Question about Pyramat Sound Rocker Gaming Chair
How can i fix the control panel on my X Rocker game chair only 1 speaker works along with the sub woofer please help me
4 Suggested Answers
benwabnick
  • 2404 Answers
SOURCE: help
That is the specs of the ac adaptor that the X Rocker Chair uses to power the speakers on.
It uses a 10 Volt Ac Adaptor that runs off of 1.2 amps.
Posted on May 28, 2009
SOURCE: x-rocker gaming chair no sound from speakers
Theese gamer chairs are very poor quality. I have had 3 now, like them alot, but they give up on you after a while. The copper connectors inside the jacks were the problem for me.
Posted on Dec 30, 2009
SOURCE: only my right speaker works and the sub
I worked it out. I was having the same problem. you probably have the GREEN EARPHONE JACK plugged into the GREEN INPUT PORT on the side of the xrocker? simply move the GREEN EARPHONE JACK to the BLUE OUTPUT JACK on the xrocker and your sorted :) it was really bugging me so i messed about until i sorted it :)
Posted on Dec 17, 2010
Hi, only 2 speakers work and the sub woofer also
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 21, 2011 | Logitech Z-680 Computer Speakers
I have a subwoofer can i hook up to computer speakers
Yes you can. cut the left speaker lead and splice a wire from it to your sub woofer. If its a powered woofer you may have too much gain going in, You don't say what kind of sub it is or weather or not its a "powered" unit. If its a powered woofer (built in amp) you should take the output directly from the computer output (buy a 1/8 in male to 2 1/8 in female connector, send one output to your original speakers and the left side of the second output to the sub woofer. you can usually adjust the level of the sub (if powered) with a control on the unit. if you need more help, contact me but please tell me more about what you have.
Mar 18, 2011 | Altec Lansing Multimedia Computer Speakers
I have pyramat chair where do i run rca cables from
How to Connect a Pyramat
Pyramat gaming chairs are high-end video recliners that integrate audio speakers and subwoofers to increase video game immersion. Pyramat chairs feature speakers and woofers placed at the head and elbows of gamers for a surround-sound effect. The chairs come in two types. Game chairs are similar to regular computer or office furniture. Gamebags are reinforced beanbag chairs with installed speakers and controls similar to the game chairs. Each of these must be connected to the console or computer to run properly.
Instructions Things You'll Need: Pyramat game chair or gamebag 12-volt AC adapter 3.5 mm audio cable 3.5 mm RCA audio adapter 1 Close all programs and power off the computer or console that you are connecting. Power surges or connection problems could cause damage to the devices if still plugged. 2 Connect the 3.5 mm audio cable to the control area on the arm of the chair or side of the gamebag. 3 Plug the other end of the 3.5mm audio cable into the stereo jack on the computer or console. Use the RCA audio adapter if the console has only A/V cable support. 4 Connect the 12-volt AC adapter to the chair and insert the other end into a grounded power outlet, preferably one with a surge protector. 5 Power on your game chair or gamebag using the control and turn on the console or computer. 6 Adjust the sound settings on the chair and your video game device to suit your preferences.
Tips & Warnings Do not get your game chair wet as this can damage the speakers and controls.
All necessary parts should be included with your game chair. If it is missing anything, contact Pyramat customer service for replacements.
Mar 07, 2011 | Pyramat Sound Rocker Gaming Chair
Low sound and buzz from speakers / Hum noise from sub-woofer
Select Start > (right click) My Computer > Manage
In the Management window select > Device Manager
Next to Sound, Video and Game Controllers click the + sign
A yellow triangle will signify a problem so if one is present, right-click that device and select Properties
You can then choose to update the driver
For more details check Dell Xps 420 Manual.
Dell Xps 420 Manual
Apr 14, 2017 | Dell A525 Computer Speakers
YAMAHA AV receiver RX-V861 I have the message 'Vol-fix' appearing on Zone 2 and no sound. This was working fine until then
Setting the RX-V861 remote control to operate Zone 2:
  1. Using a ballpoint pen or similar object and press the [CODE SET] button RX-V861 remote control. The[TRANSMIT INDICATOR]on the remote should flash twice.
