Question about Canon imageRUNNER C5180 Color Copier
I have a Canon IRC5180, the color prints and copys are totally blue. (over the full page), there is no edge or something, 100% blue on the page... if i try to recalibrate them and check the transverbelt running the machine with open right covers, i see that the belt is always blue too, the toner if always on the transferbelt as the machine try to recalibrate... I see the CMYK Pattern him produce too, but the belt is always blue... The machine done some prints normal before, maybe 10, Nr. 11 was blue (ather colors printed too) The machine sometimes, but really rare stopped with code, that the Cyan drum would have problems, but changing to another drum not fixed them... The drums are definite ok and not worn out. Any idea what to do or to check? Thx
4 Suggested Answers
  • 67 Answers
SOURCE: My Canon IR c3200 started to print olors out of focus...
you have miss regrestion there are several ways to correct this process 1-go into service mode -function-clear-dc con -ok then take machine off unlug from wall outlet replug turn machine on 2-replace your itb assy. 3-there is another way but you have to be next to the machine and fimilar with second level service mode.
Posted on Nov 22, 2008
komguy
  • 2306 Answers
SOURCE: MP830 Canon - NOZZLE CHECK does not print light cyan line
You will need a new printhead, QY6-0061-000, runs around $60.00 well worth it for your machine.
Posted on Sep 08, 2009
  • 615 Answers
SOURCE: Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Posted on Mar 28, 2010
How to reset full ink absorber on pixma mx 395
Tis not something that can be reset as far as I am aware.
To do it..
It's a big job! Printer needs to be taken apart*, thick felt ink pads need to be washed in water and fully dried (or replaced if you can get any) and then rebuilt.
*this is much harder than it should be!
Jun 02, 2014 | Canon PIXMA MX395 Inkjet Multifunction...
Printer is printing yellow instead of red and colour is fade
The magenta has run out (red).
Replace the HP 22 tri-color cartridge.
It probably has yellow and cyan (blue) left in it, and the black is most likely working as well, but if any of the 3 colors in the tricolor cartridge run out, the whole cartridge must be replaced.
For instance, if I printed my vacation photos and there was a lot of water and blue sky in all of them, the cyan might run out long before the cartridge life expectancy.
Also, don't forget that cartridges are rated in pages printed at 5% coverage.
Since a photo is about 25% of a full page, a photo printed at full bleed (edge to edge) will only yield 32 4 X 6 inch photos from a cartridge rated at 160 pages (5X expected coverage = 1/5 the prints)
Mar 27, 2011 | HP DeskJet F380 All-In-One Printer
Copies made are totally black. what do i do? i changed cartridged, put in new paper then copied. it copied fine after 20pages, copy sounded like it was jamming up, paper came out with some parts black....
Hello limay_uera
Please check your Printer setup. or options ( I am not familiar with this printer. what terms they use- I'm not sure) Ther will be options for Print in Color or Black. Make sure the radio button for COLOR is checked. This way, black and color both will print in the correct color. So leave it on color even when you want to print in Black. The black radio button is there for a different reason.
Hope this will help you.
luciana44
Nov 19, 2009 | Canon FAX-L800 Plain Paper Laser
Can't use black cartridge only to print
Unfortunately it is all true.
Personally I would stay away from Lexmark, I am a Canon fan, the MP520 looks real nice, but it's personal choice at the end of the day.
May 29, 2009 | Lexmark X2600 InkJet Printer
Canon prograf w8400
GO ONLINE AND TYPE THE FOLLOWING:
CANON IMAGEPROGRAF W8400 INKJET PRINTING 2 INCH BLACK LINE
ENTER
SEE IF ANYONE ELSE HAVING THIS PROBLEM BEFORE, GET SOME HELP OR IDEAS ON HOW TO FIX IT
GO ON LINE TO
WWW.CANONUSA.COM/IMAGEPROGRAF
ENTER
ROD
Feb 10, 2009 | Canon imagePROGRAF W8400 InkJet Printer
Detailed reports of when copies were made
Is this what u want ?????
To Print out the Department ID Print totals:
1. Select Additional Functions on the Control Panel.
2. Select System Settings.
3. Department ID Management.
4. Select On
5. Select Print Totals Page Totals.
6. Print List.
Feb 10, 2009 | Canon ImageRunner 2220I Copier
4 sets of copy counter numbers on canon imagerunner 2200
101:Total black copies and printed pages
103:Total A3 black copies and printed pages
201:Total A4 black copies
203:Total A3 black copies
Oct 31, 2008 | Canon imageRUNNER 2200
Canon i960 will not print in black ink
Yep same as above. Black prints very light gray after 5 years of good printing. Tried every test, replaced black cartridges with different brands. Just wondering if somehow you can clean the heads. I'm convinced the black head is almost totally clogged. Does anyone know how to remove the printer heas to do this?
Apr 01, 2008 | Canon I960 InkJet Photo Printer
Canon imageRUNNER C5180 Color Copier Logo
old marine
old marine
