Question about GE (PSS26MSRSS) Side by Side Refrigerator
How do I clean condenser coils on GE Refrigerator GSS23WSTA SS?
Sea Breeze
  • 4655 Answers
SOURCE: GE Fridge Motor Super Loud
Open the freezer door and see if the sound is there or if its near the floor. This needs to be corrected soon to prevent damage to your refrigerator. Your explanation makes be think the fan inside the freezer is loose or has ice buildup around the blades or the fan blade has become unbalanced in some way...Let me know and please rate me, Thanks, Sea Breeze
Posted on Jul 14, 2009
Sea Breeze
  • 4655 Answers
SOURCE: evaporator coil freezing, replaced main control
It is possible you have a defective fan motor in the condenser area or evaporator area. Sometimes when they become defective they will run for a while and just warm up and stop while the compressor continues to run. I learned that one on four costly returns to the home. The cost was to me not the customer. Thanks, Sea Breeze
Posted on Aug 05, 2009
Sea Breeze
  • 4655 Answers
SOURCE: GSS23WSTA refrigerator freezer section is getting warm.
Just the fist indication that defrost is not taking place. Most likely the defrost heater and defrost thermostat will need replaced. part number Click Here=> WR51X10101 for heater and will be easy to spot if burned out and you should also replace the defrost thermostat just in case part number Click here=> WR50X10068 Let me know if you need assistance, you may reach me through Appliance 911 or Sea Breeze Appliance Parts and Technical Services
Thank, Sea Breeze
Posted on Dec 25, 2009
Sea Breeze
  • 4655 Answers
SOURCE: GE Side by Side Refrigerator no longer cooling.
If not cooling or signs of not defrosting we will need to check the compressor start components, fan mortors and motherboard. Let me know and I can guide you through this. Sea Breeze
Posted on Apr 05, 2010
Testimonial: "Hi Sea Breez. I have ordered and replace the defrost heating element. I'll check the coils in a day or two. Thanks for providing the service manual!"
fixyourboard
  • 310 Answers
SOURCE: Ge Artica Refrigerator PSC23PSTA ss not cooling or
Typical problems that can cause this:
- iced up evaporator due to defrost problem
- failed thermistor (temperature sensor)
- compressor not running
all of the above could be due to a failure in the main control board
there is a diagnostic mode that can help you diagnose cause
Posted on Jun 22, 2010
Why is my GE Monogram, model zfsb26dnd SS, emitting an odor from the front bottom behind the base grill. The air blowing from underneath produces the smell when the fan is operating. The odor appears
The coil underneath the refrigerator, called the condenser coil, is probably blocked with dirt. This causes undue heat on that coil and the dirt stinks. The condenser coil must be cleaned thoroughly.
Dec 10, 2014 | GE Refrigerators
Our GE Monogram (model #ZFSB27DAG SS) side by side is not keeping the refrigerator side cold. It seems to be working fine on the freezer but not the ref. although the ref. side does work but just barely....
First start by Cleaning Your Condenser. If your condenser is extremely clogged. Clean it and let it run over night. Then check if there is a difference in the morning. If your condenser is clean then disregard. Make sure that you have good air flow into the fresh food(refrigerator) section threw the damper control. Click here to see your damper it is number 426. Another thing to check. Open your freezer and look on the back wall to see if there is defrost frost forming. Sometimes you have to remove the back panel to verify if your coils are clear. If you have a defrost problem starting it will restrict air flow into the refrigerator section. This is the most common problem on your model. If you remove the panel and the coils are frosted and restricting air. You can take a hair dryer and defrost them to get yourself by for a few days. This would either be your defrost termination switch, defrost timer or defrost heater bad. Here is your UNIT. Click Here to contact me.
Apr 04, 2013 | GE Monogram ZISx420DR 42-inch Side by Side...
Ge monogram..the actual model is zfsb26dnd ss.. The temperature has been randomly fluctuating worse than ever. The freezer is now at 31! It has never been perfect. It used to only climb in temp when it...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 13, 2011 | GE Monogram ZFSB26DRSS Stainless...
Hi, We have a ge refrigerator gsh25sgpa-ss. Water is leaking down the back of the inside of the freezer. We have replaced the filter and the water valve, any thoughts?
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 11, 2011 | GE Profile PSW26P Stainless Steel Side by...
Our freezer is thawing sporadically and not by our choice. We have a GE side-by-side (Mod# BSS25JSRF SS) & (Ser# FH241666). We've made sure we're shutting it properly. We've lost a lot of...
heatman101
Jul 15, 2011 | GE Refrigerators
GE refrigerator Model GTS18FBSARWW Don't have manual, as it came w/the condo. Don't know how to clean the coils or how to get to them, either. Thanks.
The condenser coil is located underneath the refrigerator on most models. YOu can access it from the front, or in some cases, in the rear. To access it from the rear, after pulling it away from the wall, you will have to remove the machine compartment cover screws and the cover itself. If it is the type i believe it is, it is called a no-clean condenser, but they still need occasional cleaning. It will be a barrel shaped condenser on the right side of the machine compartment. A good refrigerator tip for anyone looking to clean the condenser is to make sure you turn the fridge off or unplug before cleaning it.
Oct 13, 2010 | GE GTS18FBRWW Top Freezer Refrigerator
I have a GE refrigerator model number PSC25SG SA SS which has Problem that in every couple days the freezer and the refrigerator display panels display out of their setting ranges. For example, the...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Aug 24, 2010 | GE PSC25SGSSS Stainless Steel Side by Side...
I have a GE Profile side-by-side Refrig (model PSW26PSSB SS). The freezer does not stay cold. Often my food thaws. I?ve placed a cup of water in the freezer over night and it does not freeze. My ice maker...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 12, 2010 | GE Profile PSW26P Stainless Steel Side by...
Jul 14, 2009 | GE Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