  2. Using the [NUMERICAL KEY PAD] on the remote and key in 9992, the [TRANSMIT INDICATOR] should flash.
Assigning the receivers internal amp for Zone 2:
  1. Set the remote control selector to [AMP]. (Located to the right of the volume buttons on the Remote.).
  2. Press the [SET MENU]button on the remote control.
  3. Arrow down to Manual Setup and press the Enter button on the remote control.
  4. Arrow to the [SOUND MENU] option and press the [ENTER] button on the remote control.
  5. Arrow to Speaker Set and press the [ENTER] button on the remote control.
  6. Arrow to the EXTRA SP ASSIGN and select ZONE2
  7. Press the [RETURN] button on the remote control to exit out and return to the Manual Setup.
NOTES: There is an option for setting the Maximum Volume and Initial Volume in the Zone Set menu.
  • Max Volume: This is an optional feature but isrecommended to prevent the accidental change in volume levels thatcould damage the speakers and receiver.
  • Initial Volume: This is also a great feature that would seamlessly start the volume level for the second or third zone at the desired level.
We do not recommend using any Speaker Selector boxes to enable more than the recommended number of speakers per terminal.
Controlling Zone 2 using the RX-V861 remote control:
  1. If the Main Zone on the receiver is on, press the [POWER BUTTON]down and while holding that button down press the [PHONO]/[**] button on the remote. The [TRANSMIT INDICATOR] will light up.
  2. You will not be able to use the following buttons on the remote: (Pressing any other button will cause the remote to exit Zone 2 mode. [POWER], [STANDBY], [VOLUME], [MUTE] and the [INPUT SELECTOR] buttons [DVD], [CD], etc.)
There are the instructions as written straight from yamaha. If you need any further assistance please let me know.
Thank you,
Lee
Dec 13, 2009 | Audio Players & Recorders
Only my right speaker works and the sub
Sep 20, 2009 | Pyramat Sound Rocker Gaming Chair
Help
May 28, 2009 | Pyramat Sound Rocker Gaming Chair
I Do Not Know How To Connect Boston Micromedia To My Computer
The Boston Micromedia speaker set comes with two speakers (right and left),a subwoofer, and a complete set of cables to connect everything up.
1.) Position the speakers. The two small speakers typically are spaced equal distance apart on a desk/table top to the benefit of the listener. The sub-woofer typically rests under the surface, on the floor for example.
.) Connect the cable sets to the back of the two small speakers along with the speaker feet.
Note: the small speaker with the volume control knob will have three cables coming from it. This will be the "right" speaker. The other speaker will have a single cable and will be the "left" speaker.
2.) The cable ends will be color coded to match the jackson the sub-woofer. Match up the color coded cables to the respective colors on the subwoofer as follows:
(a) White cable end (left speaker) to white jack on sub-woofer.
(b) Red cable end (right speaker) to red jack
(c) Purple cable end (input) to the purple jack
(d) Green cable end (computer out) to the computer's microphone output jack.
Note: if any of the cables are too short to reach their jacks for whatever reason, an extender cable with a female and male end can be purchased relatively inexpensively to make up the difference in distance.
3.) Power up the system (plug in power cables to the sub-woofer and wall), play some music, and adjust the sub-woofer sound (control knob) to suit listening pleasure.
A nice little set of speakers, I had mine for some years now and continue to enjoy them. Good luck!
May 17, 2009 | Boston Acoustics MicroMedia Computer...
X-rocker gaming chair no sound from speakers
Aug 19, 2008 | Pyramat Sound Rocker Gaming Chair
Jvc rx-e100rsl home cinema control center
unless there are some other connectors that may be used, i would think that the issue would be resolvable thru the system settings menu, there may be a speaker arrangement setting somewhere in the menus. The Sub is a .1 setting like 5.1 or 7.1, perhaps even 2.1 where the beginning number is the speaker channels and .1 is the sub. I would think with the sub being on a mono channel it woul/should work with any setting. If there is any more info you could supply I will further research this issue and try to help you get the sub working.
Jan 27, 2008 | Audio Players & Recorders
Pyramat Sound Rocker Gaming Chair  Logo
353 people viewed this question
Top Pyramat Video Game Consoles & Games Experts
Michel Laprise Sr
Tom Chichester
Are you a Pyramat Video Game Console and Game Expert? Answer questions, earn points and help others
