by only 1 copy... Any ideas? what to do?
3 Suggested Answers
  • 990 Answers
SOURCE: Poor copy quality - lines on paper
Hello sir; The problem is caused by drum cleaning blade, you need to replace drum cartridge or drum blade if you can.
Posted on Jan 24, 2009
muleskinner2
  • 270 Answers
SOURCE: Our small office purchased a
When your drum was replaced did they put in a new drum assy or just replace the drum cylinder? I would purchase a new drum because these are one of the chepest to buy, around $ 80.00. They have a 6 month warranty and around 20,000 copies. I would replace the drum to see if that solves the problem. Before doing that, pull off the left side bypass assy. It is easily removed without tools. You should be able to see the drum and see if the drum is clean. If not, then replace the drum unit assy. Are you using only Canon toner, no other kind of brand will work. Generics should work but they are usually not as good a quality. The volume is very low and that should not be an issue. I believe its suppossed to handle 10,000 copies per month. Cleaning the glass top and below may help. The mirrors should also be cleaned as well. Good luck.
Posted on Dec 08, 2010
Bizhub C654e Color Copy Only show Cyan or Magenta Lines
So you have tried all the calibration tests? It sounds as if the alignment is off. If that isn't the case, you can try setting the copier back to default settings. I think in this make the reset button will be a tiny indented hole on the back.
Elisa Jed ' http://stores.abmcopier.com/canon-color-pre-owned/
Apr 13, 2014 | Office Equipment & Supplies
Canon irc5180 error code e000008-0001 solution
E008-001 End-of-life for Fuser assy. Not a cheap part to purchase either. The expected unit life is 300,000 copies.
Jul 27, 2012 | Office Equipment & Supplies
I wont you to help me as to how i can make a photocopy using my canon ir 3100cn machine. than you
have you ever operated a copier? it,s so simple place the originals face up on the DADF. SELECT the no. of copies. there will be option available on display for selecting whether you want B&W or color copies like b&w, auto color, full color etc. there will be copy ratio button for zoom(25%-400%). Now press start button.
For two sided copying press "two sided". There you will have mainly two options (i) 1>2 sided:- converts two single sided documents in to a two sided copy (ii)2>2 sided:- converts a 2 sided document into a 2 sided document. normally both will be done in book type for normal orientation.
Apr 11, 2011 | Canon iRC3100 Printer
When checking the meter reading on my canon ir c5185, there are the following codes before the totals: 101 102 108 230 321 322. Can you tell me their meanings?
Hello joe,hope you are well.Canon copiers have literally hundreds of "meters " that the device is constantly monitoring.Things like the number of 11x17 scans,reports printed,incoming faxes,outgoing faxes,prints at 600 dpi....etc.Its wild.The device is capable of displaying to the customer a total of six meters.The displayed meters may be customized for the customer by a technician as per the customers request or needs.Each meter is named by a number,for example "101".That particular meter indicates the total of how many sheets of paper(regardless of size) that have successfully exited the machine.102 meter indicates the total number of sheets that have been output using 8.5 X 11' as the basis.So a sheet of 11x17 paper would increment the 101 meter once,but the 102 meter would "click" twice.For billing purposes my company keeps an eye on the 102 meter to maximize profit,as it should be.Now how Canon determined the display of the other meters you see is a mystery.Again there is a meter named 958,which is the number of documents scanned to the MAILBOX. So, to completely answer your question: 108 is the total black and white copies made regardless of size.230 is just color and monocolor regardless of size.321 is{your gonna love this one}color prints on 11x17.322 is color prints on 8.5x11.So there ya' go! TMI city!!! Hope this helps.
Jan 07, 2011 | Canon Office Equipment & Supplies
I'm trying to use refilled ink cartridges in my Canon MP530, but I get a V (or U) 130 error message. Any thoughts?
CHECK INK
A.
U130
An ink tank that was once empty is installed.
Replace the ink tank.
Printing under the situation may damage the Print Head.
Canon shall not be liable for any machine malfunction or damage caused
by refilled ink tanks.
If you want to continue printing with the refilled ink tank installed, press
and hold the [Stop/Reset] for at least 5 seconds, and then release it. Using
refilled ink tanks are memorized.
* This operation will release the function for detecting the remaining ink
level
B.
i am not sure but is working on 520
1. print mono or print color for color
2.stop
3.ok
4.on/off
  1. Switch the printer OFF
  2. Press buttons 1 + 2 + 3 and 4 (simultaneously using four fingers)
  3. Keep pressing this four buttons for 10 seconds
  4. Release the On/Off button (number 4) (Keeping pressing the others)
  5. After a few seconds (when the printer go ON) you can release buttons 1, 2, 3
  1. Maybe step "c)" is not needed
  2. This procedure was used when I refilled the Black cartridge - try using the ColorCopy button instead of BlackCopy button (number 1) if you refill Color cartridge.
  3. Maybe there is no need for all the four buttons - you can try 1 + 4, 2 + 4 or 3 + 4. (or 1+2+4, 1+3+4, 2+3+4)
Dec 02, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Do you recommend Canon ClC 1180 for business
Depends on what you want to do with the copier. This a graphic's machine if you require high quality photo type output this is a perfect machine. It's not fast and will not run heavy stocks. It performs best with Hammermill color laser paper. If optioned with the Fiery Print Controller it will produce great print from photoshop and other graphics programs.
The CLC-1180 is Service intensive and will require frequent service calls and I highly recommend you have a service contract.
If you just require general office color such as Powerpoint , Word and don't require photo quality output, I would recommend the ImageRunner C-3200, ImageRunner C-3380 or ImageRunner 5180. These machines require less service and cost less per copy to operate.
Feb 19, 2010 | Canon CLC 1180 Copier
Copies made are totally black. what do i do? i changed cartridged, put in new paper then copied. it copied fine after 20pages, copy sounded like it was jamming up, paper came out with some parts black....
Hello limay_uera
Please check your Printer setup. or options ( I am not familiar with this printer. what terms they use- I'm not sure) Ther will be options for Print in Color or Black. Make sure the radio button for COLOR is checked. This way, black and color both will print in the correct color. So leave it on color even when you want to print in Black. The black radio button is there for a different reason.
Hope this will help you.
luciana44
Nov 19, 2009 | Canon FAX-L800 Plain Paper Laser
All copies and scanner outputs result in a totally black image
hi,
its could be hardware issue, if you tell me which printer, then we can try some reset on that machine..........
Regards,  raj_p5983
Jan 23, 2009 | HP PhotoSmart C4180 All-in-One Color...
Canon pixma ip3000 print problem
tthanks about that but i dont know how to deel with that
Dec 05, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon imageRUNNER C5180 Color Copier Logo
29 people viewed this question
old marine
old marine
