Question about Cycling
Upland Desert Rat 20 inch bicycle won't change gears. any adjustments that can be done to fix this problem?
2 Suggested Answers
  • 1138 Answers
SOURCE: adjust rear hand brake on Mongoose 20 inch bicycle
Here is the perfect site for you:http://www.bikeguide.org/how-to/brakes/brakes.php They're called gyro brakes by the way.
Posted on Aug 28, 2009
Chain alignment
the pedal sprocket is a fixed position and the adjustment is done at rear wheel the chain will go out of alignment if rear tire is not tightened correctly which would cause wheel to tilt --bearing in wheel or pedal damaged --
Aug 30, 2015 | John Deere 20 Inch Kids Bike Riding Toy
Upland dragonfly 16 inch girls bike. Pops put it together for my daughter birthday gift. Notice daughter having trouble pedaling. I inspected by pedal by hand, with rear wheel off ground. Found it is...
the tire is pulled back too hard against the chain. Loosen the rear wheel nuts and re tighten them make sure there is no slack in the chain, and make sure the wheel is centered by checking the gap between the tire and the chainstay(rear part of frame, looks like a triangle)
Mar 23, 2015 | Cycling
Adjust brakes lever
undo the lock nut that is on the cable holder on the brake. turn the case out to adjust the brake lock up nut when done.
Jun 17, 2013 | Mongoose 20-Inch Gravity Games BMX...
I have a honda trx 350 es my problem is it wont go into any gear the motor was clicking but now its gone dead
Have a helper lift the rear wheel of the bicycle slightly off the ground.
Kneel beside the bike and turn the pedals slowly by hand. Using the shift lever, adjust the front derailleur so that it rests at about the midpoint of its movement range.
If the initial problem is that the chain won't shift onto the largest rear gear, locate the two small side-by-side adjustment screws on the rear derailleur. Turn the left (or upper) adjustment screw counterclockwise a quarter turn with a small Phillips screwdriver. If the initial problem is that the chain won't shift onto the smallest rear gear, skip to step 6.
Continue turning the pedals and shift through all the rear gears. If the chain will still not go onto the largest rear gear, shift the chain back down to the smallest rear gear. Turn the right (or lower) adjustment screw clockwise as far as possible before the chain begins to click or rattle.
5
Shift through the gears again to test. If necessary, turn the left (or upper) screw counterclockwise another quarter turn.
6
If the initial problem is that the chain won't shift onto the smallest rear gear, begin by turning the right (or lower) adjustment screw counterclockwise a quarter turn. Shift through the gears to test.
7
If the chain still won't go onto the smallest rear gear, shift the chain to the largest rear gear. Turn the left (or upper) adjustment screw clockwise as far as possible before the chain begins to click or rattle. Shift through all the gears to test.
8
Follow steps 1 through 7 for the front derailleur, which operates on exactly the same mechanism as the rear derailleur (you still lift the rear wheel in step 1). There are two side-by-side adjusting screws that control alignment.
If otherwise,
Tighten the high gear screw, the one that hits a cam when you shift to the smallest sprocket, until you can no longer shift into high gear. Put the shifter in high gear position and while turning the pedals, unscrew the high gear screw until the system engages high gear again. Shift between high gear and the second smallest several times, backing the screw out a little more, just until the derailleur shifts smoothly.
2. Tighten the low gear screw until you no longer get first gear. Repeat the process for this low gear limit - back the screw out just until the bike shifts smoothly from the second largest to the largest sprocket.
3. If you cannot engage high or low gear, or if the above technique does not work for high or low gear, the cable may be improperly adjusted.
Shift into high gear and push the shifter all the way to the end of its travel. Loosen the cable inner wire anchor bolt. That's the bolt with a hole through which the derailleur control wire is clamped. Pull the slack out of the wire, and retighten the anchor bolt.
If your bike has index shifting, you'll find an adjusting barrel either at the derailleur or the shifter. The adjusting barrel is a hollow screw at which the cable outer housing stops, but which the inner wire continues through. Fine adjust the cable tension by turning the adjusting barrel until the clicks on the shifter correspond with proper shifting at the derailleur.
If your bicycle does not engage high gear, or is slow to engage high gear, even though properly adjusted, the cable is probably the culprit. Replace the sticky or rusted cable, and the problem will usually go away.
If you have done everything right, but the bicycle does not shift reliably, the most common reason is that the chain and freewheel are too worn to work properly. If you replace one, you must replace both. A new chain on an old freewheel or visa versa usually skips, and the new part wears out very quickly.
Another possibility is a bent derailleur. The guide pulleys, those little wheels that take up the chain slack, must pivot on the same plane as the freewheel sprockets. Derailleurs become bent when the bike falls over on the right-hand side. Whenever you set a bicycle down, or put it in a car, set it on its left side to protect the derailleur. You can sometimes straighten out a bent derailleur by simply bending it back and readjusting the limit screws.
Hoping this will help to solve the problem, do take care....
Sep 19, 2011 | Quad Cycling
Derailing gears how do I adjust the high and low won't go into third gear jumps out gers
I put this "derailing gears how do I adjust" into Google and it found the answer. Try it yourself.
Sep 16, 2011 | Cycling
I recently bought my son a 20 inch bike with shimano gears on it and can not get 1st gear on it. How do you adjust it so you can get all 5 gears ? We can only get from 2nd to 5th.
When the cable moves the chain over to the largest gear it stops because something is stopping it. If you can push the derailleur over by hand far enough by hand then the cable is not pulling it far enough and needs to be tightened with the cable adjuster or the cable end clamp. If you can't move it manually far enough then look for an adjustment screw that it is stopping at when you move it to first gear position. Adjust this screw so it moves far enough and test it to see if the cable can do it. I hope this helps.
Aug 05, 2011 | Shimano Lx Rd M580 Rear Derailleur
Chain slipping after changing tire
You may have knocked the gear derailleur when fixing and re-fitting the rear wheel. This can knock the derailleur out of whack slightly and will need proper adjusting by your local bike shop.
Jun 02, 2010 | Schwinn Windwood 26 Women s Cruiser...
Gear change delayed
If it's UP shifting to a higher gear in the rear you probably have a little derailleur cable stretch. A little tweak of the rear cable barrel adjuster CCW about 1/4 turn at a time (no more than 1 turn).
Go here and read up on it.
http://www.parktool.com/repair/readhowto.asp?id=64
Mar 27, 2010 | Blackburn 4.0 Bike Computer
Adjust rear hand brake on Mongoose 20 inch bicycle
Aug 27, 2009 | Mongoose 20-Inch Gravity Games BMX...
Cycling Logo
26 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
