Question about Mitsubishi CS-32509 TV
MITSUBISHI CS-32509 - POWERS UP THEN IMMEDIATELY SHUTS OFF. WILL NOT COME ON AND DISPLAY A PICTURE.
4 Suggested Answers
  • 247 Answers
SOURCE: I can't find the owner's manual on my Mitsubishi CS 32509 pip
from what i could find out for you it is digital but only worth $50 - $100. hope this helps.
Posted on Dec 17, 2008
premtech
  • 934 Answers
SOURCE: Progressive scan?
No it's interlaced..
Progressive or noninterlaced scanning is a method for displaying, storing or transmitting moving images in which all the lines of each frame are drawn in sequence. This is in contrast to the interlacing used in traditional television systems where only the odd lines, then the even lines of each frame (each image now called a field) are drawn alternately.
The system was originally known as "sequential scanning" when it was used in the Baird 240 line television transmissions from Alexandra Palace, England in 1936. It was also used in Baird's experimental transmissions using 30 lines in the 1920s.
Bill
Posted on Jan 04, 2009
SuperTech-11
  • 1591 Answers
SOURCE: I have sound, but no
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom (look for discoloration of the circuit board around the base of the capacitor) need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the unit will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and/or inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are SURE it's only doing supply output ripple filtering,
and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
Backlight related video here:
http://www.youtube.com/watch?v=6XoF6QZ1dmw&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors, amplifiers, computer power supplies and motherboards, and other electronic equipment.
The parts are cheap, and skill required is minimal.
A great parts source is Digi-Key, and you can order the parts online at www.digikey.com
They typically cost under a dollar a piece plus a flat shipping rate.
The parts usually arrive one business day later.
If you watch the third video, you will see that even someone with no soldering experience can perform these repairs as demonstrated by the woman in the video.
Posted on Aug 24, 2011
Picture takes 10-15 sec to come on after setting all night. Sound is OK.
If this has been taking longer to come up over time, it is likely the picture tube at fault. Time to look into a new set.
Jun 25, 2014 | Mitsubishi CS-40503 TV
TURNS ON FOR A MINUTE THEN SHUTS OFF AND WILL NOT COME BACK ON
Check its output voltages, that comes out from its main power regualtor section.
Oct 19, 2013 | Mitsubishi CS-32509 TV
Several channels have lost sound entirely on our Mitsubishi CS-32509 television. On other channels things are in Spanish at times while in English at other times. Then there are other channels that have no...
You've managed to turn on "SAP" (second audio mode) which will cause the trouble. It doesn't affect all channels, as you're finding out, and can be frustrating. Mitsubishi remotes have a singe button for SAP, if I remember correctly, and you can press it and change modes without knowing it. (The button may be marked AUDIO or SAP.) Just press the button until the on-screen display tells you SAP is off. This will bring the sound back to normal.
This ranks up there with the mysterious black box that appears on some channels. This is because of closed-captioning being set to TEXT, and it happens the same way: pressing a button on the remote.
Jun 29, 2011 | Mitsubishi CS-32509 TV
CS-40503 takes about 10 minutes for the picture to appear once the set is turned on (sound comes on immediately)....when the picture does appear, it's dim for approx. 5 seconds then comes up to full...
IF THIS SET HAS PIP (PICTURE IN PICTURE) THAN I'D SAY THE PIP MODULE IS GOING BAD. YOU CAN REPLACE IT OR GET THE BYPASS PLUG FOR IT. IT JUST PLUGS IN.
Dec 10, 2009 | Mitsubishi CS-40503 TV
Progressive scan?
Bill
Jan 04, 2009 | Mitsubishi CS-32509 TV
Dec 17, 2008 | Mitsubishi CS-32509 TV
Picture with gray box
The text mode in the closed caption is turned on.Turn off the closed caption. I don't have the schematic in front of me, so, I will wing it. There may be a button on the remote that says CC, if so then use that button to turn it off, if not then go to the service menu and you may have to search a bit. Either way it's an easy fix and you can do it yourself. If you can't find it, then, reply and I will give better instructions when I get into my shop next week.
Aug 11, 2007 | Mitsubishi CS-32509 TV
Unplug the TV for 4 hours or more. This is called a 'Hard Reset'. Then plug it back in, turn it on and let the TV do it's thing. It will set itself up. Just follow the TV setup prompts. Guide Plus is a feature on the TV. Much like a TV guide showing all channels, shows, description of shows, times, etc..
Jun 30, 2007 | Mitsubishi CS-32509 TV
Televison & Video Logo
21 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
